    [Plugin] SunTool - new Mar 2009
    49 Posts 26 Posters 44.8k Views 26 Watching
      Maciel
      [quote="SunTools"]MALAISE
      Register at:
      http://tx.technion.ac.il/~arrguedi/SunTools/download.html
      Hi Guedi,
      Ths for the tool. I couldn't register, got a message that the FormBuddy Quota Exceeded.
      Any other way?
      []s
      Maciel
        This tool was a problem because it rewrote a number of core class/methods that then clashed with many other tools - it hasn't been 'current' for a while - pity as it was potentially useful... 😞
        • I
          illiadjumper
          im already register, but still got no password send to me
            It also messes with base classes, so it's best avoided ??
            • Chris FullmerC
              This script has caused a lot of problems. Best if it were removed or re-written. But I can't keep up with life lately, so I won't be getting to it anytime soon.
                Robert_Johnson
                I've tried registering but have recieved no email, is there a problem with it?
                could someone foreward me a password to bobat16<at>hotmail<dot>com ?
                Cheers
                  Avex
                  Please, share a password 😒
                    Avex
                    Please please please please, I beg you. I really need this.
                    Emailme man<dot>juanel<at>gmail<dot>com
                    • masterpaulM
                      masterpaul
                      It does not seem to work; its a shame. I have the files. Its seems compatibility might had been broken. Also the website has a broken download link (and generally it seems broken and possibly abandoned). I have some old files from 2013 (unpacked); if someone would want to try and fix the issues I would be grateful.
                      SunTools.zip
                        As was mentioned a few posts back [but ~3 years ago !] http://sketchucation.com/forums/viewtopic.php?p=287700#p287700
                        The toolset seems abandoned, is flaky AND is potentially harmful to the loading/operation of several other tools anyway.
                        It is a 'rogue' which messes with native/base classes and its installation is best avoided.
                        It will also almost certainly not be v2014 compatible [but please complete your SCF User Profile so we might better help you].
                        The tool's files are encrypted as rbs - effectively making them uneditable and unknowable [without a Trimble-only 'decompiler' app - which would then break the ToS]...
                        As currently supplied in the previous post's ZIP, the files will 'install', but not 'load' as SketchUp starts, because the 'loader' rbs has be disabled using the SketchUcation 'Plugins Manager' [note the final ! on file-type]...
                        I do not recommend installing OR using it at all !
                        Instead, why not write a usage-spec and start a new thread that asks for development of a similar new Plugin ?
                        I have PM'd you with something to try...
                          jonathan tin yuan jong
                          the website is not working, is there any alternative i can access to the download? thanks
                            @jonathan
                            Look at the post just one before yours - this tool is not recommended for installation/use at all !
                            Look at the post just two before yours - there's a ZIP file containing the current files.
                            Use at your own risk. 😲
                            • E
                              eph
                              Personally I loved this tool, I would love to see it revived!
                              I mailed the creator with the question to update / open-source his code...
                              In the 2nd case, would anybody be interested in updating it for SU 2014+ ?
                              Crossing my fingers.. πŸ˜‰
                              EDIT - good news:
                              Thanks for your email, good to see that SunTools is useful and helpful during the design process.
                              As you sure know, SU 2014 uses a new version of Ruby, I’m updating the plug-in, hope it will be ready ASAP.
                              • E
                                esteban_arq
                                please someone give me the password thanx esteban_arq@hotmail.com
                                • facerF
                                  facer
                                  SunTool [plugin]
                                  Requires an update!
                                  You can make your requests to:
                                  Guedi Capeluto
                                  arrguedi@gmail.com
                                  http://technion.academia.edu/GuediCapeluto
                                  I have sent the following email requesting an update:
                                  Guedi ,
                                  I was checking in to see if you intended to "update" your SunTool to run on SketchUp 2017?
                                  • jujuJ
                                    juju
                                    That is an educational institution and SunTool, quite possibly, was a project of some sorts of his. I wouldn't hold my breath, although I do agree that it would be good to see the tool updated.
                                      Look in the EWH ?
                                      https://extensions.sketchup.com/en/search/site/sun
                                      This tool is well past its best and I don't recommend it ...
                                      • jujuJ
                                        juju
                                        @tig said:
                                        Look in the EWH ?
                                        I have had a look there recently, I didn't find anything quite like it although there is a variety to choose from, I'm favoring SunHours. None really seem to create a graphic Heliodon though.
                                        • 3 / 3
