    [Plugin] SunTool - new Mar 2009
    49 Posts 26 Posters 44.3k Views 26 Watching
      SunTools
      rv1974:
      Not a dumb question at all!
      This tools allows the analysis of solar access in one point (inside or outside buildings).
      It presents a view of how your point sees the sky (and the sun), in a way that you can asses in one unique view when that point is lighted (directly) by the sun during the whole year.
      First, draw the path of the sun using the SunPath Tools.
      Second choose Target Tool:
      --Look at >> will define the point on the sky that you are looking at. It will be the center of the screen. To start just leave the default [December 12:00], you can rotate your view afterward to see different parts of the sky (see help file).
      --Select the point for analysis >> just prepare in advance a point in the space that you would like to check. Inside a building it can be a seating position, if you want to check glare sources; outside buildings it can be an open space, or a solar system....
      That's it. Let me know if it was clear enough.
      Guedi
        rv1974
        Ooops I accidentally skipped the help file on the download page . that's why.. May be you should integrate it into setup.exe?
          SunTools
          IT IS integrated in the setup.exe. Look at Plugins/SunTools.
          Guedi
            rv1974
            I meant may be it should pop up after installation (or I missed it πŸ˜„Anyway many thanks!
            Another thing. Guedi do you have plans to make the interactive sun (ie moving sun dummy would affect su shadows, thomething like in 3ds max ?)
              SunTools
              A new version of SunTools Plugin (V2.0) for SketchUp is available now.
              The new version incorporates the calculation and visualization of Visible / Obstructed Sky from any point in a project (exterior/interior), and improvements of existing features as suggested by users.
              Plug-in Features
              • SunPATH: visualization (month and year)
              • SunPOS: Sun Position for a date and time
              • SunVIEW: Axonometric views from the Sun
              • SunPENETRATION: Analyze Sun Penetration/Access in any specific analysis point.
                New!
              • SkyVIEW: Calculate Sky Solid Angle (SSA) and % of visible sky / Visualize Visible/Obstructed sky from any point in your project
              V2.0 of the plug-in can be downloaded after registration from: http://tx.technion.ac.il/~arrguedi/SunTools/download.html
              A short documentation file can be viewed at: http://tx.technion.ac.il/~arrguedi/SunTools/dwnld_after_reg/stdwnld/sunTools_helpV2.pdf
              ** A Mac version of the plug-in will be available next. πŸ‘
              Enjoy.
              Guedi Capeluto
              arrguedi@technion.ac.il
              • kenK Offline
                ken
                Hello
                Well I installed the new version of SunTool 2.0 and I get the following plugin starting each time I start Sketchup. Anyone else with this problem.
                Ken
                • TIGT Online
                  Me too. Disabled it till it's fixed... Tried to limit it loading via an enclosing ruby but that fails - it's a compiled rbs...
                    SunTools
                    Ken and TIG (maybe others with the same issue).
                    Thanks for the feedback,
                    It seems like a conflict of names, I'll fix it today, and put an updated version for download.
                    Guedi
                      SunTools
                      an updated version of the installer can be downloaded now.
                      Hope this solve the problem. Please let me know.
                      Guedi
                      • kenK Offline
                        ken
                        @suntools said:
                        Guedi
                        New version did the trick, no more loading another script during start up.
                        Ken
                          SunTools
                          Hello Mac Users,
                          Following the previous announcement, SunTools Plugin for SketchUp is available now also for MAC !!
                          It can be downloaded after registration from: http://tx.technion.ac.il/~arrguedi/SunTools/download.html
                          Enjoy!!!
                          Guedi
                          • V Offline
                            vinh
                            Does any one have this password? please seng to me:phieuluu1985@yhaoo.com.vn
                              What password do you mean?
                                Maciel
                                [quote="SunTools"]MALAISE
                                Register at:
                                Hi Guedi,
                                Ths for the tool. I couldn't register, got a message that the FormBuddy Quota Exceeded.
                                Any other way?
                                []s
                                Maciel
                                • TIGT Online
                                  This tool was a problem because it rewrote a number of core class/methods that then clashed with many other tools - it hasn't been 'current' for a while - pity as it was potentially useful... 😞
                                  • I Offline
                                    illiadjumper
                                    im already register, but still got no password send to me
                                    • TIGT Online
                                      It also messes with base classes, so it's best avoided ??
                                      • Chris FullmerC Offline
                                        This script has caused a lot of problems. Best if it were removed or re-written. But I can't keep up with life lately, so I won't be getting to it anytime soon.
                                          Robert_Johnson
                                          I've tried registering but have recieved no email, is there a problem with it?
                                          could someone foreward me a password to bobat16<at>hotmail<dot>com ?
                                          Cheers
                                            Avex
                                            Please, share a password 😒
                                            • 2 / 3
