    [Plugin] SunTool - new Mar 2009
    49 Posts 26 Posters 44.8k Views 26 Watching
      It also messes with base classes, so it's best avoided ??
      • Chris FullmerC
        This script has caused a lot of problems. Best if it were removed or re-written. But I can't keep up with life lately, so I won't be getting to it anytime soon.
          Robert_Johnson
          I've tried registering but have recieved no email, is there a problem with it?
          could someone foreward me a password to bobat16<at>hotmail<dot>com ?
          Cheers
            Avex
            Please, share a password 😒
              Avex
              Please please please please, I beg you. I really need this.
              Emailme man<dot>juanel<at>gmail<dot>com
              • masterpaulM
                masterpaul
                It does not seem to work; its a shame. I have the files. Its seems compatibility might had been broken. Also the website has a broken download link (and generally it seems broken and possibly abandoned). I have some old files from 2013 (unpacked); if someone would want to try and fix the issues I would be grateful.
                SunTools.zip
                  As was mentioned a few posts back [but ~3 years ago !] http://sketchucation.com/forums/viewtopic.php?p=287700#p287700
                  The toolset seems abandoned, is flaky AND is potentially harmful to the loading/operation of several other tools anyway.
                  It is a 'rogue' which messes with native/base classes and its installation is best avoided.
                  It will also almost certainly not be v2014 compatible [but please complete your SCF User Profile so we might better help you].
                  The tool's files are encrypted as rbs - effectively making them uneditable and unknowable [without a Trimble-only 'decompiler' app - which would then break the ToS]...
                  As currently supplied in the previous post's ZIP, the files will 'install', but not 'load' as SketchUp starts, because the 'loader' rbs has be disabled using the SketchUcation 'Plugins Manager' [note the final ! on file-type]...
                  I do not recommend installing OR using it at all !
                  Instead, why not write a usage-spec and start a new thread that asks for development of a similar new Plugin ?
                  I have PM'd you with something to try...
                    jonathan tin yuan jong
                    the website is not working, is there any alternative i can access to the download? thanks
                      @jonathan
                      Look at the post just one before yours - this tool is not recommended for installation/use at all !
                      Look at the post just two before yours - there's a ZIP file containing the current files.
                      Use at your own risk. 😲
                      • E
                        eph
                        Personally I loved this tool, I would love to see it revived!
                        I mailed the creator with the question to update / open-source his code...
                        In the 2nd case, would anybody be interested in updating it for SU 2014+ ?
                        Crossing my fingers.. πŸ˜‰
                        EDIT - good news:
                        Thanks for your email, good to see that SunTools is useful and helpful during the design process.
                        As you sure know, SU 2014 uses a new version of Ruby, I’m updating the plug-in, hope it will be ready ASAP.
                        • E
                          esteban_arq
                          please someone give me the password thanx esteban_arq@hotmail.com
                          • facerF
                            facer
                            SunTool [plugin]
                            Requires an update!
                            You can make your requests to:
                            Guedi Capeluto
                            arrguedi@gmail.com
                            http://technion.academia.edu/GuediCapeluto
                            I have sent the following email requesting an update:
                            Guedi ,
                            I was checking in to see if you intended to "update" your SunTool to run on SketchUp 2017?
                            • jujuJ
                              juju
                              That is an educational institution and SunTool, quite possibly, was a project of some sorts of his. I wouldn't hold my breath, although I do agree that it would be good to see the tool updated.
                                Look in the EWH ?
                                https://extensions.sketchup.com/en/search/site/sun
                                This tool is well past its best and I don't recommend it ...
                                • jujuJ
                                  juju
                                  @tig said:
                                  Look in the EWH ?
                                  I have had a look there recently, I didn't find anything quite like it although there is a variety to choose from, I'm favoring SunHours. None really seem to create a graphic Heliodon though.
                                  • 3 / 3
