    [Plugin] UVTools 0.2 Pro (Beta) (Updated for SU6)
    198 Posts 73 Posters 170.5k Views 73 Watching
      dedmin
      columnrock.7z
      Forgot to mention - to import the .obj file in Blender 2.5 first open it in LithUnwrap, then save it again as .obj. When I tried to open directly in Blender there is an error.
      • romboutR Offline
        rombout
        so there is still no update on how to open the *.OBJ in blender???
        • Y Offline
          yiannosh
          Would u please give me a link to download the UV tool plug-in? Thanks
            At the bottom of the first post in the first page.
            • Alan FraserA Offline
              Alan Fraser
              Just an idea that stemmed from another topic on the UV mapping facilities in SU (or lack thereof). Is it possible to call an external program with Ruby, in the same way you can call an image editor in Preferences?
              If so, it would be really cool if some kind of .ini file could be added to the obj export command, so that exporting the UVs to obj automatically fired up UU3D (for example) and opened the proxy. I know that might not be possible for all UV editors as some don't open obj files, merely import them; but even if we had to write the path manually in some preference file, it would make for a much smoother workflow and effectively give SU an internal UV mapping module.
              This is a great plugin BTW. I haven't come across any glitches in it yet, in well over a year...even exporting entire people mapped from head to foot.
              3D Figures
                dedmin
                And UU3D supports SketchUp's files directly.
                  Alan Fraser
                  Ooooo!!! I must upgrade. Can it handle V8 files yet? Well somebody recognizes a gap in the market even if Google doesn't...and given the now huge list of import/export formats, there's little sense in Google limiting the export options of the free version.
                  3D Figures
                    I use UVLayout but after seeing this
                    http://www.unwrap3d.com/u3d/formats.aspx
                    It's making me think about changing. Alan if you've any deal breaker thoughts on this I'd love to hear them?
                      dedmin
                      The SketchUp plugin has been updated to import/export version 8 SketchUp files.
                      http://www.unwrap3d.com/u3d/news.aspx
                        Alan Fraser
                        Thanks dedmin, that does it for me.
                        Come on Rich, you know you want to have some Far Cry characters rampaging through your next set of visuals. πŸ˜‰
                        3D Figures
                          I've just purchased, now where are those Leisure Suit Larry models I had?
                            dedmin
                            I have to call them for a commission πŸ˜† 🀣
                            • PixeroP Offline
                              Pixero
                              Just bought it. I havent received a download link yet though...
                              Edit: Got it now. πŸ˜„
                                You may need to download the plugin for it at the bottom of this page:
                                http://www.unwrap3d.com/u3d/downloads.aspx
                                (I have not downloaded/purchased it - yet? - just browsed the site a bit so I am not sure...)
                                • PixeroP Offline
                                  Pixero
                                  I don't know if i'm blind or simply stupid, but I can't find any SketchUp export options in Ultimate Unwrap?
                                  Edit: Thanks Gaius. πŸ˜„
                                  It wasnt clear that all plugins had to be downloaded separately.
                                    Messing around this morning....
                                    to this...
                                    Lot's to get to grips with in UU3D. An extensive tutorial showing the whole process would help (from an SU point of view). Or if any knows of some good tutorials let me know.
                                      What's that small text-list of tools, top-left on your sceen-shots ?
                                      [ πŸ˜‰ ]
                                        It's a plugin i'm writing called 'Visualisationizer'. It uses voice recognition also so you can leave your shortcut hand on your crotch πŸ‘
                                        It's a bit buggy because anytime a say 'Push/Pull' it says 'make up your mind'.... πŸ˜’
                                          Now I am wondering what it says when you say that most frequent word you use.
                                          πŸ˜†
                                            F
                                            E
                                            C
                                            K
                                            Freehand
                                            Erase
                                            Circle
                                            K???
                                            • 6 / 10
