    [Plugin] UVTools 0.2 Pro (Beta) (Updated for SU6)
    198 Posts 73 Posters 187.6k Views 73 Watching
      dedmin
      @alan fraser said:
      @dedmin said:
      And UU3D supports SketchUp's files directly.
      Ooooo!!! I must upgrade. Can it handle V8 files yet? Well somebody recognizes a gap in the market even if Google doesn't...and given the now huge list of import/export formats, there's little sense in Google limiting the export options of the free version.
      The SketchUp plugin has been updated to import/export version 8 SketchUp files.
      The resource cannot be found.
      (www.unwrap3d.com)
      • Alan FraserA
        Alan Fraser
        Thanks dedmin, that does it for me.
        Come on Rich, you know you want to have some Far Cry characters rampaging through your next set of visuals. πŸ˜‰
        3D Figures
          I've just purchased, now where are those Leisure Suit Larry models I had?
            dedmin
            I have to call them for a commission πŸ˜† 🀣
            • PixeroP
              Pixero
              Just bought it. I havent received a download link yet though...
              Edit: Got it now. πŸ˜„
              • GaieusG
                You may need to download the plugin for it at the bottom of this page:
                http://www.unwrap3d.com/u3d/downloads.aspx
                (I have not downloaded/purchased it - yet? - just browsed the site a bit so I am not sure...)
                • PixeroP
                  Pixero
                  I don't know if i'm blind or simply stupid, but I can't find any SketchUp export options in Ultimate Unwrap?
                  Edit: Thanks Gaius. πŸ˜„
                  It wasnt clear that all plugins had to be downloaded separately.
                    Messing around this morning....
                    to this...
                    Lot's to get to grips with in UU3D. An extensive tutorial showing the whole process would help (from an SU point of view). Or if any knows of some good tutorials let me know.
                      What's that small text-list of tools, top-left on your sceen-shots ?
                      [ πŸ˜‰ ]
                        It's a plugin i'm writing called 'Visualisationizer'. It uses voice recognition also so you can leave your shortcut hand on your crotch πŸ‘
                        It's a bit buggy because anytime a say 'Push/Pull' it says 'make up your mind'.... πŸ˜’
                        • GaieusG
                          Now I am wondering what it says when you say that most frequent word you use.
                          πŸ˜†
                            F
                            E
                            C
                            K
                            Freehand
                            Erase
                            Circle
                            K???
                              Guys,
                              Try and keep on topic if you can? πŸ˜’
                              F&$k sake!
                              • U
                                umbra
                                Well, first post, and I must say I don't speak english, so sorry for the mistakes and thanks for your understanding.
                                The thing is after some days trying and trying this UV thing and being a noob using free software, I found this solution. I'm a happy woman now, and I want to share it πŸ˜„
                                I hope this can be useful for someone πŸ˜‰
                                1- paint the surface with the texture and export to .obj with UVTools
                                2- open the .obj with MeshLab and resave it
                                3- open it in Blender and edit the UV map (haaaaaarrrrddddddd)
                                4- export to .obj
                                5- open it again with MeshLab, and save it as .3ds
                                6- impot this .3ds in sketchup
                                I don't know what others uses this MeshLab have, but it's useful for avoiding this "Blender not importing UVTools .obj", and this issue I have with faces bad mapped importing the .obj with UVTools. It seems to handle a lot of 3d formats, but I have to say I'm learning, and doing some simple stuff as cups, apples, and so.
                                Tested in Kerkythea and everything seems to be ok (with SU2KT 3.16, the new one don't export the simple UVMapped textures spherical or cylindrical)
                                And thank you all people for sharing your plugins, you're doing Sketchup a great and fun app!!!
                                • GaieusG
                                  Hi Marina (and welcome),
                                  I am not entirely sure if it is relevant for your case but anyway, it may be useful info for some; many rendering apps (including Kerkythea) does not like these mapped UV's unless you do the mapping on pre-triangulated surfaces (already in SU). I used to have issues in Twilight (Kerkythea engine based) as well as Thea (same developer of both the rendering engine and the plugin).
                                  Tomasz, the author of the plugin is already aware of this so hopefully there will be a solution one day but until then, triangulation is the way to go (staying mainly in native SU).
                                  Here is a plugin which will triangulate your faces in SU:
                                  http://forums.sketchucation.com/viewtopic.php?t=23638
                                  • U
                                    umbra
                                    Hi Gaieus!
                                    Yes, your comment is relevant, I've learned about triangulated faces and UV mapping in the hard way (failing and failing LOL). I have Tig's plugin just for this πŸ˜‰
                                    And I have to add: the model has to be very clean, and MeshLab is useful checking this too, if you don't see the model in the right way in MeshLab, you're going to have problems editing and exporting the .obj.
                                    (Is this thread about whaat's plugin or I'm posting in the wrong place?)
                                    I know my method is a little tricky, if someone have an easier way for mac and free software, I'm reading.
                                    Thank you!
                                    • GaieusG
                                      Yes, this is about Whaat's plugin so we re in the right place.
                                      πŸ˜„
                                      However when we are at it, ou can also try Tgi3D Amorph. It also has some nice UV mapping tools (and a free PLE version with some poly count limitation as well as a full trial version with some time limitation...)
                                      And sorry Dale for hijacking the topic πŸ˜‰
                                      • rohallorahR
                                        rohallorah
                                        I have been looking for something like this for a long time now and I must say so far so good. I do a lot of interior related work so this is ideal. Been testing with Lithunwrap and seems to work fine so far.
                                        Here are 2 images I produced earlier on my thrid attampt:
                                        Sketchup Image
                                        http://i636.photobucket.com/albums/uu85/RobertOhalloran/UV Mapping with Sketchup/test.png
                                        VRAY Image
                                        http://i636.photobucket.com/albums/uu85/RobertOhalloran/UV Mapping with Sketchup/test_render.png
                                        Robert O'Halloran
                                        "Interior Architect & Designer"
                                        http://designermedia.ie
                                        • L
                                          leminilab
                                          Sketchup Image
                                          VRAY Image
                                          I was wondering what wrapping method you used for this?
                                          • "Live every day as if it were your last and then some day you'll be right."
                                          • "ThomThom rules!!!"
                                          • rohallorahR
                                            rohallorah
                                            Hi, I used the planer mode in LithUnwrap if I'm not mistaken. Worked quite well I think πŸ˜„
                                            Robert O'Halloran
                                            • 6 / 10
