    [Plugin] UVTools 0.2 Pro (Beta) (Updated for SU6)
    198 Posts 73 Posters 187.6k Views 73 Watching
    • GaieusG
      Well, from here it rather seems to be planar projection than spherical or cylindrical. With UV Tools 2, you need to do the mapping in an external program. Which one are you using?
      • Z
        zunkian
        Hi Gaieus!
        Thanks for your reply.
        I did not use any external mapping program. I mapped it directly in SU.
        This is how I did the mapping:
        -I loaded the organic model which is grouped originally, exploded it.
        -Imported the texture and placed it on the surface of the model.
        -Exploded the texture, then using the eyedropper in the paint tool, added the
        texture on the paint tool dialog box.
        -Then I applied the texture using the paint tool on the surface of the model.
        -I then right click on the model, selected the UV tools plugin and selected spherical map.
        That's how I did it.
        Did I do something wrong? Anyway, can you suggest an external program for me to do the mapping?
        Thanks for any input or advice.
        All the best,
        Andy
        • V
          vidy
          @zunkian said:
          Hi Gaieus!
          hmm.. i think its not wrong or not, what you've got is when you using projection texture..
          but if you want to use UVTools 0.2 plugin, you need external texture mapping editor such as: lithunwrap, ultimate unwrap 3d, etc..
          if you check the first page of this thread, Whaat did some clear explanation on how to using this plugin and he posted some link where you can download external texture mapping editor.
          regards,
          VD
          still so much to learn..
          • GaieusG
            @zunkian said:
            ...I then right click on the model, selected the UV tools plugin and selected spherical map...
            This is the wrong topic then. That's UVTools 1:
            http://forums.sketchucation.com/viewtopic.php?t=10404
            πŸ˜„
            And yes, sometimes that plugin does not work perfectly. Can you attach the model?
            • Z
              zunkian
              @vidy:
              Thanks, I already looked it up on the first page of the thread and there are the external UV mappers suggested.
              Will look into them.
              @Gaieus:
              Sure Gaieus, I will try to attach the model and see if you can help me out with the mapping.
              Thanks.
              All the best,
              Andy
              • Z
                zunkian
                Hi Gaieus!
                Apologies for a late reply.
                Anyway, as promised earlier, here's the rock model I have in SketchUp.
                This was generated in Acropora and then imported the mesh in SU.
                AQlso attached is the rock texture.
                Please find out if the "warped" map happens when you apply the texture on the model.
                Let me know what you come up with.
                All the best,
                Andy
                sketchup rock model
                rock texture
                  dedmin
                  columnrock.7z
                  Forgot to mention - to import the .obj file in Blender 2.5 first open it in LithUnwrap, then save it again as .obj. When I tried to open directly in Blender there is an error.
                  • romboutR
                    rombout
                    so there is still no update on how to open the *.OBJ in blender???
                    • Y
                      yiannosh
                      Would u please give me a link to download the UV tool plug-in? Thanks
                        At the bottom of the first post in the first page.
                        • Alan FraserA
                          Alan Fraser
                          Just an idea that stemmed from another topic on the UV mapping facilities in SU (or lack thereof). Is it possible to call an external program with Ruby, in the same way you can call an image editor in Preferences?
                          If so, it would be really cool if some kind of .ini file could be added to the obj export command, so that exporting the UVs to obj automatically fired up UU3D (for example) and opened the proxy. I know that might not be possible for all UV editors as some don't open obj files, merely import them; but even if we had to write the path manually in some preference file, it would make for a much smoother workflow and effectively give SU an internal UV mapping module.
                          This is a great plugin BTW. I haven't come across any glitches in it yet, in well over a year...even exporting entire people mapped from head to foot.
                          3D Figures
                            dedmin
                            And UU3D supports SketchUp's files directly.
                            • Alan FraserA
                              Alan Fraser
                              Ooooo!!! I must upgrade. Can it handle V8 files yet? Well somebody recognizes a gap in the market even if Google doesn't...and given the now huge list of import/export formats, there's little sense in Google limiting the export options of the free version.
                              3D Figures
                                I use UVLayout but after seeing this
                                The resource cannot be found.
                                (www.unwrap3d.com)
                                It's making me think about changing. Alan if you've any deal breaker thoughts on this I'd love to hear them?
                                  dedmin
                                  The SketchUp plugin has been updated to import/export version 8 SketchUp files.
                                  (www.unwrap3d.com)
                                  • Alan FraserA
                                    Alan Fraser
                                    Thanks dedmin, that does it for me.
                                    Come on Rich, you know you want to have some Far Cry characters rampaging through your next set of visuals. πŸ˜‰
                                    3D Figures
                                      I've just purchased, now where are those Leisure Suit Larry models I had?
                                        dedmin
                                        I have to call them for a commission πŸ˜† 🀣
                                        • PixeroP
                                          Pixero
                                          Just bought it. I havent received a download link yet though...
                                          Edit: Got it now. πŸ˜„
                                          • GaieusG
                                            You may need to download the plugin for it at the bottom of this page:
                                            http://www.unwrap3d.com/u3d/downloads.aspx
                                            (I have not downloaded/purchased it - yet? - just browsed the site a bit so I am not sure...)
                                            • 6 / 10
