    Google is Listening!
    329 Posts 70 Posters 127.1k Views 70 Watching
    • jbacusJ Offline
      jbacus
      @jgb said:
      First, I'm not sure what you mean by "archviz folks".
      By "archviz" I mean the community of professional SketchUp users who use it as the modeling front end to an advanced (photorealistic) rendering process for the pre-visualization of architectural design projects, either still images or animations. As for example represented in the CGarchitect forums.
      From your list of issues, I'm going to guess (please confirm or correct so I can answer your questions more accurately) that you are doing more "MCAD" kinds of projects with SketchUp. In other words, the sorts of projects which might also be done in Solidworks? Things which might eventually be fabricated in a machine shop?
      If this is the case, then I can imagine the sorts of problems you are seeing in SketchUp. And to be fair, we didn't design SketchUp for this sort of work. As you may know, SketchUphas a hard lower precision threshold at .001". For folks working on projects from 'furniture' to 'office campus' scales, this precision is perfectly sufficient. For folks working on projects smaller than 'furniture', problems like those you describe can occur. I think this probably accounts for all of your issues with 'face forming' and I'm afraid the only recourse is to scale your project up artificially while you are working. There is no fix for the .001" lower precision threshold coming in a future version of SketchUp.
      The issue you refer to as 'Hyper Pan' or 'Hyper Zoom' likely comes from the same root cause as the above issue. You're working close to the lower precision threshold in SketchUp, and tools which have been tuned for use at larger scales are beginning to behave in an less predictable way. You may find that the "Camera>Previous" command will allow you to recover easily from errant Zoom or Pan operations.
      The adoption of "Pencil Tool" as the startup tool comes from a historical decision that drawing should be the default behavior in SketchUp. Over time, alternate opinions have asserted themselves. In fact, for several releases, we flip-flopped on this decision. Which folks also found upsetting. In our current build (SU8M1), "Select" is the default tool on our Mac OS X build. Perhaps one day we will also make it so on Windows.
      Toolbar positions are very difficult for SketchUp to maintain when you are using lots of Ruby scripts that add their own toolbars. The addition of a new Ruby toolbar is currently the most chaos-inducing thing you can do. We're still working on this problem, but you should know that it is like 'cat herding' for us.
      As for your preferred units, I think this is a simple tech support issue. "Decimal > Inches" are supported in SU8 today. In fact, under the hood, SketchUp uses decimal inches natively for all calculations. If you would like this to be the default for all your new models, learn about Templates.
      Now for your mouse with all the buttons- this is a tech-support issue as well. SketchUp can never hope to support every mouse in the world natively. There are literally thousands of them. Most mouse drivers for more complex mice include some kind of application-level settings for their buttons. This is your best bet for configuring your mouse to use more buttons in SketchUp.
      There will always be some keys on your keyboard that are either reserved by SketchUp for some purpose, or by the operating system. Are you really running out of keys to use for all the thinks you want shortcuts to access?
      And finally, Materials. Certainly it is possible to modify sets of materials in SketchUp, though perhaps not in the ways you wish to do so. Probably you'll find some crossover with the archviz folks here (or maybe not?). I find that purging unused materials often solves the majority of my problems with ballooning material lists. A way to consolidate all of the similar colors in a model would be useful and I'm glad you've found a plugin to help you resolve that.
      "...exaggerate the essential and leave the obvious unclear." --Vincent Van Gogh
      John Bacus
      jbacus@sketchup.com
      • jason_marantoJ Offline
        jason_maranto
        I got some good names if you decide to go with an external UV unwrapper:
        WrapUp
        CutUp
        SliceUp
        TextureUp
        I'm sure there's more... ๐Ÿ˜‰
        Best,
        Jason.
        • StinkieS Offline
          Stinkie
          @jason_maranto said:
          WrapUp
          lol. ๐Ÿ‘
          Seriously, though, I know it's not likely going to happen, but UV-ing in SU would be sweet. ๐Ÿ˜Ž
          • soloS Offline
            UV mapping in SU needs to be made simple, there are just too many UV apps out there that are scary for new users, so SU needs to keep it simple somehow.
            • StinkieS Offline
              Stinkie
              I'm all for that, but still: probably easier said than done.
                jason_maranto
                I agree, although I think it mainly a language thing -- these programs often use very technical terms that can be very off-putting when the underlying concept is really very simple.
                For a decent UV unwrap when working with models you really only need:
                1. A knife tool to select the cutlines (these would just be regular edges)
                2. A select/group function to specify islands (Sketchups native groups are fine)
                3. A unwrap "3D skin" button
                Sure it would be nice to have edgeloop and symmetry based selection for speed, but those aren't critical. The navigation, move, scale, and rotate tools could all work exactly as in Sketchup.
                From there it's all 2D and optimization... and honestly that part should be pretty straight forward.
                Best,
                Jason.
                • StinkieS Offline
                  Stinkie
                  (...)the underlying concept is really very simple.
                  You'll do the tutorial series then. There, that's settled. ๐Ÿ’š
                    jason_maranto
                    ๐Ÿ˜† Yep, that's the plan -- I'm actually doing videos right now showing how to do it in ZBrush from Sketchup (they have a very nice plugin called UV Master for this)... but I would love to be able tell people they can stay inside the Sketchup "world" to do this basic task. โ˜€
                    Best,
                    Jason.
                    • Alan FraserA Offline
                      Alan Fraser
                      I used to be one of those continually calling for better UV mapping, but TBH I'm now perfectly happy working within SU just as it is, most of the time. And latterly I've started wrapping entire people...head, hair, clothing; right down to the knuckles on the hand and the seams on the jeans. There are two Rubies that changed all that; in UV Tools and UV Toolset.
                      For quick modifications within SU itself, I use Remember UVs. For anything more than that...or wrapping an organic shape from scratch I use Export UVs to Obj, then do the actual mapping with Ultimate Unwrap 3D, where you got all the functionality you need, including a wide range of off the shelf mapping modes plus the ability to create UV islands etc. The workflow for this is precisely the same as that called for in an earlier post by DacaD, involving a separate mapping module within SU itself. UU3D works the same as that module. You simply open the proxy obj, do the business, click Save, then switch back to SU and click Import UVs from Obj and the mesh is instantly updated.
                      Sure, an integrated mapper within SU itself might save you maybe 3 mouse clicks, but given the time it takes to map complex objects, the time difference is infinitesimal. In fact I'm thinking of writing a Ruby button to automatically open the proxy, so that UU3D will, in effect become a module of SU.
                      It's pretty cheap too. ๐Ÿ˜‰
                      There are plenty of easy things I'd like fixed (like putting edge and face count back into Entity Info. Given SU's intolerance of heavy geometry, this is pretty essential for quickly testing the most efficient method of construction, face-wise.) But UV mapping is now off my list.
                      Another bug is so old, I remember pointing it out to Jim Holman. If you're zoomed right in and have an edge highlighted, ready for moving, then attempt to move it...it will sometimes move in entirely the opposite direction to the mouse. It's not a scale/tolerance thing. I've had it happen to edges several inches long.
                      John, I know your aim is to have SU 'play nicely' with other apps rather than building the functionality into SU itself, so can we please have a decent obj importer..like Sycode's. Much of the mass-appeal market is based around the obj format...whether you prefer dae or not (I've stopped generating Collada flavour at FormFonts; no one ever downloaded it; nor have I had a single request for its reinstatement)...and it's a real pain having to convert everything prior to import.
                      3D Figures
                        dacad
                        Allan, for a minute you've put a smile in my face when you said you were mapping characters in SK, but then i've read the rest os your post on how you're doing it. You teaser ๐Ÿ˜›.
                        I don't have acess to UU3D so my mapping it's done in Max, and for me that's the problem. Sk limitations made me reuse Max more and more, so as soon as a mesh goes into Max it stays there, specially with the problem with importers you seem to know too. And staying out of SK just for mapping simple stuff for me it makes no sense. Plain and simple, for anyone that used SK intensivly before, Max sucks for modeling, from start to finish, with real measures and the snaps and navigation aren't as good and fluid as in Sk. But once you get better with, you stop fighting it and it stops bothering you (if i could model organic stuff with SK before there were plugins, i certainly can model with real measures in Max).
                        Just for the record, i don't want a Sk like Max! Max it's a behemonth and there's stuff there that either i don't have use for or simply don't know what it does. But that doesn't mean i think Sk it's perfect right now. The core use, for me at least, for Sk is modeling, mapping and animation/image (more for previz), and each of this departments need tweaks/fixes/basic tools to be in a stage that I can call mature, because i really don't need much more for most work, but each time i have to use other software to do basic stuff like mapping, or tweaking more organic shapes, or modeling something that will be faster or less probable to give me problems, or animating an object from point A to point B, etc, it won't get back to Sk simply because, now, i can do everything in the other software.
                        With the development team now beeing more focused in Google Earth and Layout, that was what started to push me to other softwares, so as i said in the begining i'm not sure how much i'm still the typical user for Sk, or a user that Sk wants.
                        Best Regards
                        David
                          tfdesign
                          I still can't figure out why all those who want SU to be like 3DSMax just use Blender! I mean Blender is also free!! ๐Ÿ˜’
                          I love SketchUp how it is. Being able to use plugins is great, but it's also great that they are not cluttering up SU's interface. You'll be really hard pushed to find any other modeller as powerful as SU, that even a 6 year-old can use. (My 6 year-old!) โ˜€
                            dacad
                            Tfdesign please re-read my post (or see the parts in bold below).
                            P.S.: and i love Sk or i wouldn't give myself this work wrinting what, why and how to make it better. ๐Ÿ˜‰
                            • jgbJ Offline
                              jgb
                              John
                              Thanks for explaining away just about everything.
                              Yes, I probably could make use of Solidworks, but I do not draw stuff to make shop drawings of small stuff. I design conceptual stuff, like a huge cargo airlifter (320 ft wingspan), and a hangar to house it. Then there is 2.5million sq ft manufacturing facility to make it using a proprietary manufacturing process. My normal lower precision limit is .1 inch, and rarely gets to .001 only when I draw some smaller components in separate drawings.
                              Precision is not the problem, and scaling up is not the solution for the GAP problem. I get most of the gaps in triangle formation on flat surfaces. I get the gaps because SU snaps my lines just a tad off where I want them when there are more than 1 endpoint very close by and I cannot toggle OFF the snap. Then the triangular face fails to form. V6 said there was a gap but not where, and V8 says nothing about why it won't form. I'm not asking you to fix the gap, just indicate where it is. I can zoom in to fix it myself.
                              You totally ignored that part. Yeah, I suppose I could set precision to 1 inch, but then stuff won't fit. As for scaling up, SU also has problems with say a 3,200 ft object as well.
                              Hyper Pan/zoom happens at any scale, precision or distance from the object. I use last view a lot to try and get back, but usually the last view before the hyper-pan is exactly over empty space which caused the problem.
                              As for the pencil or the pointer tool on startup causing your developers such great consternation, did you ever think of giving us a startup default CHOICE???? There is a whole section on preferences built-in to SU; add that as an item.
                              So a plugin blows away the toolbar positions. I can accept that. But then what is the function of "Save toolbar locations" and "Restore toolbar locations" in V8? They simply do not work.
                              Yeah, SU supports Decimal Inch as I always input dimensions to the VCB using feet, inch and decimal inch. SU just does NOT display Feet AND inch AND Decimal-inch. It displays Feet Inch and Fractions of an inch, and others as well, none of which I want to use.
                              As for complex mice, I gave you the easy solution, button output remap. Give the (any) mouse more buttons (say 10 or 12) and let me define what button I press to do what shortcut I want. That way it matters not to SU what brand of mouse and how many buttons it has.
                              As for KB control keys, and if I am running out, the answer is a qualified yes. My left hand hovers over the left side and there is only a small number of keys I can easily and quickly hit with thumb PLUS forefinger on the left side. More control keys will help.
                              As for purging "unused" materials, that is a non-starter if you think about it. The purging only is enabled in the material list, not the Entity Info panel. Then, if I have 2 (or more) objects in my model with say, black, but one was imported from some other SU model, its' black is now a separate and different black. You cannot purge a material in use. I can't even sort the list to put the 2 blacks side by each.
                              I guess you are right, I have to let the SU community of Ruby Wizards solve the problems SU developers can't seem to grasp, let alone fix.
                              jgb
                                It has always worked for me when I do need to use it.
                                • jbacusJ Offline
                                  jbacus
                                  Not sure what you're hoping to achieve here, but I am trying to answer your questions. I think I'm going to stop for a bit and show your post to some other folks to see if they can help me understand what you're trying to do. It isn't at all clear to me what work you're doing with SketchUp.
                                  John Bacus
                                  jbacus@sketchup.com
                                  • jeff hammondJ Offline
                                    do any apps actually support this and/or does anyone/industry use that? if i understand correctly, you want to see 27' - 3 5/8" written as 27' 3.625"?
                                      In aviation you'd use/see these type of dimensions in detailed/fabrication drawings. Not the feet part though. Just something like - 101.385"
                                      Or in machine shops for close tolerance manufacture/rework.
                                        Right, I see decimal inches and decimal feet used often enough. Just can't recall seeing them in this particular requested format.
                                        (not that I'm saying there's anything wrong with it. I'm just wondering if there's any real world use)
                                          Never seen it either. It seems jgb uses it for concept design of aircraft and hangars.
                                            jason_maranto
                                            Re: Alan Fraser
                                            Yep the(Beta) plugin is about as close to an inside Sketchup workflow as you are going to get -- and it makes my point for me that Sketchup itself would need hardly any changes to make this work. However the issue is this is a Pro version software I am talking about -- We should have access to a Sketchup-based UV workspace that allows for basic mapping types and unwrapping in a Pro software.
                                            As I said I can use ZBrush for this very well, but as was pointed out once I go to ZBrush I'm not going back into Sketchup because it's just too much of a painful workflow. If there is a missing feature that drives me away from Sketchup and into the arms of another app (like Modo) it will be this UV issue -- which is a complete dealbreaker for my models. Here's an example: http://forums.sketchucation.com/viewtopic.php?f=333&t=34508 -- right now I have to take this model into ZBrush for the sole reason of applying textures/decals.
                                            Bottom line, this limits the usefulness of Sketchup to large percentage of users... many of whom have paid to be "Pro" users. I really fail to see how it is logical to expect a user who simply wants to model a object in Sketchup and render a professional looking presentation in Layout purchase a 3rd party UV mapper. This is a basic function and if they are selling texturing/rendering capability then support for getting textures properly mapped to the geometry should just be part of the package.
                                            BTW there is a very fast compiled free OBJ importer here: http://forums.sketchucation.com/viewtopic.php?f=80&t=35936 -- since you don't mind using 3rd party apps/plugins for basic functions this should answer your feature request perfectly...
                                            Yes, I'm very happy to have generous coders giving us free tools, but it does tend to highlight how easy it could be for the Sketchup dev team to add them if they chose to.
                                            Best,
                                            Jason.
                                            • 13
                                            • 14
                                            • 15
                                            • 16
                                            • 17
                                            • 16 / 17
