    [Plugin] UVTools 0.2 Pro (Beta) (Updated for SU6)
    198 Posts 73 Posters 187.6k Views 73 Watching
    • P
      pmolsen
      Ok, so I have a model of a human head and 4 photos of each side of the head. I export the surface to a UV mapping program which rips it apart into a flat surface. Now what? How on earth do I distort the photos to match the weird-shaped surface, so the eyes are where they should be and not where the ears go etc? And how do I seamlessly join the photos together first?
      Is there a good tutorial on all of that somewhere please, because a head textured with black and white squares or bricks, like in the examples, just doesn't look right somehow 😄
      • P
        pmolsen
        Wow, that looks easy (Not!) 😞
        Shouldn't take more than a year to learn to use Blender. Another year and I might manage to unwrap my first model. Another couple of years and I should manage to texture it and import it back into Sketchup.
        Obviously not quite as straight forward as I had imagined. Guess I'm just a slow learner.
          jonorman
          Hi there Whaat.
          Wha(a)t is this ??? Perfect uv map in uvmapper3d but when i save it and reload to SU it gets a little ofsett some places ?? Somthing i do wrong or have forgotten or a little bug ??? Btw, great plugin.
          Edit: think the solution is that this only happens from a 90 degree horisontal / vertical face to a angel face wich in turn means that the lengtht of the edge is different from face to face. Can anyone fonfirm this ??
          upper blue background Uvmapper3d shows a good maping. Lower image shows reimported UV map in SU.. 2 faces offset from rest.
            3rdEye
            Yo,
            I am not shure, if I did somethimg wrong, but I tried with Maya 2009, and when I try to open or import the Bridge object, I can´t see anything in Maya. Even in the Outliner there is nothing displayed. When I open the UV Editor, it comes up blank.
            regards, 3rd Eye
            P.S.: Keep trying, we really need this UV Mapping stuff.
            By the way @ TIG: Your object importer is really cool, working for me nice so far! Thanx for taking the challenge! (I havent tried with really BIG models up to now) What I dont understand: If you chose the import comand Import "obj. with textures" why does it not bring the uv coordinates with it - or does it? (for me this didn´t work)
              The UV mapping should be brought in by the OBJimporter, assuming it was exported out initially!
              There is a limitation for 'distorted' textures - an exporter has some difficulties with those as they somehow require more 'points' than the OBJ format allows. For example, if you use SUp's built-in OBJ exporter you will find that a series of 'unique' distorted-texture-files are made for the 'distorted textures' and these are used instead of the usual image file for a non-distorted one. My own OBJexporter doesn't [yet] cope with distorted textures but does UV map scaled/rotated/placed textures OK - an upgrade is due when I get a moment free... 🤓
                Rafa
                For the Crash on SU 8 you have to experiment with this steps also:
                @olishea said:
                use the paint bucket tool to roughly apply the texture to your object.....it will not look correct (dont worry). now select the object (just click its surface) and go to edit>surface>uv tools>then choose cylindrical or spherical map.
                should be straight forward. you can change the scale of the texture in the sketchup materials window.
                Another thing, Unselect the faces that does not have the texture.
                • Z
                  zunkian
                  Hello everyone!
                  I have a little problem I want it resolved.
                  I downloaded the plugin UVTools 0.2 Pro and seems to be working fine as long as I follow the instructions
                  until I found some glitches on the mapping of the texture.
                  I am trying to map a texture on an organic model of a columnar rock and this is the result:
                  texture mapped on organic model
                  I noticed that a part of the model seems to "stretch" or distort the texture image. In other parts, it's just fine.
                  I also tried it on a cylinder model (see attachment below), it happens the same. When I used the UVTools plugin, I use spherical mapping but it also happens the same when using cylindrical mapping.
                  Please tell me what seems to be the problem why the texture map isn't smoothly mapped on the model?
                  Thanks for any input or help you can provide.
                  texture mapped on cylindrical model
                  All the best,
                  Andy
                  • GaieusG
                    Well, from here it rather seems to be planar projection than spherical or cylindrical. With UV Tools 2, you need to do the mapping in an external program. Which one are you using?
                    • Z
                      zunkian
                      Hi Gaieus!
                      Thanks for your reply.
                      I did not use any external mapping program. I mapped it directly in SU.
                      This is how I did the mapping:
                      -I loaded the organic model which is grouped originally, exploded it.
                      -Imported the texture and placed it on the surface of the model.
                      -Exploded the texture, then using the eyedropper in the paint tool, added the
                      texture on the paint tool dialog box.
                      -Then I applied the texture using the paint tool on the surface of the model.
                      -I then right click on the model, selected the UV tools plugin and selected spherical map.
                      That's how I did it.
                      Did I do something wrong? Anyway, can you suggest an external program for me to do the mapping?
                      Thanks for any input or advice.
                      All the best,
                      Andy
                      • V
                        vidy
                        @zunkian said:
                        Hi Gaieus!
                        hmm.. i think its not wrong or not, what you've got is when you using projection texture..
                        but if you want to use UVTools 0.2 plugin, you need external texture mapping editor such as: lithunwrap, ultimate unwrap 3d, etc..
                        if you check the first page of this thread, Whaat did some clear explanation on how to using this plugin and he posted some link where you can download external texture mapping editor.
                        regards,
                        VD
                        still so much to learn..
                        • GaieusG
                          @zunkian said:
                          ...I then right click on the model, selected the UV tools plugin and selected spherical map...
                          This is the wrong topic then. That's UVTools 1:
                          http://forums.sketchucation.com/viewtopic.php?t=10404
                          And yes, sometimes that plugin does not work perfectly. Can you attach the model?
                          • Z
                            zunkian
                            @vidy:
                            Thanks, I already looked it up on the first page of the thread and there are the external UV mappers suggested.
                            Will look into them.
                            @Gaieus:
                            Sure Gaieus, I will try to attach the model and see if you can help me out with the mapping.
                            Thanks.
                            All the best,
                            Andy
                            • Z
                              zunkian
                              Hi Gaieus!
                              Apologies for a late reply.
                              Anyway, as promised earlier, here's the rock model I have in SketchUp.
                              This was generated in Acropora and then imported the mesh in SU.
                              AQlso attached is the rock texture.
                              Please find out if the "warped" map happens when you apply the texture on the model.
                              Let me know what you come up with.
                              All the best,
                              Andy
                              sketchup rock model
                              rock texture
                                dedmin
                                columnrock.7z
                                Forgot to mention - to import the .obj file in Blender 2.5 first open it in LithUnwrap, then save it again as .obj. When I tried to open directly in Blender there is an error.
                                • romboutR
                                  rombout
                                  so there is still no update on how to open the *.OBJ in blender???
                                  • Y
                                    yiannosh
                                    Would u please give me a link to download the UV tool plug-in? Thanks
                                      At the bottom of the first post in the first page.
                                      • Alan FraserA
                                        Alan Fraser
                                        Just an idea that stemmed from another topic on the UV mapping facilities in SU (or lack thereof). Is it possible to call an external program with Ruby, in the same way you can call an image editor in Preferences?
                                        If so, it would be really cool if some kind of .ini file could be added to the obj export command, so that exporting the UVs to obj automatically fired up UU3D (for example) and opened the proxy. I know that might not be possible for all UV editors as some don't open obj files, merely import them; but even if we had to write the path manually in some preference file, it would make for a much smoother workflow and effectively give SU an internal UV mapping module.
                                        This is a great plugin BTW. I haven't come across any glitches in it yet, in well over a year...even exporting entire people mapped from head to foot.
                                        3D Figures
                                          dedmin
                                          And UU3D supports SketchUp's files directly.
                                          • Alan FraserA
                                            Alan Fraser
                                            Ooooo!!! I must upgrade. Can it handle V8 files yet? Well somebody recognizes a gap in the market even if Google doesn't...and given the now huge list of import/export formats, there's little sense in Google limiting the export options of the free version.
                                            3D Figures
                                            • 5 / 10
