    Solid Tools crashing on mac
    38 Posts 10 Posters 4.6k Views 10 Watching
    • EdsonE
      Edson
      @tig said:
      I assume you don't have the 'Outliner' window open whilst you are doing these operations - that is a known and notorious cause of crashes...
      The HolePunch tool does use observers to ensure that the cutting component and its 'hole' are 'linked' they select, move together etc.
      I assume the objects you are trying to 'boolean' are simple non-cutting instances that haven't any 'hole-punching' connections... The HolePunchSelectionObserver only kicks in if certain prerequisites are met like component behavior and paired attributes... There is also a tools Observer that spots if you are 'copying' punched-objects... but again I don't see how that might kick in in this case...
      Clearly Hole Punching works 'safely' on my PC and also for many other users, I am [currently] at a loss as to why it might be causing this in your specific case[s]... I get Edson's example to boolean perfectly in all varieties with HolePunching enabled ???
      The code is 'open' so if Google spot what might be up I'd be more than grateful... πŸ˜•
      TIG,
      yes, you are right. my outliner window was closed.
      I removed the HolePunchTool from my plugins folder and tried the solid tools with all the files with which I had problems before. no problems at all. I am not sure this is conclusive evidence but it looks like there is some kind of conflict between HolePunchTool and Solid Tools on mac.
      http://www.mahfuz.arq.br
        Are there any MAC users with 'HolePunch' loaded who are getting good results with Solid Tools too ?
        Perhaps Google can cast some light on what might be happening... πŸ˜•
        • T
          TriciaS
          Hi all,
          We'll take a look and see if we can figure out what the conflict is.
          Tricia
          • GaieusG
            Hi Tricia, long time no see! I hope you are fine!
            • bmikeB
              bmike
              Outliner closed (only open when I really need it!)
              The model and examples I posted did not have any objects that had made use of the HolePunch tool - I can create a new model, a few solids, and if HolePunch is in the folder, it will crash.
              As I said - to have the solids tools work with HolePunch in my Plugins folder, I need to use groups, and not components to perform the solid operation. This may be a clue, but I'm not a programmer...
              My guess - HolePunch and SolidTools conflict with how they handle creating copies of components while performing their operations.
              I'm not sure which version of HolePunch I'm running - but I will go back to the thread and find your latest update and see if this causes any problems.
              • bmikeB
                bmike
                OK, running your latest update of the #HolePunch.rb things seem to be working fine.
                I've attached the previous version I had which appeared to cause the issues.
                #HolePunchTool.txt
                  Thanks bmike.
                  Bmike was on v1.6 πŸ˜’
                  Edson - do you have the latest copy of HolePunch ? It should be v2.0 http://forums.sketchucation.com/viewtopic.php?p=271170#p271170
                  1.7 20110121 Observers are now first removed then added to avoid duplication and rare clashes with other scripts.
                  1.8 20110208 Finding Cutting Component's 'loop' edges to match with punched hole algorithm improved to avoid glitches if multiple edges in the Z=0 plane.
                  1.9 20110209 Context-menu code recast to avoid exacerbating gray-out issue.
                  2.0 20110309 Punched hole algorithm improved for nested groups/components.
                  These 4 updates since then might have already fixed the 'clash' issue ❓
                  • bmikeB
                    bmike
                    @tig said:
                    Thanks bmike.
                    Tough for me to keep up with all the updates and plugins!!!
                    Glad we solved my problem. Hopefully this works for Edson!!!
                    • T
                      TriciaS
                      Hi Csaba - hope you are fine as well πŸ˜›
                      Sounds like this issue may be solved. TIG/Edson - just let me know if you want us to look into anything.
                      • EdsonE
                        Edson
                        good news. the version I had installed was 1.6. I updated it and ran all the tests. it worked perfectly! no crashes. 😍
                        thanks to all of you for cracking this one.
                          Hooray! πŸ˜„
                          So it looks like I had fixed the problem even BEFORE you realized you had it... had you only kept HolePunch up to date πŸ˜’
                          At least I can sleep tonight...... πŸ˜’ πŸ˜‰
                          • EdsonE
                            Edson
                            @tig said:
                            Hooray! πŸ˜„
                            yes, I wish I could keep up to date with so many good plugins. 😲
                            you should not lose sleep over that. your credit with us is enormous. πŸ‘
                            • GaieusG
                              We could create a global announcement for "Critical plugin updates" and from time-to-time, post news there when it turns out that a plugin conflicts with something and users should update.
                              • EdsonE
                                Edson
                                I was also having crashes when using chris's Shape Bender. after updating HolePunchTool that problem also went away! 😍
                                • 2 / 2
