    [Plugin] Quadrilateralizer v1.1 20110215
    28 Posts 14 Posters 37.9k Views 14 Watching
      I can envisage another tool to optimize selected coplanar quads...
      It tests a faces for their vertices' 'concave-ness'/co-linearity and adjusts the concave/linear vertex location until it is just convex... I suspect this might involve a lot of tail-chasing as one faces concave vertex could be its neighbor's convex vertex ๐Ÿ˜’
      Alternatively if any of the Quadrilateralized faces have co-linear or concave vertices select all and Quadrilateralize them a second time - that should fix them - although the mesh will then be much finer ๐Ÿ˜’ BUT there's no such thing as as a free lunch...Capture.PNG
      • CAntonisC
        CAntonis
        Thanks so much TIG!
        One question though: Is this gonna help exporting a model to other modelers with greater detail, is it just because quad faced geometry is better or both?
        Downloaded already and I ll be checking for updates!!!!
        Again THANKS A BOUNCH!
        • Didier BurD
          Didier Bur
          Hi TIG,
          When translating into french, I came across this (line 82):
          return nil if UI.messagebox("Quadrilateralizer;\n\nThe Selected Faces are NOT\nALL of the Connected Faces.\nDo you want to Continue ?",MB_YESNO)==7
          Isn't this message confusing or wrong ?
          DB
            @didier bur said:
            Hi TIG,
            The selected-faces are not ALL of the connected-faces.
            Do you want to continue?
            ๐Ÿ˜•
            Les choisir-faces ne sont pas tous les relier-faces.
            Voulez-vous continuer ?
            • Didier BurD
              Didier Bur
              Les faces choisies ne font PAS TOUTES partie des faces connectรฉes
              DB
                I couldn't have put it better myself!
                Je n'aurais pas pu mieux dire moi-mรชme! ๐Ÿ˜„
                • KrisidiousK
                  Krisidious
                  you Rock Tig...
                  By: Kristoff Rand
                  • B
                    Ben Ritter
                    TIG, thank you.
                    • EarthMoverE
                      EarthMover
                      ๐Ÿ‘ ๐Ÿ‘ Thanks bro!
                      Content Creator at Skapeup
                        Thanks TIG....any chance of a progress bar?
                          Here's v1.1 http://forums.sketchucation.com/viewtopic.php?p=309120#p309120
                          More info and percentage progress now reported in the Status Bar.
                            That was quick ๐Ÿ˜ฒ
                              Sorry it took so long I was at the corner-shop buying some milk when you posted ๐Ÿ˜ฒ ๐Ÿ˜‰
                                Now that you're around and idle, how about this ๐Ÿ˜‰
                                • GaieusG
                                  Thanks TIG. The more I think about this plugin, the more I like it. It can have so many areas to use.
                                    dedmin
                                    So, if I drink more milk maybe I can start writing wonderful plugins as You do?
                                    ๐Ÿ˜’ โ˜€
                                    • GaieusG
                                      Or eat more cookies (look at ThomThom). ๐Ÿ˜’
                                      Maybe both - but if you drink more beer, you will grow a red beard like Rich has (or a belly like me).
                                        dedmin
                                        ๐Ÿ˜† ๐Ÿ˜† ๐Ÿ˜†
                                        • troyhomeT
                                          troyhome
                                          thanks for this great plug!
                                          IOviz.com
                                          SU Pro 2024 PC
                                            This new tool QuadsFrom2Tris http://forums.sketchucation.com/viewtopic.php?p=315130#p315130 might help fix a few connected triangles into quads... rather than affect every preexisting quad in a surface by re-quadding it...
