    [Plugin] Quadrilateralizer v1.1 20110215
    28 Posts 14 Posters 37.3k Views 14 Watching
    • TIGT Online
      TIG (c) 2011
      All Rights Reserved.
      THIS SOFTWARE IS PROVIDED "AS IS" AND WITHOUT ANY EXPRESS OR IMPLIED
      WARRANTIES,INCLUDING,WITHOUT LIMITATION,THE IMPLIED WARRANTIES OF
      MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE.
      Script: Quadrilateralizer.rb
      Usage:
      Select faces. Note that other entity-types in the selection are ignored.
      Run 'Quadrilateralizer' from the 'Plugins' menu.
      If there are no faces in the selection there is an error-message, it exits.
      If all selected faces are already quads then you are asked if you want to
      split them further: 'Yes' to redivide selected quad faces or No' to abort.
      If the selected faces are not equivalent to 'all connected faces' then you
      are warned: 'Yes' to continue, 'No' to abort. It is recommended that all
      connected faces are processed together [treble-click a face to select all]
      to ensure that all connected faces become quadrilaterals; otherwise later
      processing of these non-quad faces could result in the connected quads
      being made into non-quads, or if all connected faces were selected the
      non-quads would split but the previously made quads will be split again -
      it could get messy - this might be what is required... but usually
      processing all connected at once is the best method.
      All selected faces are now split into quadrilaterals ['quads'].
      Note that any preexisting quads in the selection will also be split
      because splitting any adjacent non-quads will force these existing quads
      into non-quads anyway.
      UV texture mapping etc is kept.
      It is one step undo-able.
      The vertices of these quad faces can be adjusted with the Move tool...
      Donations: By PayPal.com to info @ revitrev.org PayPalButton
      Version:
      1.0 20110214 First Release.
      1.1 20110215 More info and percentage progress reported in Status Bar.
      Put into the Plugins folder and restart Sketchup...
        OK, first to download so first to thank. I know why Pete asked for it...
        πŸ‘
        Will it move vertices slightly to create quads from non co-planar tris for instance (or does it only subdivide)?
        • soloS Offline
          Sweet!! cannot wait to give it a run.
          Thanks a bunch.
            Some quads are created from tris in a way that they have co-linear edges. This may not be an issue in many apps but SDS2's smooth tool cannot handle these, Pete.
            TIG: still great tool, thanks!
            • TIGT Online
              Most quads will not have co-linear sides [although thin slivers of triangles do approach co-linearity] - but those that do you can manually Move a vertex as desired.
              The subdivision can produce unoptimized quads anyway that would benefit from some adjustments to some vertex locations...
              This is only v1.0, I only starting thinking about writing it a couple of hours ago πŸ˜’
              Any feedback or suggestions on improvements welcomed...
                chloesdad
                Thank you very much TIG.
                • TIGT Online
                  I can envisage another tool to optimize selected coplanar quads...
                  It tests a faces for their vertices' 'concave-ness'/co-linearity and adjusts the concave/linear vertex location until it is just convex... I suspect this might involve a lot of tail-chasing as one faces concave vertex could be its neighbor's convex vertex πŸ˜’
                  Alternatively if any of the Quadrilateralized faces have co-linear or concave vertices select all and Quadrilateralize them a second time - that should fix them - although the mesh will then be much finer πŸ˜’ BUT there's no such thing as as a free lunch...Capture.PNG
                  • CAntonisC Offline
                    CAntonis
                    Thanks so much TIG!
                    One question though: Is this gonna help exporting a model to other modelers with greater detail, is it just because quad faced geometry is better or both?
                    Downloaded already and I ll be checking for updates!!!!
                    Again THANKS A BOUNCH!
                    • Didier BurD Offline
                      Didier Bur
                      Hi TIG,
                      When translating into french, I came across this (line 82):
                      return nil if UI.messagebox("Quadrilateralizer;\n\nThe Selected Faces are NOT\nALL of the Connected Faces.\nDo you want to Continue ?",MB_YESNO)==7
                      Isn't this message confusing or wrong ?
                      DB
                      • TIGT Online
                        @didier bur said:
                        Hi TIG,
                        The selected-faces are not ALL of the connected-faces.
                        Do you want to continue?
                        πŸ˜•
                        Les choisir-faces ne sont pas tous les relier-faces.
                        Voulez-vous continuer ?
                          Didier Bur
                          Les faces choisies ne font PAS TOUTES partie des faces connectΓ©es
                          DB
                          • TIGT Online
                            I couldn't have put it better myself!
                            Je n'aurais pas pu mieux dire moi-mΓͺme! πŸ˜„
                            • KrisidiousK Offline
                              Krisidious
                              you Rock Tig...
                              By: Kristoff Rand
                                Ben Ritter
                                TIG, thank you.
                                • EarthMoverE Offline
                                  EarthMover
                                  πŸ‘ πŸ‘ Thanks bro!
                                  Content Creator at Skapeup
                                    Thanks TIG....any chance of a progress bar?
                                    • TIGT Online
                                      Here's v1.1 http://forums.sketchucation.com/viewtopic.php?p=309120#p309120
                                      More info and percentage progress now reported in the Status Bar.
                                        That was quick 😲
                                        • TIGT Online
                                          Sorry it took so long I was at the corner-shop buying some milk when you posted 😲 πŸ˜‰
                                            Now that you're around and idle, how about this πŸ˜‰
