    [Plugin] Quadrilateralizer v1.1 20110215
    28 Posts 14 Posters 37.9k Views 14 Watching
      @gaieus said:
      Some quads are created from tris in a way that they have co-linear edges. This may not be an issue in many apps but SDS2's smooth tool cannot handle these, Pete.
      TIG: still great tool, thanks!
      Most quads will not have co-linear sides [although thin slivers of triangles do approach co-linearity] - but those that do you can manually Move a vertex as desired.
      The subdivision can produce unoptimized quads anyway that would benefit from some adjustments to some vertex locations...
      This is only v1.0, I only starting thinking about writing it a couple of hours ago πŸ˜’
      Any feedback or suggestions on improvements welcomed...
      • C
        chloesdad
        Thank you very much TIG.
          I can envisage another tool to optimize selected coplanar quads...
          It tests a faces for their vertices' 'concave-ness'/co-linearity and adjusts the concave/linear vertex location until it is just convex... I suspect this might involve a lot of tail-chasing as one faces concave vertex could be its neighbor's convex vertex πŸ˜’
          Alternatively if any of the Quadrilateralized faces have co-linear or concave vertices select all and Quadrilateralize them a second time - that should fix them - although the mesh will then be much finer πŸ˜’ BUT there's no such thing as as a free lunch...Capture.PNG
          • CAntonisC
            CAntonis
            Thanks so much TIG!
            One question though: Is this gonna help exporting a model to other modelers with greater detail, is it just because quad faced geometry is better or both?
            Downloaded already and I ll be checking for updates!!!!
            Again THANKS A BOUNCH!
            • Didier BurD
              Didier Bur
              Hi TIG,
              When translating into french, I came across this (line 82):
              return nil if UI.messagebox("Quadrilateralizer;\n\nThe Selected Faces are NOT\nALL of the Connected Faces.\nDo you want to Continue ?",MB_YESNO)==7
              Isn't this message confusing or wrong ?
              DB
                @didier bur said:
                Hi TIG,
                The selected-faces are not ALL of the connected-faces.
                Do you want to continue?
                πŸ˜•
                Les choisir-faces ne sont pas tous les relier-faces.
                Voulez-vous continuer ?
                • Didier BurD
                  Didier Bur
                  Les faces choisies ne font PAS TOUTES partie des faces connectΓ©es
                  DB
                    I couldn't have put it better myself!
                    Je n'aurais pas pu mieux dire moi-mΓͺme! πŸ˜„
                    • KrisidiousK
                      Krisidious
                      you Rock Tig...
                      By: Kristoff Rand
                      • B
                        Ben Ritter
                        TIG, thank you.
                        • EarthMoverE
                          EarthMover
                          πŸ‘ πŸ‘ Thanks bro!
                          Content Creator at Skapeup
                            Thanks TIG....any chance of a progress bar?
                              Here's v1.1 http://forums.sketchucation.com/viewtopic.php?p=309120#p309120
                              More info and percentage progress now reported in the Status Bar.
                                That was quick 😲
                                  Sorry it took so long I was at the corner-shop buying some milk when you posted 😲 πŸ˜‰
                                    Now that you're around and idle, how about this πŸ˜‰
                                    • GaieusG
                                      Thanks TIG. The more I think about this plugin, the more I like it. It can have so many areas to use.
                                        dedmin
                                        So, if I drink more milk maybe I can start writing wonderful plugins as You do?
                                        πŸ˜’ β˜€
                                        • GaieusG
                                          Or eat more cookies (look at ThomThom). πŸ˜’
                                          Maybe both - but if you drink more beer, you will grow a red beard like Rich has (or a belly like me).
                                            dedmin
                                            πŸ˜† πŸ˜† πŸ˜†
