    [Plugin] Quadrilateralizer v1.1 20110215
    28 Posts 14 Posters 36.2k Views 14 Watching
      TIG (c) 2011
      All Rights Reserved.
      THIS SOFTWARE IS PROVIDED "AS IS" AND WITHOUT ANY EXPRESS OR IMPLIED
      WARRANTIES,INCLUDING,WITHOUT LIMITATION,THE IMPLIED WARRANTIES OF
      MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE.
      Script: Quadrilateralizer.rb
      Usage:
      Select faces. Note that other entity-types in the selection are ignored.
      Run 'Quadrilateralizer' from the 'Plugins' menu.
      If there are no faces in the selection there is an error-message, it exits.
      If all selected faces are already quads then you are asked if you want to
      split them further: 'Yes' to redivide selected quad faces or No' to abort.
      If the selected faces are not equivalent to 'all connected faces' then you
      are warned: 'Yes' to continue, 'No' to abort. It is recommended that all
      connected faces are processed together [treble-click a face to select all]
      to ensure that all connected faces become quadrilaterals; otherwise later
      processing of these non-quad faces could result in the connected quads
      being made into non-quads, or if all connected faces were selected the
      non-quads would split but the previously made quads will be split again -
      it could get messy - this might be what is required... but usually
      processing all connected at once is the best method.
      All selected faces are now split into quadrilaterals ['quads'].
      Note that any preexisting quads in the selection will also be split
      because splitting any adjacent non-quads will force these existing quads
      into non-quads anyway.
      UV texture mapping etc is kept.
      It is one step undo-able.
      The vertices of these quad faces can be adjusted with the Move tool...
      Donations: By PayPal.com to info @ revitrev.org PayPalButton
      Version:
      1.0 20110214 First Release.
      1.1 20110215 More info and percentage progress reported in Status Bar.
      Put into the Plugins folder and restart Sketchup...
        OK, first to download so first to thank. I know why Pete asked for it...
        πŸ‘
        Will it move vertices slightly to create quads from non co-planar tris for instance (or does it only subdivide)?
        • soloS Offline
          Sweet!! cannot wait to give it a run.
          Thanks a bunch.
            Some quads are created from tris in a way that they have co-linear edges. This may not be an issue in many apps but SDS2's smooth tool cannot handle these, Pete.
            TIG: still great tool, thanks!
              Most quads will not have co-linear sides [although thin slivers of triangles do approach co-linearity] - but those that do you can manually Move a vertex as desired.
              The subdivision can produce unoptimized quads anyway that would benefit from some adjustments to some vertex locations...
              This is only v1.0, I only starting thinking about writing it a couple of hours ago πŸ˜’
              Any feedback or suggestions on improvements welcomed...
                chloesdad
                Thank you very much TIG.
                  I can envisage another tool to optimize selected coplanar quads...
                  It tests a faces for their vertices' 'concave-ness'/co-linearity and adjusts the concave/linear vertex location until it is just convex... I suspect this might involve a lot of tail-chasing as one faces concave vertex could be its neighbor's convex vertex πŸ˜’
                  Alternatively if any of the Quadrilateralized faces have co-linear or concave vertices select all and Quadrilateralize them a second time - that should fix them - although the mesh will then be much finer πŸ˜’ BUT there's no such thing as as a free lunch...Capture.PNG
                  • CAntonisC Offline
                    CAntonis
                    Thanks so much TIG!
                    One question though: Is this gonna help exporting a model to other modelers with greater detail, is it just because quad faced geometry is better or both?
                    Downloaded already and I ll be checking for updates!!!!
                    Again THANKS A BOUNCH!
                    • Didier BurD Offline
                      Didier Bur
                      Hi TIG,
                      When translating into french, I came across this (line 82):
                      return nil if UI.messagebox("Quadrilateralizer;\n\nThe Selected Faces are NOT\nALL of the Connected Faces.\nDo you want to Continue ?",MB_YESNO)==7
                      Isn't this message confusing or wrong ?
                      DB
                        @didier bur said:
                        Hi TIG,
                        The selected-faces are not ALL of the connected-faces.
                        Do you want to continue?
                        πŸ˜•
                        Les choisir-faces ne sont pas tous les relier-faces.
                        Voulez-vous continuer ?
                          Didier Bur
                          Les faces choisies ne font PAS TOUTES partie des faces connectΓ©es
                          DB
                            I couldn't have put it better myself!
                            Je n'aurais pas pu mieux dire moi-mΓͺme! πŸ˜„
                            • KrisidiousK Offline
                              Krisidious
                              you Rock Tig...
                              By: Kristoff Rand
                                Ben Ritter
                                TIG, thank you.
                                • EarthMoverE Offline
                                  EarthMover
                                  πŸ‘ πŸ‘ Thanks bro!
                                  Content Creator at Skapeup
                                    Thanks TIG....any chance of a progress bar?
                                      Here's v1.1 http://forums.sketchucation.com/viewtopic.php?p=309120#p309120
                                      More info and percentage progress now reported in the Status Bar.
                                        That was quick 😲
                                          Sorry it took so long I was at the corner-shop buying some milk when you posted 😲 πŸ˜‰
                                            Now that you're around and idle, how about this πŸ˜‰
