    [Plugin] CleanUp
    974 Posts 217 Posters 861.2k Views 217 Watching
      Webdialog Errors
      IE7 users should update TT_Lib2 to 2.5.1 which addresses IE7 error messages with the webdialogs.
      • bagateloB Offline
        bagatelo
        @thomthom said:
        @bagatelo said:
        Maybe we can run other older version of this fantastic plugin as well. Is it possible? Remeber: I love You!!!
        Why?
        Because of the window popping up?
        The old version has some flaws which is fixed in V3.
        Because the possibility to clean unneeded edges.
          @bagatelo said:
          @thomthom said:
          Why?
          That exists in CleanUp3.
          • bagateloB Offline
            bagatelo
            @thomthom said:
            @bagatelo said:
            @thomthom said:
            Why?
            YES! I know it. But the problem is keyboard shortcuts. Maybe you can make possible to assign shortcuts for every option in the menu. The possible for set shortcut for unneeded edges and Merge identical materials can be great. Thank you.
              DIEGO-RODRIGUEZ
              as usual. excellent work. very professional.
              thank you very much
                @bagatelo said:
                @thomthom said:
                @bagatelo said:
                @thomthom said:
                Why?
                That's an interesting idea.
                  Version 3.1.0
                  • Added menu item for repeating last cleanup. (scope not remembered.)
                  • Added menus for each cleanup sub-routine.
                    dedmin
                    • CAntonisC Offline
                      CAntonis
                      This is one of the best plugs ever! Great job and much appreciated!
                      Thank you!
                      • plot-parisP Offline
                        plot-paris
                        Thomthom, thats really perfect now! you made me a happy man!
                          rv1974
                          http://www.youtube.com/watch?v=RyUf7r_9yNs&feature=player_embedded
                          Is this you Thom?
                          Never thought the chill boosts the productivity so much 🙂
                              Seems that I introduced a bug in 3.1.0 - the scope isn't properly selected. 😞
                              Fixing...
                                Version 3.1.1
                                • Fixed bug where the current scope wasn't correctly pre-selected
                                • bagateloB Offline
                                  bagatelo
                                  Great. I loved. But Now sometimes I have code error:
                                  C;/Program Files/Google/Google SketchUp 7/Plugins/tt_cleanup.rb;952;in `remove_materials'
                                  C;/Program Files/Google/Google SketchUp 7/Plugins/tt_cleanup.rb;915;in `merge_similar_materials'
                                  C;/Program Files/Google/Google SketchUp 7/Plugins/tt_cleanup.rb;477;in `cleanup!'
                                  C;/Program Files/Google/Google SketchUp 7/Plugins/tt_cleanup.rb;420;in `show_cleanup_ui'
                                  C;/Program Files/Google/Google SketchUp 7/Plugins/tt_cleanup.rb;419;in `call'
                                  C;/Program Files/Google/Google SketchUp 7/Plugins/TT_Lib2/inputbox.rb;160;in `initialize'
                                  C;/Program Files/Google/Google SketchUp 7/Plugins/TT_Lib2/inputbox.rb;155;in `call'
                                  C;/Program Files/Google/Google SketchUp 7/Plugins/TT_Lib2/inputbox.rb;143;in `close'
                                  C;/Program Files/Google/Google SketchUp 7/Plugins/TT_Lib2/inputbox.rb;143;in `initialize'
                                  C;/Program Files/Google/Google SketchUp 7/Plugins/TT_Lib2/inputbox.rb;131;in `call'
                                  What is happening? Thanks thomthom for your efforts.
                                    Can you reproduce that in 3.1.1? (if so can you repost the message so the line numbers match with the latest version?)
                                    Also, it seems that part of that error message is missing...
                                      And you mention it occurs some times - got a sample model where it always occurs?
                                        Version 3.1.2
                                        • Fixed missing operation wrappers.
                                        • Fixed merge materials.
                                        Recommended update!
                                        • jim smithJ Offline
                                          jim smith
                                          Thanks for the update TT - I use this a lot! Excellent plugin, excellent improvements. 👍
                                          "Out of clutter find simplicity,
                                          from discord find harmony,
                                          In the middle of difficulty lies opportunity"
                                          Albert Einstein
                                          • bagateloB Offline
                                            bagatelo
                                            I have updated to version 3.1.1 and no error show me, at this time.
                                            • 48
                                            • 49
                                            • 7 / 49
