    [Tutorial > Texturing] Texturing an arch - #2
    87 Posts 18 Posters 34.2k Views 18 Watching
      Now twisted AND bent. 😲
      (This definitely needs pre-triangulation as it would be triangulated by the twist anyway)
      Incredible!
      UV.skp
      • massimoM Offline
        massimo Moderator
        So Gai now we are waiting for a model of this... πŸ˜†
          Ah, Bernini... I have not always liked that deep Baroque but nowadays I am fine with it...
          πŸ˜„
          • massimoM Offline
            massimo Moderator
            Yeah, I always preferred Borromini (who also worked a bit at that baldaquin anyway). πŸ˜‰
              I pitty the brick builder. πŸ˜„
                dominion
                Sorry to be dumb but how do you subdivide? is it a plugin?
                  I just copied the bottom edges along with a linear array (Ctrl+ )
                    dominion
                    er if i do that it creates faces for each section of the texture, your 2nd image shows it as one face and your first shows dotted lines for the divide my has sild edges?
                      Yes, I softened those edges so that when I turn off hidden geometry (which you can see in the first image as dotted), I can select the whole surface as one. If you select all after the array operation and right click > soften edges, check the "soften coplanar edges" box at the bottom right of the dialog.
                        dominion
                        Ah I get it thanks
                          So how is it going? Let's see some interesting results (I always make boring vaults only although now there is also a sugar cane I made this way)
                            dominion
                            hohum not working, done it all but when i click restore uv it does nothing at all 😞
                              Have you got the original (not-yet-bent) shape?
                                dominion
                                yea got it fine looks exactly as in your tut
                                  You mean it looks like the one in the tut before you make the bend and the UV restore or you mean that you could do it finally?
                                    dominion
                                    i can do the bend its just the uv restore that does not work
                                      If you open the Ruby Console - does it give you an error?
                                      If not, any chance you can do a video capture`?
                                        And any chance you can share the file, too? Beforeit's bent...
                                          +1
                                          • O Offline
                                            Odlanier
                                            This is an old issue:
                                            I read long time ago about the way to change the "avatar" (male figure in the SU default template).
                                            I barley remember that you can use your own pic for this.
                                            Q. After I build an avatar of myself, how can I make it face the camera all the time?
                                            Thanks for your help.
                                            Odlanier
                                            We have only one Earth, Our children maybe just a half, theirs perhaps none; do something for our planet.
                                            • 5 / 5
