    Alpha Channel, Trees, Vray - HELP
    renderpluginsextensions
    30 Posts 13 Posters 23.6k Views 13 Watching
    • kaluK Offline
      kalu
      Thank you ThomThom, aweomse your plugin, I have that problem when Import 3DS trees...
      This is the result:
      THE ONLY DIFFERENCE BETWEEN FICTION AND REALITY IS WHEN FICTION HAS TO BE CREDIBLE
        πŸ‘ Nice
        Where's that top tree from?
        • kaluK Offline
          kalu
          Is from ASGVIS, I need to use for a Tutorial that I work right now.
            teris
            i've tried it... but it didn't work out... i wonder what part i've missed...
              teris
              i've tried it using vray 1.48.xx,,, it works... just use the color texture as transparency option... but when i tried it using vray 6 with the explanation above,,, it still didn't work... i still wonder... help me out guys... thanks...
              • bac9-flclB Offline
                bac9-flcl
                Isn't there a way to utilize normal transparency types supported in SketchUp? I'm talking about alpha channels in .png/.tga/etc textures.
                I have a vast library of transparent materials, but all of them have transparency data inside, not as a separate file - and it is very inconvenient for me to make separate images with alpha, just to meet weird V-Ray standards. Is it possible (in V-Ray material editor) to assign alpha channel of e.g. RGBA .tga texture to be used as transparency map?
                • andybotA Offline
                  andybot
                  There is a check box in the material diffuse layer to "use color texture as transparency" for just such files.
                    ali64risk
                    @devran said:
                    rightclick on the alpha channel and save as a new picture... thats all
                    I tried but I could not...
                    please someone explain more?
                    (right clicking on alpha channel in Photoshop gave me 2 options: "duplicate channel" and "save channel"... where I can save alpha channel as png?)
                    • N Offline
                      nomeradona
                      ali.. what they were talking was the workflow for the old version. the new vray version, dont worry, just follow what andybot said.
                        ali64risk
                        thank you
                        yes it is working
                        • 2 / 2
