    Alpha Channel, Trees, Vray - HELP
    renderpluginsextensions
    30 Posts 13 Posters 23.9k Views 13 Watching
      How did you get these trees? What the images used in them is needed is a clip map (if you can get the original png files, you can create these clips easily in PS).
        CurryPork
        Here are the trees. I got them either from here, the internet or the warehouse. But my point is how can you extract the PNG or the alpha channel from these sketchup files.
        2D tree
        3D tree
          Right click the material in the SU material editor, choose "Extract Texture Image". Save the file to disk and open in your image editor of choice to extract the alpha channel.
            CurryPork
            Thanks Thom, I tried right clicking everywhere and cannot find that feature.
              Sorry. Be in the list of materials. Not in edit mode. (The "Select" tab next to "Edit")
                CurryPork
                Thanks Thom. I learned something new.
                I got the alpha channel out of the tree now. Do you know how to make it work in Vray?
                I assign a PNG as a bitmap in the COLOR slot in DIFFUSE and the alpha layer as a bitmap in the TRANSPARENCY slot in the DIFFUSE. But when I render in Vray it's not working... any suggestion?
                  CurryPork
                  OK, I got it to work... thanks.
                    chango70
                    So how did you get it to work?
                      CurryPork
                      I have it working for the 2D tree and this works for the 3D tree as well. So, just extract the alpha channel from the original texture as Thom described.
                      In VRAY, apply the original texture in the Color slot and the alpha in the transparent slot. Render and this solves it.
                      Thanks Thom.
                        chango70
                        Thx I just tried it myself and it works.
                          devran
                          Hi Fellowcombatants listen!!! First You download the tree from warehouse... click on the component open it then rightclick and save the png. then open in Photoshop and rightclick on the icon in the layers menu and choose choose pixels... change to channels menu and create a alpha channel... this channel is saveable as a new picture... rightclick on the alpha channel and save as a new picture... thats all.... ( sorry for all non Photoshop users)... ciao devran
                            tvicari
                            You guys rock . . thanks for the tips, works great I have been looking for this solution for a long time. Thanks for making an effort and sharing knowledge.
                              jdcarling
                              Hey all,
                              I read this post and have figured out how to create the alpha channel in photoshop for a tree, but cannot find the location to insert the png properly in the material editor - diffuse - transparency. I clicked the lower case, then switched the left panel to TEXBITMAP but coudl not insert the alpha channel PNG anywhere... any tips.
                                jdcarling
                                Hey All,
                                  In the Transparency slot of the diffuse layer - add a TexBitmp:
                                  • kaluK Offline
                                    kalu
                                    Hi thomthom:
                                    I have this dilema, I read the post all perfect. I try to mimic the results and I want to know what I am doing wrong. I attach the tree and the images for the render. Please let me know what I am doing wrong. I use Sketchup Pro 8 and Vray 1.48.89. Some of the leaves show as a rectangular green. I have no Idea why.
                                    Here is the link to the 3D model of the tree:
                                    https://rcpt.yousendit.com/1023169415/e1236da1e739047eed35fa1248da71be
                                    Thank you!!!!
                                    THE ONLY DIFFERENCE BETWEEN FICTION AND REALITY IS WHEN FICTION HAS TO BE CREDIBLE
                                      That's because you didn't map the backside of the faces. You can even see that in SketchUp.
                                      I'm guessing you imported this from another 3d format?
                                      Because of that you lost the backside information. Many other 3d apps doesn't display anything on the backside of faces. You have to explicitly enable it.
                                      To quickly transfer UV mapping from one side to another, use this plugin: http://forums.sketchucation.com/viewtopic.php?f=323&t=18992&p=155759#p155759
                                      • kaluK Offline
                                        kalu
                                        Thank you ThomThom, aweomse your plugin, I have that problem when Import 3DS trees...
                                        This is the result:
                                          πŸ‘ Nice
                                          Where's that top tree from?
                                          • kaluK Offline
                                            kalu
                                            Is from ASGVIS, I need to use for a Tutorial that I work right now.
