    Alpha Channel, Trees, Vray - HELP
    renderpluginsextensions
    30 Posts 13 Posters 24.8k Views 13 Watching
    • C
      chango70
      So how did you get it to work?
      • C
        CurryPork
        I have it working for the 2D tree and this works for the 3D tree as well. So, just extract the alpha channel from the original texture as Thom described.
        In VRAY, apply the original texture in the Color slot and the alpha in the transparent slot. Render and this solves it.
        Thanks Thom.
        • C
          chango70
          Thx I just tried it myself and it works.
            devran
            Hi Fellowcombatants listen!!! First You download the tree from warehouse... click on the component open it then rightclick and save the png. then open in Photoshop and rightclick on the icon in the layers menu and choose choose pixels... change to channels menu and create a alpha channel... this channel is saveable as a new picture... rightclick on the alpha channel and save as a new picture... thats all.... ( sorry for all non Photoshop users)... ciao devran
            • T
              tvicari
              You guys rock . . thanks for the tips, works great I have been looking for this solution for a long time. Thanks for making an effort and sharing knowledge.
                jdcarling
                Hey all,
                I read this post and have figured out how to create the alpha channel in photoshop for a tree, but cannot find the location to insert the png properly in the material editor - diffuse - transparency. I clicked the lower case, then switched the left panel to TEXBITMAP but coudl not insert the alpha channel PNG anywhere... any tips.
                  jdcarling
                  Hey All,
                    In the Transparency slot of the diffuse layer - add a TexBitmp:
                    • kaluK
                      kalu
                      Hi thomthom:
                      I have this dilema, I read the post all perfect. I try to mimic the results and I want to know what I am doing wrong. I attach the tree and the images for the render. Please let me know what I am doing wrong. I use Sketchup Pro 8 and Vray 1.48.89. Some of the leaves show as a rectangular green. I have no Idea why.
                      Here is the link to the 3D model of the tree:
                      https://rcpt.yousendit.com/1023169415/e1236da1e739047eed35fa1248da71be
                      Thank you!!!!
                      THE ONLY DIFFERENCE BETWEEN FICTION AND REALITY IS WHEN FICTION HAS TO BE CREDIBLE
                        That's because you didn't map the backside of the faces. You can even see that in SketchUp.
                        I'm guessing you imported this from another 3d format?
                        Because of that you lost the backside information. Many other 3d apps doesn't display anything on the backside of faces. You have to explicitly enable it.
                        To quickly transfer UV mapping from one side to another, use this plugin: http://forums.sketchucation.com/viewtopic.php?f=323&t=18992&p=155759#p155759
                        • kaluK
                          kalu
                          Thank you ThomThom, aweomse your plugin, I have that problem when Import 3DS trees...
                          This is the result:
                            πŸ‘ Nice
                            Where's that top tree from?
                            • kaluK
                              kalu
                              Is from ASGVIS, I need to use for a Tutorial that I work right now.
                              • T
                                teris
                                i've tried it... but it didn't work out... i wonder what part i've missed...
                                • T
                                  teris
                                  i've tried it using vray 1.48.xx,,, it works... just use the color texture as transparency option... but when i tried it using vray 6 with the explanation above,,, it still didn't work... i still wonder... help me out guys... thanks...
                                  • bac9-flclB
                                    bac9-flcl
                                    Isn't there a way to utilize normal transparency types supported in SketchUp? I'm talking about alpha channels in .png/.tga/etc textures.
                                    I have a vast library of transparent materials, but all of them have transparency data inside, not as a separate file - and it is very inconvenient for me to make separate images with alpha, just to meet weird V-Ray standards. Is it possible (in V-Ray material editor) to assign alpha channel of e.g. RGBA .tga texture to be used as transparency map?
                                    • andybotA
                                      andybot
                                      There is a check box in the material diffuse layer to "use color texture as transparency" for just such files.
                                        ali64risk
                                        I tried but I could not...
                                        please someone explain more?
                                        (right clicking on alpha channel in Photoshop gave me 2 options: "duplicate channel" and "save channel"... where I can save alpha channel as png?)
                                        • N
                                          nomeradona
                                          ali.. what they were talking was the workflow for the old version. the new vray version, dont worry, just follow what andybot said.
                                            ali64risk
                                            thank you
                                            yes it is working
