    Alpha Channel, Trees, Vray - HELP
    renderpluginsextensions
    30 Posts 13 Posters 24.3k Views 13 Watching
    • C
      CurryPork
      Thanks Thom, I tried right clicking everywhere and cannot find that feature.
        Sorry. Be in the list of materials. Not in edit mode. (The "Select" tab next to "Edit")
        • C
          CurryPork
          Thanks Thom. I learned something new.
          I got the alpha channel out of the tree now. Do you know how to make it work in Vray?
          I assign a PNG as a bitmap in the COLOR slot in DIFFUSE and the alpha layer as a bitmap in the TRANSPARENCY slot in the DIFFUSE. But when I render in Vray it's not working... any suggestion?
          • C
            CurryPork
            OK, I got it to work... thanks.
            • C
              chango70
              So how did you get it to work?
              • C
                CurryPork
                I have it working for the 2D tree and this works for the 3D tree as well. So, just extract the alpha channel from the original texture as Thom described.
                In VRAY, apply the original texture in the Color slot and the alpha in the transparent slot. Render and this solves it.
                Thanks Thom.
                • C
                  chango70
                  Thx I just tried it myself and it works.
                    devran
                    Hi Fellowcombatants listen!!! First You download the tree from warehouse... click on the component open it then rightclick and save the png. then open in Photoshop and rightclick on the icon in the layers menu and choose choose pixels... change to channels menu and create a alpha channel... this channel is saveable as a new picture... rightclick on the alpha channel and save as a new picture... thats all.... ( sorry for all non Photoshop users)... ciao devran
                    • T
                      tvicari
                      You guys rock . . thanks for the tips, works great I have been looking for this solution for a long time. Thanks for making an effort and sharing knowledge.
                        jdcarling
                        Hey all,
                        I read this post and have figured out how to create the alpha channel in photoshop for a tree, but cannot find the location to insert the png properly in the material editor - diffuse - transparency. I clicked the lower case, then switched the left panel to TEXBITMAP but coudl not insert the alpha channel PNG anywhere... any tips.
                          jdcarling
                          Hey All,
                            In the Transparency slot of the diffuse layer - add a TexBitmp:
                            • kaluK
                              kalu
                              Hi thomthom:
                              I have this dilema, I read the post all perfect. I try to mimic the results and I want to know what I am doing wrong. I attach the tree and the images for the render. Please let me know what I am doing wrong. I use Sketchup Pro 8 and Vray 1.48.89. Some of the leaves show as a rectangular green. I have no Idea why.
                              Here is the link to the 3D model of the tree:
                              https://rcpt.yousendit.com/1023169415/e1236da1e739047eed35fa1248da71be
                              Thank you!!!!
                              THE ONLY DIFFERENCE BETWEEN FICTION AND REALITY IS WHEN FICTION HAS TO BE CREDIBLE
                                That's because you didn't map the backside of the faces. You can even see that in SketchUp.
                                I'm guessing you imported this from another 3d format?
                                Because of that you lost the backside information. Many other 3d apps doesn't display anything on the backside of faces. You have to explicitly enable it.
                                To quickly transfer UV mapping from one side to another, use this plugin: http://forums.sketchucation.com/viewtopic.php?f=323&t=18992&p=155759#p155759
                                • kaluK
                                  kalu
                                  Thank you ThomThom, aweomse your plugin, I have that problem when Import 3DS trees...
                                  This is the result:
                                    πŸ‘ Nice
                                    Where's that top tree from?
                                    • kaluK
                                      kalu
                                      Is from ASGVIS, I need to use for a Tutorial that I work right now.
                                      • T
                                        teris
                                        i've tried it... but it didn't work out... i wonder what part i've missed...
                                        • T
                                          teris
                                          i've tried it using vray 1.48.xx,,, it works... just use the color texture as transparency option... but when i tried it using vray 6 with the explanation above,,, it still didn't work... i still wonder... help me out guys... thanks...
                                          • bac9-flclB
                                            bac9-flcl
                                            Isn't there a way to utilize normal transparency types supported in SketchUp? I'm talking about alpha channels in .png/.tga/etc textures.
                                            I have a vast library of transparent materials, but all of them have transparency data inside, not as a separate file - and it is very inconvenient for me to make separate images with alpha, just to meet weird V-Ray standards. Is it possible (in V-Ray material editor) to assign alpha channel of e.g. RGBA .tga texture to be used as transparency map?
