    [Plugin] FredoTools::CurviShear 1.5a - 25 Aug 11 (ramps)
    67 Posts 41 Posters 177.9k Views 41 Watching
    • G
      grim
      fredo
      yes i seem to have a problem see image attached , with a single arc it works fine, with a double arc and weld plugin used i get a mess
      regerds grim
      SU8 curvishear problem
      • fredo6F
        @grim said:
        fredo
        regerds grim
        Could you post the skp file so that I have a look
          rv1974
          Hi fredo!
          Please take a look at this:
          http://www.scriptspot.com/3ds-max/scripts/ant-stitcher-fast-and-easy-way-to-connect-two-meshes-in-3ds-max
          If only you could add a similar feature it'd become a mega hit!
            arjunmax09
            I'm trying to make a ramp using curvishear and curviloft but not getting the desired result. I've attached a video of what exactly happens during the process
            trying to make Ramp.rar
            when you fail at something....you haven't really failed...you've found one way the thing will not work out
            • jeff hammondJ
              arjun,
              try using the 3rd icon in curviloft.. skinning of shapes
                arjunmax09
                arjun,
                i tried using that but nothing happens..can you post a video or some screenshots?? I've uploaded the model btw..
                rr5 low.skp
                  Daniel S
                  @arjunmax09 said:
                  arjun,
                  Works for me...
                  Like Jeff said.. try using the 3rd icon... not the first one:
                  Here I attach the result:
                  rr5 low.skp
                  Daniel S
                    arjunmax09
                    @daniel s said:
                    Works for me...
                    [attachment=1:1596wm15]<!-- ia1 -->skin.jpg<!-- ia1 -->[/attachment:1596wm15]
                    Daniel S
                    Daniel...i used the same button for making the ramp...i select all the edges but nothing happens..Please upload screenshots or a video of how you actually make the ramp...I'm using SU 8 Pro..??
                      Daniel S
                      Just select the ramp and click the button. A small video showing how the skinning of the ramp is made:
                      I´m using SU8 Pro too.
                      Do you have the latests versions of Curviloft and LibFredo6?
                      For checking the latest version of curviloft go to "Tools>Fredo6 Collection>Curviloft>About..." should say Curviloft v1.0c.
                      For checking the latest version of LibFredo6 go to "Window>LibFredo6 Settings>About..." should say LibFredo6 v3.5c.
                      If you don´t have that versions you can download them from here: http://forums.sketchucation.com/viewtopic.php?f=323&t=28586
                      If you have the correct ones, try to make the ramp with the ruby console open (go to Window>Ruby Console). Perhaps the ruby console shows an error that you can copy and paste here.
                      Daniel S
                        arjunmax09
                        I had the recent versions. I just checked the way you told. But I overwrote the files with freshly downloaded ones anyway. Eventually I was able to make the ramp that you made. That file had another ramp too. I can't make that one.. I've made a new file of that ramp and a video of what exactly happens. Please check and tell me what to do.
                        RAmp another try.rar
                          Daniel S
                          Here you have to use another plugin called weld.rb (you can download it at http://www.smustard.com/script/Weld)
                          I attach a video showing how to make it work and .skp files.
                          Daniel S
                          ramp new welded.skp
                          ramp new final.skp
                          ramp new video.wmv
                            arjunmax09
                            Thanks Daniel...I'm finally able to make the ramp 😄 .. But for selecting the linear edges along one axis for welding is there a faster way rather than selecting them one by one??
                              Daniel S
                              You can try with Fredo6´s Hoverselect plugin (http://forums.sketchucation.com/viewtopic.php?f=323&t=18916). But it´s not working for me. Perhaps is a SketchUp 8 issue.
                              Daniel S
                              • K
                                kathecasta
                                i'm following these same instructions, and it works at creating the ramp for me, so long as i don't click "reverse curve orientation" but i need it to be reversed!
                                When I try to skin it using the "reverse orientation" it doesn't create the top plane for the ramp, just the sides for some reason....
                                anyone have any idea why this is happening?
                                thanks!!
                                [attachment=0:36vg9dz6]<!-- ia0 -->skinning a ramp.gif<!-- ia0 -->[/attachment:36vg9dz6]
                                Daniel S
                                • G
                                  ghassan
                                  wow
                                  • ToboboT
                                    Tobobo
                                    I cant believe i havent found this till now. This would have saved hours of time.
                                    Thank you
                                    Toby
                                    Philippians 4:13
                                      deprezzar
                                      tanks Fredo!!!brilliant!!!
                                        ddtaylor
                                        thanks for sharing
                                        • keea1111K
                                          keea1111
                                          Can someone help me install this plug in? I am on Mac and I put the whole FredoTools folder in my plugins folder, but it is not active or even visible in SU? Much thanks, Keea
                                          KEEA
                                            mwm5053
                                            Great plugin but I'm doing something wrong here I'm sure. Coming up with the same results as grim earlier in this thread. Thanks for the help
                                            ramps.skp
                                            2011 iMac
                                            SU 2015 Pro, 2017 Make
                                            V2 Twilight
                                            macOS Sierra 10.12.5
                                            • 3 / 4
