    [Plugin] FredoTools::CurviShear 1.5a - 25 Aug 11 (ramps)
    67 Posts 41 Posters 178.4k Views 41 Watching
      arjunmax09
      I'm trying to make a ramp using curvishear and curviloft but not getting the desired result. I've attached a video of what exactly happens during the process
      trying to make Ramp.rar
      when you fail at something....you haven't really failed...you've found one way the thing will not work out
      • jeff hammondJ
        arjun,
        try using the 3rd icon in curviloft.. skinning of shapes
          arjunmax09
          arjun,
          i tried using that but nothing happens..can you post a video or some screenshots?? I've uploaded the model btw..
          rr5 low.skp
            Daniel S
            @arjunmax09 said:
            arjun,
            Works for me...
            Like Jeff said.. try using the 3rd icon... not the first one:
            Here I attach the result:
            rr5 low.skp
            Daniel S
              arjunmax09
              @daniel s said:
              Works for me...
              [attachment=1:1596wm15]<!-- ia1 -->skin.jpg<!-- ia1 -->[/attachment:1596wm15]
              Daniel S
              Daniel...i used the same button for making the ramp...i select all the edges but nothing happens..Please upload screenshots or a video of how you actually make the ramp...I'm using SU 8 Pro..??
                Daniel S
                Just select the ramp and click the button. A small video showing how the skinning of the ramp is made:
                I´m using SU8 Pro too.
                Do you have the latests versions of Curviloft and LibFredo6?
                For checking the latest version of curviloft go to "Tools>Fredo6 Collection>Curviloft>About..." should say Curviloft v1.0c.
                For checking the latest version of LibFredo6 go to "Window>LibFredo6 Settings>About..." should say LibFredo6 v3.5c.
                If you don´t have that versions you can download them from here: http://forums.sketchucation.com/viewtopic.php?f=323&t=28586
                If you have the correct ones, try to make the ramp with the ruby console open (go to Window>Ruby Console). Perhaps the ruby console shows an error that you can copy and paste here.
                Daniel S
                  arjunmax09
                  I had the recent versions. I just checked the way you told. But I overwrote the files with freshly downloaded ones anyway. Eventually I was able to make the ramp that you made. That file had another ramp too. I can't make that one.. I've made a new file of that ramp and a video of what exactly happens. Please check and tell me what to do.
                  RAmp another try.rar
                    Daniel S
                    Here you have to use another plugin called weld.rb (you can download it at http://www.smustard.com/script/Weld)
                    I attach a video showing how to make it work and .skp files.
                    Daniel S
                    ramp new welded.skp
                    ramp new final.skp
                    ramp new video.wmv
                      arjunmax09
                      Thanks Daniel...I'm finally able to make the ramp 😄 .. But for selecting the linear edges along one axis for welding is there a faster way rather than selecting them one by one??
                        Daniel S
                        You can try with Fredo6´s Hoverselect plugin (http://forums.sketchucation.com/viewtopic.php?f=323&t=18916). But it´s not working for me. Perhaps is a SketchUp 8 issue.
                        Daniel S
                        • K
                          kathecasta
                          i'm following these same instructions, and it works at creating the ramp for me, so long as i don't click "reverse curve orientation" but i need it to be reversed!
                          When I try to skin it using the "reverse orientation" it doesn't create the top plane for the ramp, just the sides for some reason....
                          anyone have any idea why this is happening?
                          thanks!!
                          [attachment=0:36vg9dz6]<!-- ia0 -->skinning a ramp.gif<!-- ia0 -->[/attachment:36vg9dz6]
                          Daniel S
                          • G
                            ghassan
                            wow
                            • ToboboT
                              Tobobo
                              I cant believe i havent found this till now. This would have saved hours of time.
                              Thank you
                              Toby
                              Philippians 4:13
                                deprezzar
                                tanks Fredo!!!brilliant!!!
                                  ddtaylor
                                  thanks for sharing
                                  • keea1111K
                                    keea1111
                                    Can someone help me install this plug in? I am on Mac and I put the whole FredoTools folder in my plugins folder, but it is not active or even visible in SU? Much thanks, Keea
                                    KEEA
                                      mwm5053
                                      Great plugin but I'm doing something wrong here I'm sure. Coming up with the same results as grim earlier in this thread. Thanks for the help
                                      ramps.skp
                                      2011 iMac
                                      SU 2015 Pro, 2017 Make
                                      V2 Twilight
                                      macOS Sierra 10.12.5
                                      • T
                                        thanesuan
                                        thx a lot 😍
                                        • B
                                          Bertil
                                          cant get it to work on Mac
                                          • cottyC
                                            cotty
                                            We will need some more information to help you ...
                                            my SketchUp gallery
                                            • 3 / 4
