    [Plugin] FredoTools::CurviShear 1.5a - 25 Aug 11 (ramps)
    67 Posts 41 Posters 175.9k Views 41 Watching
    • jeff hammondJ
      arjun,
      try using the 3rd icon in curviloft.. skinning of shapes
        arjunmax09
        arjun,
        i tried using that but nothing happens..can you post a video or some screenshots?? I've uploaded the model btw..
        rr5 low.skp
        when you fail at something....you haven't really failed...you've found one way the thing will not work out
          Daniel S
          @arjunmax09 said:
          arjun,
          Works for me...
          Like Jeff said.. try using the 3rd icon... not the first one:
          Here I attach the result:
          rr5 low.skp
          Daniel S
            arjunmax09
            @daniel s said:
            Works for me...
            [attachment=1:1596wm15]<!-- ia1 -->skin.jpg<!-- ia1 -->[/attachment:1596wm15]
            Daniel S
            Daniel...i used the same button for making the ramp...i select all the edges but nothing happens..Please upload screenshots or a video of how you actually make the ramp...I'm using SU 8 Pro..??
              Daniel S
              Just select the ramp and click the button. A small video showing how the skinning of the ramp is made:
              I´m using SU8 Pro too.
              Do you have the latests versions of Curviloft and LibFredo6?
              For checking the latest version of curviloft go to "Tools>Fredo6 Collection>Curviloft>About..." should say Curviloft v1.0c.
              For checking the latest version of LibFredo6 go to "Window>LibFredo6 Settings>About..." should say LibFredo6 v3.5c.
              If you don´t have that versions you can download them from here: http://forums.sketchucation.com/viewtopic.php?f=323&t=28586
              If you have the correct ones, try to make the ramp with the ruby console open (go to Window>Ruby Console). Perhaps the ruby console shows an error that you can copy and paste here.
              Daniel S
                arjunmax09
                I had the recent versions. I just checked the way you told. But I overwrote the files with freshly downloaded ones anyway. Eventually I was able to make the ramp that you made. That file had another ramp too. I can't make that one.. I've made a new file of that ramp and a video of what exactly happens. Please check and tell me what to do.
                RAmp another try.rar
                  Daniel S
                  Here you have to use another plugin called weld.rb (you can download it at http://www.smustard.com/script/Weld)
                  I attach a video showing how to make it work and .skp files.
                  Daniel S
                  ramp new welded.skp
                  ramp new final.skp
                  ramp new video.wmv
                    arjunmax09
                    Thanks Daniel...I'm finally able to make the ramp 😄 .. But for selecting the linear edges along one axis for welding is there a faster way rather than selecting them one by one??
                      Daniel S
                      You can try with Fredo6´s Hoverselect plugin (http://forums.sketchucation.com/viewtopic.php?f=323&t=18916). But it´s not working for me. Perhaps is a SketchUp 8 issue.
                      Daniel S
                      • K
                        kathecasta
                        i'm following these same instructions, and it works at creating the ramp for me, so long as i don't click "reverse curve orientation" but i need it to be reversed!
                        When I try to skin it using the "reverse orientation" it doesn't create the top plane for the ramp, just the sides for some reason....
                        anyone have any idea why this is happening?
                        thanks!!
                        [attachment=0:36vg9dz6]<!-- ia0 -->skinning a ramp.gif<!-- ia0 -->[/attachment:36vg9dz6]
                        Daniel S
                        • G
                          ghassan
                          wow
                          • ToboboT
                            Tobobo
                            I cant believe i havent found this till now. This would have saved hours of time.
                            Thank you
                            Toby
                            Philippians 4:13
                              deprezzar
                              tanks Fredo!!!brilliant!!!
                                ddtaylor
                                thanks for sharing
                                • keea1111K
                                  keea1111
                                  Can someone help me install this plug in? I am on Mac and I put the whole FredoTools folder in my plugins folder, but it is not active or even visible in SU? Much thanks, Keea
                                  KEEA
                                    mwm5053
                                    Great plugin but I'm doing something wrong here I'm sure. Coming up with the same results as grim earlier in this thread. Thanks for the help
                                    ramps.skp
                                    2011 iMac
                                    SU 2015 Pro, 2017 Make
                                    V2 Twilight
                                    macOS Sierra 10.12.5
                                    • T
                                      thanesuan
                                      thx a lot 😍
                                      • B
                                        Bertil
                                        cant get it to work on Mac
                                        • cottyC
                                          cotty
                                          We will need some more information to help you ...
                                          my SketchUp gallery
                                          • W
                                            wishiyyl
                                            Looks awesome Fredo! Congrats yet again,
                                            • 3 / 4
