    More Characters
    Scheduled Pinned Locked Moved Organic Modelling
    71 Posts 25 Posters 35.8k Views 25 Watching
    • soloS Offline
      Playing again, a quick Odie. I used SDS2, FFD and TOS.
      http://img713.imageshack.us/img713/4935/odiesumodel.png
      http://img441.imageshack.us/img441/439/odier.png
      And for those proxy junkies, here is the basic form.
        liam887
        Awesome! I cant wait for SDS2!!! πŸ˜„ πŸ˜„ πŸ˜„ πŸ˜„ πŸ˜„ πŸ˜„
        VISIT MY ONLINE GALLERY
        • Rich O BrienR Online
          Excellent Pete πŸ‘
          For the render/line overlay, what was the studio setup?
          • soloS Offline
            I used Thea, posed in SU, exported the line image, opened same camera in Thea, added shadow catcher inifite plane, added HDRi image for reflection and white background (just a white .jpg I created in PS)
            Combines using 'multiply in PS...done.
              It was the White BG that i needed to know. Was the infinite plain a Diffused White? I really like that setup πŸ‘
              • soloS Offline
                It's Odie, from Garfield. πŸ’š
                http://www.designsbyjoy.net/DesignerTag/Animation/GooGifs/odie.gif
                  Very cool Toon Dog β˜€
                  Does the new SDS2 has a Points/faces/polygons counter visible on the screen?
                  • michaliszissiouM Offline
                    michaliszissiou
                    Nice dog.
                    Well done Pete,
                    Crits? Too many polys (but its OK here) much stretching on ears area, not the best for UVs.
                    • FrederikF Offline
                      Frederik
                      @solo said:
                      ...exported the line image...
                      I've never figured how to do this...
                      Please enlighten us mortals...
                      If I export a line image, the background will not be transparent...
                      Cheers
                      Kim Frederik
                        I presume he sets the blend mode to overlay in Photoshop? That's what i do anyway 😳
                        • soloS Offline
                          @michal, Poly count is no issue, I dont mind high poly models, I use a studio renderer so that hurdle is overcome. I used FFD on ears so yes I stretched the mesh.
                          @Frederick and Rich, I use a white background when rendering so exporting SU lines with a white background actually helps, in PS I use 'multiply' for blend, makes lines pop better.
                          • jeff hammondJ Offline
                            if you export a tiff or png which support transparency then click 'transparent background' in the export options.
                            [though i'm thinking this may be a mac only feature?]
                            • soloS Offline
                              Mac only... πŸ’š
                              See, there is a reason for owning a Mac. πŸ˜‰
                                What is it? You can it disappear into the BG
                                • FrederikF Offline
                                  Frederik
                                  Cheers, Pete...
                                  Just thought you had a trick in your sleeve to export the lines with transparent background, but blending using 'multiply' works just fine... πŸ‘
                                  Edit: I knew I had seen somewhere that you're able to get transparent background on a Mac...
                                  Well, well... thomthom's Export 2d with Alpha can make similar png's for us depending on Windows... πŸ˜›
                                  Unfortunately only the background will be transparent and not objects (not even if you paint them in the same color as the bg)...
                                  Cheers
                                  Kim Frederik
                                    michaliszissiou
                                    Multiply works fine, no need for transparent background.
                                    If you want transparent or semi transparent exports (lets say window glass etc) apply a strong color (pure magenta or green) then use it as mask in Ps. πŸ˜‰ A nice way for fake reflections in PP.
                                    • Chris FullmerC Offline
                                      @solo said:
                                      Mac only... πŸ’š
                                      Actually, that is no longer true. I think since they re-built the SU render engine in 7.1, PC has been able to export transparent png's.
                                      • FrederikF Offline
                                        Frederik
                                        Please elaborate and post some screen shots, Chris...
                                        Cause I sure can't find this in the option menu...
                                        I've tried both tif and png - and I don't see any option for selecting transparent background...
                                        Cheers
                                        Kim Frederik
                                          michaliszissiou
                                          Really Frederik, you don't need this much. You may need to mask some glass windows too, transparency doesn't help much there. Try to assign a pure green or magenta instead. Ps can do miracles this way. From a mac user anyway.
                                          • FrederikF Offline
                                            Frederik
                                            I know, michalis...
                                            I can make incredible things in post pro with PS for Win... πŸ˜„
                                            I also know about the work arounds, but if I can avoid them, it would be great...
                                            Chris F. states that transparent background is possible with SU for Win since ver. 7.1 but I can't find how/where, hence my question to Chris to post some screen shots...
                                            Well, well... I don't want to hijack this thread... πŸ˜„
                                            Cheers
                                            Kim Frederik
                                            • 1 / 4
