    Lock toolbars
    97 Posts 52 Posters 189.1k Views 52 Watching
      arjunmax09
      there are so many people on this forum who are awesome at making plugins... is there a possibility that one can make a plugin that just stops this haywire toolbars problem??
      when you fail at something....you haven't really failed...you've found one way the thing will not work out
        There's been a great number of brave attempts. Countless hours has been spent trying to hack the wretches thing - but all have returned bruised and scared. 😞
          arjunmax09
          i see.....but as the adidas line goes ..."IMPOSSIBLE IS NOTHING"... surely one genius is going to crack this problem... 😄
            putnik
            Until a couple of days ago installing a new script would mess up my toolbar locations, but at least I could re-arrange toolbars. Then I installed a couple of new ones, Extrusion Tools by TIG was one of them. And toolbars stopped sticking to where I wanted them to be! Really annoying!
            Strangely, the following from Halroach did help. Thanks!
            I have found a solution to the jumping toolbar problem!
            you must pack and cram each line of toolbars all the way to the end, until one of the toolbars get cropped, and then cram one more toolbar until one of the toolbars shifts to the next line automatically (sort of like an auto carriage return, or wordwrap). Now you can rearrange the toolbars on the third line, and they won't jump around! and you can replace the cropped toolbar from the second line to the third line too...
            PS This is not to say that TIG's Extrusion Tools was actually the culprit. I don't know what was.
            http://keshas.info
              Banaticus
              @remus said:
              ...except office 2007 😛
              Well, Microsoft has the official stance that things can't be removed from the Ribbon... but what they don't advertise is that you can hide things on the Ribbon and otherwise move stuff around (and add new things): http://msdn.microsoft.com/en-us/library/aa338202%28office.12%29.aspx#OfficeCustomizingRibbonUIforDevelopers_Customizing
              I would really really like to see the ability to do something like that, some sort of coding or CSS or XML or something that would allow us to upload a customized UI from a file. There are a few things that I like to use regularly that I just can't do with keyboard shortcuts, like the Dimension tool for callouts. I've set it to the "D" key, but then there's that layer-pane thing that sizes itself to cover the model and which "hides" (removes) everything on one side of it -- I love sliding that thing back and forth to quickly remove a wall.
                Joewoodworker
                I've had to arrange my toolbars for the third/fourth time today. Really annoying! I hope this will be fixed soon so one can lock your tools (menu top and left) in position so in the even of something happening you don't have to rearrange them afterwards.
                I think this has been mentioned (requested) in the wishlist before, hope it gets the attention it deserves.
                Hey Juju...
                Ummm, why don't you set the screen up as you'd like to see it everytime by turning it into a template? You set up everything, the units, the toolbars, the background get rid of Brice...everything you want. The next time you launch SU...presto! It's the way you want it.
                Joe,
                Twisted Knot Woodshop, "There's never been a classier joint"
                Maker of expensive firewood since 1968
                • halroachH Offline
                  halroach
                  An observation: 😞
                  1. There are plugins (most plugins) that load a toolbar automatically when first installed - and in most cases cause a lot of havoc - moving all the other toolbars all over the place.
                  2. On the other hand plugins that need to be initially "checked" ('view''toolbars''plugin name') or from ('preferences''extensions''plugin name') usually load somewhere in the middle of the screen that way they can be placed easily without messing everything up. I am not a coder, but maybe the initial placement of the toolbar is something that can be coded into each plugin... (i.e. make it load somewhere neutral at first load) or is it just by chance?
                  FlexTools - Super Quick Windows, Doors, Slats...
                  • xennonX Offline
                    xennon
                    This is incredible ... this thread alone has been going since Apr 2008 ... more than 30 months and STILL no resolution to the extremely annoying issue. Version 8 has now come out and guess what - I STILL DOES IT!!.
                    OMFG - What does it take for goooooooogle to pull their finger out and address this problem?
                    Someone else said that it's been around since at least v4 ... how long ago was that?!
                    Given the enormous resource base of gooooooogle, rivaled probably only by microsoft and yahoo in scale - how bad must their developers be if they can't solve this problem in the years that they've had to mess with it.
                    totally gob-smacked!
                    • jbacusJ Offline
                      jbacus
                      While it is clear that you're not impressed with our improvement (for those who've missed it so far, we're also discussing this on the SketchUp Help Forum), I'm curious to know if it had any impact on the workflow of other folks here on SCF?
                      The basic problem is that folks with more than a dozen Ruby extensions (I ran into someone yesterday who had over 200 of them installed at once... whoa!) are overwhelming our simple MFC toolbar implementation. It just can't scale to that kind of usage. To make things work better, we'll have to stop using Microsoft's toolbars and write our own. That isn't a trivial project, unfortunately– we could do it, but it would mean not doing something else.
                      As I said over at our forums, being civil will make it much more likely that discussion of the actual problems at hand will occur. I'm quite willing to discuss these sorts of issues, but find it easier to do when folks are being polite.
                      "...exaggerate the essential and leave the obvious unclear." --Vincent Van Gogh
                      John Bacus
                      jbacus@sketchup.com
                      • mitcorbM Offline
                        mitcorb
                        "but find it easier to do when folks are being polite."
                          Xennon,
                          The toolbar has been given a serious overhaul and is a step forward. Pointing out how lazy and bad they development team does nothing for your argument. Also posting in 2 forums the same diatribe without a compelling case in either is disappointing. Your free to air your opinions wherever you wish. I might add that we're a friendly bunch around here, as you know from your Golden Ratio thread, and help is always forthcoming. We also welcome new members and encourage open and honest discussions. I would take John's advice and show some tact when raising your concerns with SU. You'll find alot more people will support you!
                          Also I can vouch that the guys at Google SketchUp not only work hard but party even harder 😉
                          For those who are interested here's Xennon's post from the Google Help Forums...
                          That "remember" or restore option is a crock - it does nothing. It only works if you move toolbars around and change your mind (during that session) and want to go back to how they were when the prog started. If you install a new script/plugin, SU will ALWAYS start up after the install with messed up toolbars and pressing that restore button will do absolutely nothing.
                          This is a serious and extremely annoying BUG that's been there since waaaaaay back to version 4 at least. The best the developers have managed to come up with is a half-arsed save/restore option that fails more than it succeeds. Time to roll up the sleeves people and dig into the muck that must be the SU code and fix it once and for all.
                          Waddaya recon gooooooogle? ... you brave enough to have a go? (I for one think not)
                          • ToboboT Offline
                            Tobobo
                            I agree whilst it is frustrating that the toolbars move, i can imagine that Google have higher priorities in development such windows 7 and OS compatibility. Don’t forget Google bought SU to improve the openness of the 3D element of Good Earth. Plus it’s a minor thing in what is a massive programme. John's point about rubies is fair, I don’t have 200 ( 😮 ) but I know they can programme stuff based on that extreme amount.
                            So keep working boys and girls I can hold on a bit longer
                            PS. manners cost nothing so being nice to people is free.
                            Toby
                            Philippians 4:13
                              It's a major annoyance restoring ones workspace every time you get the Shuffle. A reliable workspace is essential to get a good workflow - so UI elements moving about is not a good thing.
                              • ToboboT Offline
                                Tobobo
                                A fair point my dear sir, and for a SU giant such as yourself I can imagine that you have many toolbars surrounding your most splendiferous creations.
                                Me however aint got much.
                                Toby
                                Philippians 4:13
                                  Actually, I keep my visible toolbars to a minimum in order to reduce the pain of the Shuffle and save screen estate. I keep at max one row of small-icon toolbars. But some of them are several very short ones - which still leaves me with several toolbars to clean up. I really feel sorry for those who need to clean up more toolbars.
                                    Jim
                                    I have taken to not using Toolbars, or having a very minimal number open. I wrote a custom WebDialog (or 2) to replace Toolbars. One dialog is a general toolbar replacement, the other toggles the normal Toolbars visible/not visible. The dialogs are pretty rough around the edges since I am the only one who uses them; but they do show what can be done and how the WebDialogs can (and will) be an effective alternative to the built-in Toolbars.
                                    There are a few other, similar plugins that are using webdialogs as toolbar alternatives.
                                    My dialogs: the short texts are buttons, too.
                                    http://i.min.us/iQWzW.png
                                    (moved post from another topic)
                                      rockstarkid76
                                      @remus said:
                                      Julian, why dont you get rid of all your toolbars and jsut use keyboard shortcuts? it takes a bit of getting used to but its a lot faster 🤓
                                      BUT NOT ALL COMMANDS HAVE SHORTCUTS!
                                        rockstarkid76
                                        @a4chitect said:
                                        there is a little trick to help you, once you are happy with your toolbar arrangement, close sketchup (the UI gets saved internally). anytime your screen gets resized, or messed up, or your toolbars change - don't close sketchup, open another instance of sketchup - this one opens with the original UI. then close both windows but make sure that you close the clean and tidy @last 😄
                                        this way your clean UI gets saved as last overwriting the messy one (since all instances of sketchup share one UI setting)
                                        GREAT!!! THANKS
                                          You can set up your own shortcuts from Window > Preferences > Shortcuts
                                          (p.s. Please don't use all caps when writing a post. It's considered bad forum manner. If anything, use all lower. Makes things much easier to read and it doesn't make you look like you are yelling.)
                                            rockstarkid76
                                            im sorry for using all caps.my apologies 😳
                                            • 4 / 5
