    Lock toolbars
    97 Posts 52 Posters 210.9k Views 52 Watching
      @remus said:
      Im sure it will do very little to ease your pain, but if you get enough short-cuts setup it is quite possible to model entirely with short-cuts. Combined with a choice few tool-bars i have found this to be the best solution.
      I actually combine this with Jim's tool-bar plug-in and have stripped my SU window entirely off the tool-bars. Now the only "native" tool-bar is Jim's and there are a couple of plug-ins placed nicely under each other but everything is floating next to my SU window where I don't have any tool-bars.
      About 80% of the cases I use short-cuts anyway and this allows me to "dump" all those icons the tool of which I'd use with short-cuts anyway and to keep only those plug-ins "alive" that I'm currently using for that particular model (e.g. I don't need the Kerky exporter or the IDX Renditioner tool-bars) while modelling.
      Yes, I KNOW this is a sort of workaround (but this is SketchUp after all and we are masters at workarounds, aren't we?) but has one very big advantage as well; since Jim's script stores the tool-bar info in an external file, I can set it up once and carry it from computer to computer without any problem.
      • N Offline
        notareal
        @a4chitect said:
        there is a little trick to help you, once you are happy with your toolbar arrangement, close sketchup (the UI gets saved internally). anytime your screen gets resized, or messed up, or your toolbars change - don't close sketchup, open another instance of sketchup - this one opens with the original UI. then close both windows but make sure that you close the clean and tidy @last 😄
        this way your clean UI gets saved as last overwriting the messy one (since all instances of sketchup share one UI setting)
        Thanks for the tip. This has been one major annoyance.
          putnik
          Registry tweak works OK only till the next installation of a new script with toolbar which is always followed by another toolbar chaos. Google, please fix this.
          http://keshas.info
          • RayOchoaR Offline
            RayOchoa
            +1 happened to me today 😡 😡 😡
            CaR DeSiGnS bY mE
            http://ray-ochoa.com
            • PixeroP Offline
              Pixero
              I've found a good way of placing toolbars is to click in the lower left part of a menu and release it at the upper left part where you want it it doesnt "jump back" to where it was.
              http://i43.tinypic.com/2pq1g0h.jpg
              • PixeroP Offline
                Pixero
                Bump.
                I added a couple new ruby scripts today and what do you know... all my toolbars were flung all over my screen. And then I had to fix it all over again at home.
                Please fix this Google.
                When ever I add a new script it A L W A Y S the Sandbox toolbar that moves around and mess things up. Is it the same for you?
                  Nopes. Any toolbar. Often all.
                  • MALAISEM Offline
                    MALAISE
                    You can also using the Toolsbar Menu, unselect all items. Close SU and reopen, you'll get a brand new space and reselect step by step all favourites !
                    But it looks like some dressing ( first aid) on a piece of wood ( very bad translation's French say ) 😳
                    MALAISE 😉
                    • halroachH Offline
                      halroach
                      The Jumping Toolbar Syndrome! - PARTIAL SOLUTION
                      Sometimes I find myself battling the toolbars to get them all tight and snug (after the installation of a new ruby toolbar).
                      for example:
                      I have three lines of toolbars lets say, and two of them are full, with the third line containing only a few buttons. I then try to place another toolbar on the third line, and instead of if being placed right next to it, it's placed on a fourth line, wasting all that space on the third line... argggh
                      I have found a solution to the jumping toolbar problem!
                      you must pack and cram each line of toolbars all the way to the end, until one of the toolbars get cropped, and then cram one more toolbar until one of the toolbars shifts to the next line automatically (sort of like an auto carriage return, or wordwrap). Now you can rearrange the toolbars on the third line, and they won't jump around! and you can replace the cropped toolbar from the second line to the third line too...
                      Hope This Helps Someone
                      FlexTools - Super Quick Windows, Doors, Slats...
                        arjunmax09
                        there are so many people on this forum who are awesome at making plugins... is there a possibility that one can make a plugin that just stops this haywire toolbars problem??
                        when you fail at something....you haven't really failed...you've found one way the thing will not work out
                          There's been a great number of brave attempts. Countless hours has been spent trying to hack the wretches thing - but all have returned bruised and scared. 😞
                            arjunmax09
                            i see.....but as the adidas line goes ..."IMPOSSIBLE IS NOTHING"... surely one genius is going to crack this problem... 😄
                              putnik
                              Until a couple of days ago installing a new script would mess up my toolbar locations, but at least I could re-arrange toolbars. Then I installed a couple of new ones, Extrusion Tools by TIG was one of them. And toolbars stopped sticking to where I wanted them to be! Really annoying!
                              Strangely, the following from Halroach did help. Thanks!
                              PS This is not to say that TIG's Extrusion Tools was actually the culprit. I don't know what was.
                              http://keshas.info
                                Banaticus
                                @remus said:
                                ...except office 2007 😛
                                Well, Microsoft has the official stance that things can't be removed from the Ribbon... but what they don't advertise is that you can hide things on the Ribbon and otherwise move stuff around (and add new things): http://msdn.microsoft.com/en-us/library/aa338202%28office.12%29.aspx#OfficeCustomizingRibbonUIforDevelopers_Customizing
                                I would really really like to see the ability to do something like that, some sort of coding or CSS or XML or something that would allow us to upload a customized UI from a file. There are a few things that I like to use regularly that I just can't do with keyboard shortcuts, like the Dimension tool for callouts. I've set it to the "D" key, but then there's that layer-pane thing that sizes itself to cover the model and which "hides" (removes) everything on one side of it -- I love sliding that thing back and forth to quickly remove a wall.
                                  Joewoodworker
                                  I've had to arrange my toolbars for the third/fourth time today. Really annoying! I hope this will be fixed soon so one can lock your tools (menu top and left) in position so in the even of something happening you don't have to rearrange them afterwards.
                                  I think this has been mentioned (requested) in the wishlist before, hope it gets the attention it deserves.
                                  Hey Juju...
                                  Ummm, why don't you set the screen up as you'd like to see it everytime by turning it into a template? You set up everything, the units, the toolbars, the background get rid of Brice...everything you want. The next time you launch SU...presto! It's the way you want it.
                                  Joe,
                                  Twisted Knot Woodshop, "There's never been a classier joint"
                                  Maker of expensive firewood since 1968
                                  • halroachH Offline
                                    halroach
                                    An observation: 😞
                                    1. There are plugins (most plugins) that load a toolbar automatically when first installed - and in most cases cause a lot of havoc - moving all the other toolbars all over the place.
                                    2. On the other hand plugins that need to be initially "checked" ('view''toolbars''plugin name') or from ('preferences''extensions''plugin name') usually load somewhere in the middle of the screen that way they can be placed easily without messing everything up. I am not a coder, but maybe the initial placement of the toolbar is something that can be coded into each plugin... (i.e. make it load somewhere neutral at first load) or is it just by chance?
                                    • xennonX Offline
                                      xennon
                                      This is incredible ... this thread alone has been going since Apr 2008 ... more than 30 months and STILL no resolution to the extremely annoying issue. Version 8 has now come out and guess what - I STILL DOES IT!!.
                                      OMFG - What does it take for goooooooogle to pull their finger out and address this problem?
                                      Someone else said that it's been around since at least v4 ... how long ago was that?!
                                      Given the enormous resource base of gooooooogle, rivaled probably only by microsoft and yahoo in scale - how bad must their developers be if they can't solve this problem in the years that they've had to mess with it.
                                      totally gob-smacked!
                                      • jbacusJ Offline
                                        jbacus
                                        While it is clear that you're not impressed with our improvement (for those who've missed it so far, we're also discussing this on the SketchUp Help Forum), I'm curious to know if it had any impact on the workflow of other folks here on SCF?
                                        The basic problem is that folks with more than a dozen Ruby extensions (I ran into someone yesterday who had over 200 of them installed at once... whoa!) are overwhelming our simple MFC toolbar implementation. It just can't scale to that kind of usage. To make things work better, we'll have to stop using Microsoft's toolbars and write our own. That isn't a trivial project, unfortunately– we could do it, but it would mean not doing something else.
                                        As I said over at our forums, being civil will make it much more likely that discussion of the actual problems at hand will occur. I'm quite willing to discuss these sorts of issues, but find it easier to do when folks are being polite.
                                        "...exaggerate the essential and leave the obvious unclear." --Vincent Van Gogh
                                        John Bacus
                                        jbacus@sketchup.com
                                        • mitcorbM Offline
                                          mitcorb
                                          "but find it easier to do when folks are being polite."
                                            Xennon,
                                            The toolbar has been given a serious overhaul and is a step forward. Pointing out how lazy and bad they development team does nothing for your argument. Also posting in 2 forums the same diatribe without a compelling case in either is disappointing. Your free to air your opinions wherever you wish. I might add that we're a friendly bunch around here, as you know from your Golden Ratio thread, and help is always forthcoming. We also welcome new members and encourage open and honest discussions. I would take John's advice and show some tact when raising your concerns with SU. You'll find alot more people will support you!
                                            Also I can vouch that the guys at Google SketchUp not only work hard but party even harder 😉
                                            For those who are interested here's Xennon's post from the Google Help Forums...
                                            That "remember" or restore option is a crock - it does nothing. It only works if you move toolbars around and change your mind (during that session) and want to go back to how they were when the prog started. If you install a new script/plugin, SU will ALWAYS start up after the install with messed up toolbars and pressing that restore button will do absolutely nothing.
                                            This is a serious and extremely annoying BUG that's been there since waaaaaay back to version 4 at least. The best the developers have managed to come up with is a half-arsed save/restore option that fails more than it succeeds. Time to roll up the sleeves people and dig into the muck that must be the SU code and fix it once and for all.
                                            Waddaya recon gooooooogle? ... you brave enough to have a go? (I for one think not)
                                            • 4 / 5
