    Lock toolbars
    97 Posts 52 Posters 204.4k Views 52 Watching
    • mitcorbM Offline
      mitcorb
      "but find it easier to do when folks are being polite."
      ๐Ÿ‘ ๐Ÿ‘ ๐Ÿ‘ ๐Ÿ‘ ๐Ÿ‘
        Xennon,
        The toolbar has been given a serious overhaul and is a step forward. Pointing out how lazy and bad they development team does nothing for your argument. Also posting in 2 forums the same diatribe without a compelling case in either is disappointing. Your free to air your opinions wherever you wish. I might add that we're a friendly bunch around here, as you know from your Golden Ratio thread, and help is always forthcoming. We also welcome new members and encourage open and honest discussions. I would take John's advice and show some tact when raising your concerns with SU. You'll find alot more people will support you!
        Also I can vouch that the guys at Google SketchUp not only work hard but party even harder ๐Ÿ˜‰
        For those who are interested here's Xennon's post from the Google Help Forums...
        That "remember" or restore option is a crock - it does nothing. It only works if you move toolbars around and change your mind (during that session) and want to go back to how they were when the prog started. If you install a new script/plugin, SU will ALWAYS start up after the install with messed up toolbars and pressing that restore button will do absolutely nothing.
        This is a serious and extremely annoying BUG that's been there since waaaaaay back to version 4 at least. The best the developers have managed to come up with is a half-arsed save/restore option that fails more than it succeeds. Time to roll up the sleeves people and dig into the muck that must be the SU code and fix it once and for all.
        Waddaya recon gooooooogle? ... you brave enough to have a go? (I for one think not)
        • ToboboT Offline
          Tobobo
          I agree whilst it is frustrating that the toolbars move, i can imagine that Google have higher priorities in development such windows 7 and OS compatibility. Donโ€™t forget Google bought SU to improve the openness of the 3D element of Good Earth. Plus itโ€™s a minor thing in what is a massive programme. John's point about rubies is fair, I donโ€™t have 200 ( ๐Ÿ˜ฎ ) but I know they can programme stuff based on that extreme amount.
          So keep working boys and girls I can hold on a bit longer
          PS. manners cost nothing so being nice to people is free.
          Toby
          Philippians 4:13
            It's a major annoyance restoring ones workspace every time you get the Shuffle. A reliable workspace is essential to get a good workflow - so UI elements moving about is not a good thing.
            • ToboboT Offline
              Tobobo
              A fair point my dear sir, and for a SU giant such as yourself I can imagine that you have many toolbars surrounding your most splendiferous creations.
              Me however aint got much.
              Toby
              Philippians 4:13
                Actually, I keep my visible toolbars to a minimum in order to reduce the pain of the Shuffle and save screen estate. I keep at max one row of small-icon toolbars. But some of them are several very short ones - which still leaves me with several toolbars to clean up. I really feel sorry for those who need to clean up more toolbars.
                  Jim
                  I have taken to not using Toolbars, or having a very minimal number open. I wrote a custom WebDialog (or 2) to replace Toolbars. One dialog is a general toolbar replacement, the other toggles the normal Toolbars visible/not visible. The dialogs are pretty rough around the edges since I am the only one who uses them; but they do show what can be done and how the WebDialogs can (and will) be an effective alternative to the built-in Toolbars.
                  There are a few other, similar plugins that are using webdialogs as toolbar alternatives.
                  My dialogs: the short texts are buttons, too.
                  http://i.min.us/iQWzW.png
                  (moved post from another topic)
                    rockstarkid76
                    @remus said:
                    Julian, why dont you get rid of all your toolbars and jsut use keyboard shortcuts? it takes a bit of getting used to but its a lot faster ๐Ÿค“
                    BUT NOT ALL COMMANDS HAVE SHORTCUTS!
                      rockstarkid76
                      @a4chitect said:
                      there is a little trick to help you, once you are happy with your toolbar arrangement, close sketchup (the UI gets saved internally). anytime your screen gets resized, or messed up, or your toolbars change - don't close sketchup, open another instance of sketchup - this one opens with the original UI. then close both windows but make sure that you close the clean and tidy @last ๐Ÿ˜„
                      this way your clean UI gets saved as last overwriting the messy one (since all instances of sketchup share one UI setting)
                      GREAT!!! THANKS
                        You can set up your own shortcuts from Window > Preferences > Shortcuts
                        (p.s. Please don't use all caps when writing a post. It's considered bad forum manner. If anything, use all lower. Makes things much easier to read and it doesn't make you look like you are yelling.)
                          rockstarkid76
                          im sorry for using all caps.my apologies ๐Ÿ˜ณ
                          • N Offline
                            numerobis
                            sorry... but every time i read this topic title i have to laugh... it's really a big joke that this annoying little problem is still not fixed after such a long time!
                            If this is such a hard thing to do, the developers of nearly all other softwares i know must be real geniuses since they found a solution for this "unsolvable" problem... ๐Ÿ˜’
                            • ToboboT Offline
                              Tobobo
                              the save tool bars have gone along way to solve it. Though saying that it hasn't happened in a while. touch wood
                              Toby
                              Philippians 4:13
                                kwistenbiebel
                                Yes, annoying bug still around.. ๐Ÿ˜„
                                • F Offline
                                  findthong
                                  This is quite nice. Everyone here having some problem with Toolbar, but my problem is Web Dialogs LOL.
                                  I'm using Dual monitor set up. Sometime I work with SketchUp on my 1st monitor when SketchUp is being my top priority and many time I've to move it to 2nd monitor. And web dialogs not going to move with SketchUp. That's quite annoying and I need to do a lot workaround and get familier with it.
                                  And I've just counted I've 112 shortcut combinations to get aroud these UI problem as much as possible! And I can remember 80 percent of them, but not much icons!. It need a lot brain power, when you want to have less moving around as possible while using a lot of scripts to prevent tedious tasks as much as possible. I can't imagine I can even work in SketchUp without my cheat sheet or on other computer ๐Ÿ˜„.
                                  We definitely need some UI love for extensive users, because there're so many advanced SketchUp user around!
                                    shawnkelly
                                    Sounds like some of the users in this post need to move to another software. This is called Sketch-Up for a reason. I was most likely developed by someone that was tired of the limitations of pencil and paper. It is meant for sketching out ideas quickly without the fuss of all that you people bring to it. I despise the other programs because of their complexity. I use them (Rhino and Modo) of course because they are unnecessary but not at the beginning of a project that has no initial parameters. Do not try to make it so hard on yourselves, it steals all the fun out of it.
                                    BTW, has anyone tried View>Toolbar>Save Toolbar Location/Restore Toolbar Location. I crash (Bug-Splat) Sketch-Up all the time and I have yet to manually move all my toolbars back to their positions after restoring them.
                                      No splat here on Restore Toolbars
                                      Sent from my iPad
                                      • pbacotP Offline
                                        We don't have this problem on Macs.
                                        The toolbars are never in a good place, never where you put them, same with windows so they can't be messed up. You get the Mac "customize toolbar" which also sucks.
                                        • MichaelNeysesM Offline
                                          MichaelNeyses
                                          I just cant fathom, what you guys are doing with your toolbars, I closely watched the progress of this discussion. I almost feel guilty by not having this genuine problem at all.
                                          If the bars are disturbed, which very rarely occurs, I hit the ALT/F9 Button that I have set on the 'Restore Toolbars' command and all the boys are back in place.
                                          I dont have any explanation for this good behavoir other then maybe that I am using a 30" screen which gives me planty of room not to mess in the vicinity of the bars.
                                          I rely very much on SU during my workday and produce at least 50 projekts a year. I would have never stuck with this software, if there were such instances as the need of rearranging the landscape of toolbars 5 times a day! Maybe choose the plugins I am using a bit carefully but I have learned long ago that being a gearhead and jumping on any train is the least splendid of all forthcoming methods.
                                          nothing beats the joy of accomplishing a design that meets previous vision
                                            Note that this discussion started in 2008 (see first post) when there was no such function as "Save toolbar position" or "Restore toolbar position".
                                            People keep re-discovering this topic time-to-time...
                                            • 4 / 5
