    The "Duh!" thread (aka the Doh! thread)
    696 Posts 135 Posters 314.3k Views 135 Watching
      Add to the previous thread ๐Ÿ˜„
      I reread the doc (that was written in small that you can enter measure in VCB with the Scale tool! ๐Ÿ˜ณ
      And also a cool one (in the same doc)! ๐Ÿ’š
      You can Press in the SAME TIME SHIFT AND CTRL with the Scale tool ! ๐Ÿ˜ฎ ๐Ÿ˜ณ ๐Ÿ˜ณ
      For have a super scaling result! ๐Ÿ’š
      • ToboboT Offline
        Tobobo
        One this week was more of a remembering than a Duh moment.
        Using the Entity Ifon box you can increase the length of a line and No. of sides of a circle.
        Toby
        Philippians 4:13
          @tobobo said:
          ...No. of sides of a circle.
          And a polygon and an arc...
            In what side? Good or false? ๐Ÿ˜„
            • spenceS Offline
              spence
              One of my many many "Duh" moments came when I found out that while using the Paint Bucket Tool you could hold down Shift to paint all that match or hold Ctrl to paint all connected. I use this often.
              Boy I have learned a lot of new stuff from this thread ๐Ÿ˜„
              Spence
              • ToboboT Offline
                Tobobo
                The changes its length in the same direction it has been drawn. it has to be unattached at one end, and that is the end the lengthens or shortens.
                Toby
                Philippians 4:13
                  Jim
                  Has any one here also thought of compiling/organizing this thread into a more readable format? Wiki? Print?
                  • pyrolunaP Offline
                    pyroluna
                    well... there's a sketchup-wiki in Dutch... so... yay! for Dutch people
                      Jim
                      Today I learned you can use the arrow keys to precisely move the selection in Paint.NET. (Holding Ctrl moves it by 10 pixels.)
                        I just realised it the other day myself, too. ๐Ÿ˜„
                        • david_hD Offline
                          david_h
                          I've been taken to task just now on this one. . . I asked for a plugin to toggle the Construction lines on and off. . .turns out it's in the view menu. . .
                          WHICH I NEVER USE BY THE WAY!!!!
                          Hide Construction lines
                          This is so humiliating. . .. ๐Ÿ˜ณ ๐Ÿ’š
                          I'm okay now. . .
                            Jim
                            I just learned that Edit > Delete Guides is context-sensitive - it deletes guides all guides starting from the current editing context and deeper, but not from "higher" level contexts. I had always thought it always deleted all guides, everywhere.
                              I had that same realization a couple of weeks ago. ๐Ÿ˜„
                                @rv1974 said:
                                If Thom is already here..
                                Only last week I discovered know that double clicking on blue balloons (edge tools-inspect gaps) actually close the gaps.
                                Great tool!
                                Ah, yea it's not that obvious - I had further plans for the UI. (also for CleanUp), but they've been down-prioritized.
                                btw, no need to doubleclick - single click is enough.
                                  rv1974
                                  Only last week I discovered that double clicking on blue balloons (edge tools-inspect gaps) actually close the gaps.
                                  Great tool!
                                    Doh. ๐Ÿ˜ฒ
                                    What???!!! ๐ŸŽ‰
                                      Being able to select only a few edges from a face and offset them instead of the whole face.
                                      Yes but edges must be selected without discontinuity! ๐Ÿ˜ณ ๐Ÿ˜ณ ๐Ÿ˜ณ
                                      • boofredlayB Offline
                                        boofredlay
                                        Something I just learned a couple days ago while studying the Google Earth Modeling videos.
                                        D'oh, never knew that you could make a unique texture from a portion of another!
                                        [flash=853,505:84crs2i3]http://www.youtube.com/v/18r2sCMUSBU&fs=1[/flash:84crs2i3]
                                        • DanielD Offline
                                          Daniel
                                          I've always known about hiding geometry by holding the shift key with the eraser, but last week I just noticed the "hidden" check box on the entity info window. ๐Ÿ˜ณ
                                          My avatar is an anachronism.
                                          • Bob JamesB Offline
                                            Bob James
                                            Never paid any attention to this thread until today ๐Ÿ˜ณ
                                            @tig said:
                                            .....select all faces with the same material as the one highlighted... then RickW pointed out that it is already a standard built-in tool under Select... ๐Ÿ˜ณ
                                            OMG ๐Ÿ˜ฒ I soooo needed this yesterday ๐Ÿ‘Š
                                            This thread is one of the greatest tutorials ever made!
                                            Now to Page 1 and read (and write down) all of the golden nuggets in this thread.
                                            • 30
                                            • 31
                                            • 32
                                            • 33
                                            • 34
                                            • 35
                                            • 32 / 35
