    The "Duh!" thread (aka the Doh! thread)
    696 Posts 135 Posters 622.4k Views 135 Watching
      You should suffer fools gladly... one day you will be one of them!
      I once invented my great new tool for the context-menu that would select all faces with the same material as the one highlighted... then RickW pointed out that it is already a standard built-in tool under Select... ๐Ÿ˜ณ
        Mine of the day ๐Ÿ’š (thx Regis)
        I have found that was a good idea ๐Ÿ’ญ
        Draw first the line then use
        but... ๐Ÿ’š
        you can also with only just enter in the VCB
        (whatever unities in activity)
        3.14cm
        31.4mm
        0.0314m
        ... (i am not very familiar with inch ๐Ÿ’š
        ๐Ÿ˜’
          Add to the previous thread ๐Ÿ˜„
          I reread the doc (that was written in small that you can enter measure in VCB with the Scale tool! ๐Ÿ˜ณ
          And also a cool one (in the same doc)! ๐Ÿ’š
          You can Press in the SAME TIME SHIFT AND CTRL with the Scale tool ! ๐Ÿ˜ฎ ๐Ÿ˜ณ ๐Ÿ˜ณ
          For have a super scaling result! ๐Ÿ’š
          • ToboboT
            Tobobo
            One this week was more of a remembering than a Duh moment.
            Using the Entity Ifon box you can increase the length of a line and No. of sides of a circle.
            Toby
            Philippians 4:13
            • GaieusG
              @tobobo said:
              ...No. of sides of a circle.
              And a polygon and an arc...
                In what side? Good or false? ๐Ÿ˜„
                • spenceS
                  spence
                  One of my many many "Duh" moments came when I found out that while using the Paint Bucket Tool you could hold down Shift to paint all that match or hold Ctrl to paint all connected. I use this often.
                  Boy I have learned a lot of new stuff from this thread ๐Ÿ˜„
                  Spence
                  • ToboboT
                    Tobobo
                    The changes its length in the same direction it has been drawn. it has to be unattached at one end, and that is the end the lengthens or shortens.
                    Toby
                    Philippians 4:13
                      Jim
                      Has any one here also thought of compiling/organizing this thread into a more readable format? Wiki? Print?
                      • pyrolunaP
                        pyroluna
                        well... there's a sketchup-wiki in Dutch... so... yay! for Dutch people
                          Jim
                          Today I learned you can use the arrow keys to precisely move the selection in Paint.NET. (Holding Ctrl moves it by 10 pixels.)
                          • GaieusG
                            I just realised it the other day myself, too. ๐Ÿ˜„
                            • david_hD
                              david_h
                              I've been taken to task just now on this one. . . I asked for a plugin to toggle the Construction lines on and off. . .turns out it's in the view menu. . .
                              WHICH I NEVER USE BY THE WAY!!!!
                              Hide Construction lines
                              This is so humiliating. . .. ๐Ÿ˜ณ ๐Ÿ’š
                              I'm okay now. . .
                                Jim
                                I just learned that Edit > Delete Guides is context-sensitive - it deletes guides all guides starting from the current editing context and deeper, but not from "higher" level contexts. I had always thought it always deleted all guides, everywhere.
                                  I had that same realization a couple of weeks ago. ๐Ÿ˜„
                                    @rv1974 said:
                                    If Thom is already here..
                                    Only last week I discovered know that double clicking on blue balloons (edge tools-inspect gaps) actually close the gaps.
                                    Great tool!
                                    Ah, yea it's not that obvious - I had further plans for the UI. (also for CleanUp), but they've been down-prioritized.
                                    btw, no need to doubleclick - single click is enough.
                                      rv1974
                                      Only last week I discovered that double clicking on blue balloons (edge tools-inspect gaps) actually close the gaps.
                                      Great tool!
                                      • GaieusG
                                        Doh. ๐Ÿ˜ฒ
                                        What???!!! ๐ŸŽ‰
                                          Being able to select only a few edges from a face and offset them instead of the whole face.
                                          Yes but edges must be selected without discontinuity! ๐Ÿ˜ณ ๐Ÿ˜ณ ๐Ÿ˜ณ
                                          • boofredlayB
                                            boofredlay
                                            Something I just learned a couple days ago while studying the Google Earth Modeling videos.
                                            D'oh, never knew that you could make a unique texture from a portion of another!
                                            [flash=853,505:84crs2i3]http://www.youtube.com/v/18r2sCMUSBU&fs=1[/flash:84crs2i3]
                                            • 12
                                            • 13
                                            • 14
                                            • 15
                                            • 16
                                            • 34
                                            • 35
                                            • 14 / 35
