πŸ€‘ SketchPlus 1.3 | 44 Tools for $15 until June 20th Buy Now
Unbelievably annoying problem!!! Help before I jump!
10 Posts 6 Posters 309 Views 6 Watching
    leedeetee
    Can anyone help me?!
    I have absolutely no idea why one area in my model won't become a face!! HELP!
    I've tried everything but one more minute and I'm down to the river....
    File attached.
    SOS
      Not co-planar
      Lee.skp
        yeah, i've never used color by axis but apparently, it's not very accurate..
        according to those colors, it's coplanar but once you check it, it's not.
          leedeetee
          Cheers guys, so the "colour by axis", is pretty pointless then? 😳
          Did you make any amendments, Rich?
            It's a mystery...
            Here's a fix with just one hidden-line...HesHall model.skp
              Yes, the bottom of the 'L' shaped hole had 2 edges?
                leedeetee
                Did it?! Bugger. πŸ˜„
                Thanks to you both, Rich and TIG.
                I've stripped it back to the dxf file and started again anyway. I went through half a bottle of white trying to fix that!
                πŸ‘
                  jim smith
                  I have run into these stubborn faces. I erased most of the lines around the opening and re-drew them. Attached is a Jing SWF video showing what I did. Something must have been doubled up and no doubt one of the lines did'nt intersect properly??
                  2010-11-05_1553.swfmissin_face_help.swf
                  "Out of clutter find simplicity,
                  from discord find harmony,
                  In the middle of difficulty lies opportunity"
                  Albert Einstein
                  • W Offline
                    Wo3Dan
                    @tig said:
                    It's a mystery...
                    Not that mysterious though, TIG. Lee should only move one edge (the longest vertical one) slightly forward.
                    This will get it in plane with the other edges like the (upside down) L-shape (red+blue).
                    One may get tricked here by the top red edge(s!!). For in fact there are two almost collinear edges within tolerance, showing red. It looks like just one.
                    In his original model move the endpoint which is somewhere in the middle of that top edge, to see this. You will see sort of a triangle getting formed.
                    (The 'Teape Measure' tool shows which endpoint(s) is/are how much out of plane. It's both endpoints of the longer vertical edge).
                      leedeetee
                      Thanks so much guys, great help, especially for a Friday night.
