    [Plugin] SCF PowerToolbar (09.Sep.2010)
    76 Posts 36 Posters 81.2k Views 36 Watching
      rongvuong
      Don't work with sketchup 8.
      help me?
      • HumpmetwiceH Offline
        Humpmetwice
        I get this error after installing the power toolbar. Did I do something wrong, is there something else I need?
        • CadFatherC Offline
          CadFather
          ok, wrong lines have been changed - hope it still works.
            Could you add a Last Updated timestamp to your original post? Makes it easier to catch any updates when you browse the plugins.
              Humpmetwice
              Is there something I can do to fix this or do I need to uninstall it? It still works but is aggravating 😮 !
                CadFather
                Thom, you mean in the subject, or just the post?
                @ humpmetwice, i don't think this has to do with SCF-PB - take out all your plugins then install PB, if it works then you know..
                  At least the subject - since that appears when you browse the forum and also in Jim's index.
                    CadFather
                    yes of course.. done.
                    • U Offline
                      unclex
                      where is the new guy?
                        the.pjt
                        How do we can unpack the main file to edit it ? is it possible to unpack a code ? can you upload a unpacked version ?
                          bd99
                          thankkkkkkkkkkkkkkkkkkkk
                          • E Offline
                            exposal
                            I've try on SU8.0 PRO.that's no problem.
                            • H Offline
                              hyprc
                              so cool, thank U
                                I've edited the download page - with a warning about 'rogue files' inside the zip!
                                CADfather, can you please sort out this issue, which can break some other tools and cause other problems - the older files [ sketchup.rb and extensions.rb] supplied in the zip should NEVER be put into the Plugins folder. In all recent versions of Sketchup newer versions of those files come pre-installed in the Tools folder, so having these duplicates just messes things up - sometimes so subtly it causes hours of searching to find what's up! 😒
                                  CadFather
                                  sure, i'll post an update very soon
                                  • U Offline
                                    Unr Cruurni
                                    Hay all fearless Ruby Scripters!
                                    First I want to thank you all for the wonderfull job your doing !
                                    now,
                                    Using SCF powerbar with Metric Meters template is O.k?
                                    since I'v been having trouble with the Push-Pull along normals tool.
                                    I set 6m as a value and it Pulls 0.15m...
                                    Thanks ! ALOT!
                                      anderseide
                                      Hello¨
                                      First of all, great work!
                                      Second, am I the only one getting trouble installing all the SCF bars(power bar, architect, draw tool, selective etc)? They all have their icons in a folder called CD_ICONS, so loading them all in the plugins folder made them overwrite each other. In the end I had to change each folder to CD_ICON1, CD_ICON2, and then change the routing in the orignial rb. file.
                                      Am I the only one experiencing this?
                                      Third: All my plugin toolbars load at startup except the different SCFs. I have tried twenty times to place them and save the template, but it doesnt work When I manually toggle them on, theyre in the right place, so I guess the template is saved, but the toolbars wont show up without manually enabling them.
                                      Any suggestions?
                                      • 4 / 4
