    [Plugin] SCF PowerToolbar (09.Sep.2010)
    76 Posts 36 Posters 85.6k Views 36 Watching
    • W
      windrockwater
      The link for downloading this cool script is not working. Is there a working link available? TIA...
      • CadFatherC
        CadFather
        Hi, link repaired.. thanks
        • H
          haroldcampbell
          @driven said:
          has any one got this fully running on a mac??
          i get this error, functionality of some of the tools
          Don't know if this is still an issue for anyone, but you can find a patched version that works for me.
          I changed line 4921
          if (n1.between? (n2 - interval), (n2 + interval))
          to
          if ( n1.between?((n2 - interval), (n2 + interval)) )
          I'm running mac os x 6, SketchUp 7 (7.1.6859)
          patched cd_power_m.rb file.
          • Dan RathbunD
            Dan Rathbun
            Errors in [Plugin] SCF PowerToolbar v1
            The errors are caused by poor programming style.
            If you run SU7 Mac (with Ruby 1.8.5-p0) OR run SU7 on PC AND have updated your Ruby interpreter DLL to Ruby 1.8.5 or higher, then certain "typos" are no longer permitted by the Ruby interpreter.
            ` %(black)[cd_power_extension_m.rb
            Line 4921:]if (n1.between? (n2 - interval), (n2 + interval))
            * move first "(" just after "between?" and before "(n2", so it replaces the space character. Like:
            if n1.between?((n2 - interval), (n2 + interval))`
            ` %(black)[cd_power_m.rb
            • same fix as above, .. replace Line 4921]
              with:
            ` %(black)[cutting_windows.rb
            fix Line 610:]
            faces_and_heights[0.pushpull (faces_and_heights[1]), false]
            * add parenthesis around pushpull method's argument list, ie:
            faces_and_heights[0.pushpull( (faces_and_heights[1]), false )]`
            What is happening, is that:
            • Ruby is getting confused as to what are method argument lists, and what are arguments (delimeted with parenthesis,) within the arguemnt list.
            • For best practice in later Ruby versions, all methods should have parenthesis around the whole argument list, with NO space between end of method name and the left parenthesis of it's argument list.
            • If a method has no args, speed up Ruby by passing an empty arg list, like so: %(darkred)[*obj*.method_name()]
            I'm not here much anymore.
            • N
              Nosonja
              Don't work with sketchup 8.
              • CadFatherC
                CadFather
                i'm hoping to fix the bugs soon..
                • T
                  tina0603
                  try to replace it with haroldcampbell attachments
                    rongvuong
                    help me?
                    • HumpmetwiceH
                      Humpmetwice
                      I get this error after installing the power toolbar. Did I do something wrong, is there something else I need?
                      • CadFatherC
                        CadFather
                        ok, wrong lines have been changed - hope it still works.
                          Could you add a Last Updated timestamp to your original post? Makes it easier to catch any updates when you browse the plugins.
                          • HumpmetwiceH
                            Humpmetwice
                            Is there something I can do to fix this or do I need to uninstall it? It still works but is aggravating ๐Ÿ˜ฎ !
                            • CadFatherC
                              CadFather
                              Thom, you mean in the subject, or just the post?
                              @ humpmetwice, i don't think this has to do with SCF-PB - take out all your plugins then install PB, if it works then you know..
                                At least the subject - since that appears when you browse the forum and also in Jim's index.
                                • CadFatherC
                                  CadFather
                                  yes of course.. done.
                                  • U
                                    unclex
                                    where is the new guy?
                                    • T
                                      the.pjt
                                      How do we can unpack the main file to edit it ? is it possible to unpack a code ? can you upload a unpacked version ?
                                      • B
                                        bd99
                                        thankkkkkkkkkkkkkkkkkkkk
                                        • E
                                          exposal
                                          I've try on SU8.0 PRO.that's no problem.
                                          • H
                                            hyprc
                                            so cool, thank U
                                            • 4 / 4
