    [Plugin] SCF PowerToolbar (09.Sep.2010)
    76 Posts 36 Posters 82.3k Views 36 Watching
      Sir
      the link to your website is broken btw
      • W Offline
        windrockwater
        The link for downloading this cool script is not working. Is there a working link available? TIA...
        • CadFatherC Offline
          CadFather
          Hi, link repaired.. thanks
          • H Offline
            haroldcampbell
            @driven said:
            has any one got this fully running on a mac??
            i get this error, functionality of some of the tools
            Don't know if this is still an issue for anyone, but you can find a patched version that works for me.
            I changed line 4921
            if (n1.between? (n2 - interval), (n2 + interval))
            to
            if ( n1.between?((n2 - interval), (n2 + interval)) )
            I'm running mac os x 6, SketchUp 7 (7.1.6859)
            patched cd_power_m.rb file.
            • Dan RathbunD Offline
              Dan Rathbun
              Errors in [Plugin] SCF PowerToolbar v1
              The errors are caused by poor programming style.
              If you run SU7 Mac (with Ruby 1.8.5-p0) OR run SU7 on PC AND have updated your Ruby interpreter DLL to Ruby 1.8.5 or higher, then certain "typos" are no longer permitted by the Ruby interpreter.
              ` %(black)[cd_power_extension_m.rb
              Line 4921:]if (n1.between? (n2 - interval), (n2 + interval))
              * move first "(" just after "between?" and before "(n2", so it replaces the space character. Like:
              if n1.between?((n2 - interval), (n2 + interval))`
              ` %(black)[cd_power_m.rb
              • same fix as above, .. replace Line 4921]
                with:
              ` %(black)[cutting_windows.rb
              fix Line 610:]
              faces_and_heights[0.pushpull (faces_and_heights[1]), false]
              * add parenthesis around pushpull method's argument list, ie:
              faces_and_heights[0.pushpull( (faces_and_heights[1]), false )]`
              What is happening, is that:
              • Ruby is getting confused as to what are method argument lists, and what are arguments (delimeted with parenthesis,) within the arguemnt list.
              • For best practice in later Ruby versions, all methods should have parenthesis around the whole argument list, with NO space between end of method name and the left parenthesis of it's argument list.
              • If a method has no args, speed up Ruby by passing an empty arg list, like so: %(darkred)[*obj*.method_name()]
              I'm not here much anymore.
              • N Offline
                Nosonja
                Don't work with sketchup 8.
                  CadFather
                  i'm hoping to fix the bugs soon..
                    tina0603
                    try to replace it with haroldcampbell attachments
                      rongvuong
                      help me?
                      • HumpmetwiceH Offline
                        Humpmetwice
                        I get this error after installing the power toolbar. Did I do something wrong, is there something else I need?
                          CadFather
                          ok, wrong lines have been changed - hope it still works.
                            Could you add a Last Updated timestamp to your original post? Makes it easier to catch any updates when you browse the plugins.
                              Humpmetwice
                              Is there something I can do to fix this or do I need to uninstall it? It still works but is aggravating ๐Ÿ˜ฎ !
                                CadFather
                                Thom, you mean in the subject, or just the post?
                                @ humpmetwice, i don't think this has to do with SCF-PB - take out all your plugins then install PB, if it works then you know..
                                  At least the subject - since that appears when you browse the forum and also in Jim's index.
                                    CadFather
                                    yes of course.. done.
                                    • U Offline
                                      unclex
                                      where is the new guy?
                                        the.pjt
                                        How do we can unpack the main file to edit it ? is it possible to unpack a code ? can you upload a unpacked version ?
                                          bd99
                                          thankkkkkkkkkkkkkkkkkkkk
                                          • E Offline
                                            exposal
                                            I've try on SU8.0 PRO.that's no problem.
                                            • 4 / 4
