    [Plugin] SCF PowerToolbar (09.Sep.2010)
    76 Posts 36 Posters 85.6k Views 36 Watching
      Could you add a Last Updated timestamp to your original post? Makes it easier to catch any updates when you browse the plugins.
      • HumpmetwiceH
        Humpmetwice
        @cadfather said:
        ok, wrong lines have been changed - hope it still works.
        Is there something I can do to fix this or do I need to uninstall it? It still works but is aggravating 😮 !
        • CadFatherC
          CadFather
          Thom, you mean in the subject, or just the post?
          @ humpmetwice, i don't think this has to do with SCF-PB - take out all your plugins then install PB, if it works then you know..
            At least the subject - since that appears when you browse the forum and also in Jim's index.
            • CadFatherC
              CadFather
              yes of course.. done.
              • U
                unclex
                where is the new guy?
                • T
                  the.pjt
                  How do we can unpack the main file to edit it ? is it possible to unpack a code ? can you upload a unpacked version ?
                  • B
                    bd99
                    thankkkkkkkkkkkkkkkkkkkk
                    • E
                      exposal
                      I've try on SU8.0 PRO.that's no problem.
                      • H
                        hyprc
                        so cool, thank U
                          I've edited the download page - with a warning about 'rogue files' inside the zip!
                          CADfather, can you please sort out this issue, which can break some other tools and cause other problems - the older files [ sketchup.rb and extensions.rb] supplied in the zip should NEVER be put into the Plugins folder. In all recent versions of Sketchup newer versions of those files come pre-installed in the Tools folder, so having these duplicates just messes things up - sometimes so subtly it causes hours of searching to find what's up! 😒
                          • CadFatherC
                            CadFather
                            sure, i'll post an update very soon
                            • U
                              Unr Cruurni
                              Hay all fearless Ruby Scripters!
                              First I want to thank you all for the wonderfull job your doing !
                              now,
                              Using SCF powerbar with Metric Meters template is O.k?
                              since I'v been having trouble with the Push-Pull along normals tool.
                              I set 6m as a value and it Pulls 0.15m...
                              Thanks ! ALOT!
                                anderseide
                                Hello¨
                                First of all, great work!
                                Second, am I the only one getting trouble installing all the SCF bars(power bar, architect, draw tool, selective etc)? They all have their icons in a folder called CD_ICONS, so loading them all in the plugins folder made them overwrite each other. In the end I had to change each folder to CD_ICON1, CD_ICON2, and then change the routing in the orignial rb. file.
                                Am I the only one experiencing this?
                                Third: All my plugin toolbars load at startup except the different SCFs. I have tried twenty times to place them and save the template, but it doesnt work When I manually toggle them on, theyre in the right place, so I guess the template is saved, but the toolbars wont show up without manually enabling them.
                                Any suggestions?
                                • 4 / 4
