    [Plugin] SCF PowerToolbar (09.Sep.2010)
    76 Posts 36 Posters 82.3k Views 36 Watching
    • CadFatherC Offline
      CadFather
      i'm hoping to fix the bugs soon..
        tina0603
        try to replace it with haroldcampbell attachments
          rongvuong
          Don't work with sketchup 8.
          help me?
          • HumpmetwiceH Offline
            Humpmetwice
            I get this error after installing the power toolbar. Did I do something wrong, is there something else I need?
              CadFather
              ok, wrong lines have been changed - hope it still works.
                Could you add a Last Updated timestamp to your original post? Makes it easier to catch any updates when you browse the plugins.
                  Humpmetwice
                  Is there something I can do to fix this or do I need to uninstall it? It still works but is aggravating 😮 !
                    CadFather
                    Thom, you mean in the subject, or just the post?
                    @ humpmetwice, i don't think this has to do with SCF-PB - take out all your plugins then install PB, if it works then you know..
                      At least the subject - since that appears when you browse the forum and also in Jim's index.
                        CadFather
                        yes of course.. done.
                        • U Offline
                          unclex
                          where is the new guy?
                            the.pjt
                            How do we can unpack the main file to edit it ? is it possible to unpack a code ? can you upload a unpacked version ?
                              bd99
                              thankkkkkkkkkkkkkkkkkkkk
                              • E Offline
                                exposal
                                I've try on SU8.0 PRO.that's no problem.
                                • H Offline
                                  hyprc
                                  so cool, thank U
                                    I've edited the download page - with a warning about 'rogue files' inside the zip!
                                    CADfather, can you please sort out this issue, which can break some other tools and cause other problems - the older files [ sketchup.rb and extensions.rb] supplied in the zip should NEVER be put into the Plugins folder. In all recent versions of Sketchup newer versions of those files come pre-installed in the Tools folder, so having these duplicates just messes things up - sometimes so subtly it causes hours of searching to find what's up! 😒
                                      CadFather
                                      sure, i'll post an update very soon
                                      • U Offline
                                        Unr Cruurni
                                        Hay all fearless Ruby Scripters!
                                        First I want to thank you all for the wonderfull job your doing !
                                        now,
                                        Using SCF powerbar with Metric Meters template is O.k?
                                        since I'v been having trouble with the Push-Pull along normals tool.
                                        I set 6m as a value and it Pulls 0.15m...
                                        Thanks ! ALOT!
                                          anderseide
                                          Hello¨
                                          First of all, great work!
                                          Second, am I the only one getting trouble installing all the SCF bars(power bar, architect, draw tool, selective etc)? They all have their icons in a folder called CD_ICONS, so loading them all in the plugins folder made them overwrite each other. In the end I had to change each folder to CD_ICON1, CD_ICON2, and then change the routing in the orignial rb. file.
                                          Am I the only one experiencing this?
                                          Third: All my plugin toolbars load at startup except the different SCFs. I have tried twenty times to place them and save the template, but it doesnt work When I manually toggle them on, theyre in the right place, so I guess the template is saved, but the toolbars wont show up without manually enabling them.
                                          Any suggestions?
                                          • 4 / 4
