    [Plugin] Work Plane
    183 Posts 32 Posters 119.5k Views 32 Watching
    • CadFatherC Offline
      CadFather
      • EarthMoverE Offline
        EarthMover
        Wow killer update! πŸ‘ πŸ‘
        Content Creator at Skapeup
          dedmin
          Excellent work, TIG! You guys just don't let me go away from SketchUP!
            Seems near perfection πŸ˜„
            Seems just missing πŸ˜„
            in adjust ask number of circles
            and "center" is always some tricky ergonomy : possible with inference
            but not evident on an inclined plan! πŸ˜‰
            I arrive one time on 20 try and must think! 😳
            Will be more easy with another paradigme πŸ˜„
            Center point = (pt1 pt2)/2 , (pt2 pt3)/2
            and diameter size = smaller edge
            (ok I can draw a diagonal for have the middle and then the center but...)
              PS Something curious when you "adjust" a circular Plane you obtain the Adjust menu of the rectangular work plane and of course Cirular is transformed in rectangular πŸ˜„!
              Edit That was in the notes 😳
                Pilou!
                I just knew you'd ask this... πŸ˜’
                'Adjust' should recognize a rectangular and disk shaped WorkPlane and thereafter have alternative dialogs... it's on the list...
                Currently you shouldn't get 'Adjust' as an option at all if the selected WorkPlane is a disk.
                This coding error could be corrected... but I supposed one day soon I'll have to fix the 'Adjust' to do both kinds anyway...
                πŸ˜’ πŸ˜’ πŸ˜’
                • kenK Offline
                  ken
                  Since the Cline Axes and Cline Normal are used to check alignment, would it be possible to add a set of TAB toggling 3 workplane disks at the origin of both of these plugin, so one would have a workplane to align the protractor. They would need to be to large, just big enough to allow one to the set the protractor's to the plane.
                  Thank you for ALL the work.
                  Ken
                    Ken
                    I suppose I could add an extra type 'WorkPlane...' > 'New Protractor' to do that - it's be quite easy to make...
                      Here's v2.2 http://forums.sketchucation.com/viewtopic.php?p=274345#p274345
                      'New Protractor' option added.
                      'Adjust' now applies to a plane or a disk - with different dialogs to suit.
                      'New Disk' now has number of 'Segments' and 'Rings' options.
                        dedmin
                        Why rectangle tool doesn't draw on the Workplane?
                          EarthMover
                          Dedmin, check pages 5 & 6 of this thread. Rectangle issue has been covered there. πŸ˜‰
                            @dedmin said:
                            Why rectangle tool doesn't draw on the WorkPlane?
                            It's a known issue with Sketchup itself - it occurs on all faces in groups/instances that are not axial or planar through the origin - not just this tool.
                            There is a 3pt rectangle tool that will work - see the earlier thread...
                            We await a fix from Google...
                              dedmin
                              Sorry 😳 😳
                                Maybe Hide in the Context Menu πŸ˜‰
                                Adjust Protractor
                                and why not a protractor "rectangular" πŸ˜„
                                That becomes the Rolls Royce of Work Plane 😎
                                • kenK Offline
                                  ken
                                  The new "Protractor" option is implemented better than I could even image. Again thanks so much.
                                  Now, I will be quite as a mouse as I will be using the brand new tools.
                                  Ken
                                    CadFather
                                    there may be a glitch in the adjust menu on disk - it worked once, then i got the settings for the rectangular grid instead
                                      Here's v2.3 http://forums.sketchucation.com/viewtopic.php?p=274345#p274345
                                      Glitch when 'Adjust'ing a 'Disk' more than once is now fixed,
                                      A new 'Hide/UnHide All' toggle option added to context-menu/tools-menu.
                                        CadFather
                                        TIG, at least give me the time to finish writing my post! 😲 😎
                                          The cause of the 'Adjust Disk' glitch was obvious to me as soon as you reported it - a line of code was not copied between the normal 'Disk Maker' and the 'Adjusted-Disk Maker' methods - thus the newly 'Adjusted' 'Disk' wasn't given its 'disk' attribute, and therefore the 'Adjust' tool thought it was a 'Plane' and so it 'Adjusted' it accordingly [wrongly!]. Note that 'Adjust' might still fail on older 'Disks', that were made before the recent updates and that don't have a 'disk' attribute - if so you need to re-make them and they will then be OK.
                                          Pilou's Hide/UnHide [good] idea was also very simple to do - just a few lines of code switching the 'WORKPLANE' layer on/off...
                                          πŸ€“
                                            CadFather
                                            ..i see, that actually makes sense.. still that was fast..
                                            [speaking aside] ..and the day hasn't even started..!
                                            Thanks! πŸ‘ β˜€
                                            • 6 / 10
