    [Plugin] Cloud
    72 Posts 25 Posters 105.2k Views 25 Watching
    • MALAISEM
      MALAISE
      Very useful, specially for terrain modelling
      MALAISE
      • Didier BurD
        Didier Bur
        @ Mozzie: please open the ruby console and copy-paste this line: Sketchup.active_model.options[0][2]
        Hit enter and post what happens. You should have an integer returned, from 0 to 4. Any other result shows who's the culprit...
        They changed the units options hash between 7.0 and 7.1 👿
        DB
          What? that has not been documented anywhere - has it?
          • Didier BurD
            Didier Bur
            v6: length unit is: Sketchup.active_model.options[0][2]
            v7.0 length unit is: Sketchup.active_model.options[0][2]
            v 7.1. length unit is: Sketchup.active_model.options[3][2]
            Am I right ?
            DB
              oh, you meant the array index - I thought the hash key had changed:
              ` Sketchup.active_model.options.keys.each {|key| p key; Sketchup.active_model.options[key].each {|k,v| puts "> #{k} - #{v}"} }
              "PageOptions"
              ShowTransition - false
              TransitionTime - 2.0
              "SlideshowOptions"
              LoopSlideshow - true
              SlideTime - 1.0
              "NamedOptions"
              "UnitsOptions"
              LengthPrecision - 0
              LengthFormat - 0
              LengthUnit - 2
              LengthSnapEnabled - false
              LengthSnapLength - 0.0393700787401575
              AnglePrecision - 1
              AngleSnapEnabled - true
              SnapAngle - 15.0
              SuppressUnitsDisplay - false
              ForceInchDisplay - false
              "PrintOptions"
              PrintWidth - 7.0
              PrintHeight - 5.0
              ComputeSizeFromScale - false
              SizeInPrint - 1.0
              SizeInModel - 307.906005859375
              VectorMode - false
              FitToPage - true
              NumberOfPages - 1
              LineWeight - 0.5
              PixelsPerInch - 150.0
              SectionSlice - false
              ModelExtents - false
              PrintQuality - 3
              ScaleAdjustment - 1.0
              QualityAdjustment - 0.5
              ["PageOptions", "SlideshowOptions", "NamedOptions", "UnitsOptions", "PrintOptions"]`
              This is the same in all versions?
                You shouldn't hard-code the units items like that [or any other option for that matter] - because the order can change with each build - instead use model.options["UnitsOptions"]["LengthUnit"] that will work no matter what 🤓
                • Didier BurD
                  Didier Bur
                  Of course ! I don't know why I didn't though of that before...
                  Bug fixed, new version available, same place.
                  DB
                    mozzie
                    Thanks for the fix ... it is no longer necessry but result is;
                    nil
                    for 7.1
                      There are four Cloud threads - can we clean these up please?
                      For instance;
                      Removing the download for the old ones,
                      Replacing [Plugin] with [Obsolete]
                      Add a link to the new version
                      Then finally lock the old ones?
                      When I was looking at the plugin index it was confusing to what was the latest version.
                        Difficult to keep track of what's new, some topics contain plugins but not the [Plugin] prefix, other topics are posted as questions and then a plugin is added but the first post not renamed with the prefix, etc.
                        Yea - we should do a cleanup of all these - have them reposted fresh and remove any outdated version.
                          JGA
                          Thanks very much for providing this plugin, we've recently invested in a Total Station & this translates the point data reliably. Providing a help file is also a boon.
                          We're also using TIG's contourmaker plugin, which helps when exporting to data to AutoCAD.
                          Regards,
                          JGA
                          • E
                            Erkki
                            How to get Cloud_71.rbs and Cloud_6.rb to work?
                            My intention is to load elevation data of a terrain collected with the help of a GSP-logger to create a terrain model for a village. I noticed that there is a plugin Cloud_71.rbs in the Ruby Library Depot by Didier Bur. I understand that the plugin accepts elevation data, if it is in the CSV-format described in the pdf of the plugin. I downloaded Cloud_71.rbs in the plugin folder of Sketchup 7.1 (Windows XP Pro).
                            For some reason the Cloud_71.rbs didn't show up in the Plugin menu or any other menu either after restart of Sketchup 7.1. The older "Clouds" with extension .rb show up, but unfortunately I wasn't able to get them work with the downloaded sample files, although I browsed all the possible SketchUcation discussion forums and also some others for help.
                            Does anyone know if there is an any easy way to get the Cloud_xx.rb plugins to work? And how to get the Cloud_71.rbs plugin show up and make terrain in Sketchup 7.1 or even in the newer Sketchup 8? I'm convinced that there are ways - I just couldn't find the way.
                            I'd be grateful for your help.
                            Kind regards Erkki Finni
                            • Didier BurD
                              Didier Bur
                              Avoid having more than one version of a plugin installed at the same time, remove older versions of cloud script, this may cause the problem.
                              Hope this helps,
                              DB
                              • E
                                Erkki
                                @didier bur said:
                                Hope this helps,
                                Thanks for the hint! I'll try to do this.
                                Regards Erkki Finni
                                • E
                                  Erkki
                                  @didier bur said:
                                  Hope this helps,
                                  Hi again,
                                  1. I removed the oldest versions of the Cloud_xx.rb plugins and
                                  2. left only Cloud_71.rbs in the Plugin folder of Skecthup 7.1.
                                  3. I started Skecthup
                                  4. As it was opened, the File menu included Points Cloud option
                                  5. After this everything was childsplay - all the test files were
                                    drawn beatifully on the screen. I didn't test the Export-option yet.
                                  6. I repeated the test with Skecthup 8.0.3117 and the result was also good.
                                  This success made me happy and confident to use the plugin for my orginal purpose; to create terrain by using GPS-logger data as input. So many thanks for your help!
                                    Sir
                                    anyone tried this on a file with about half a billion points?
                                    • Didier BurD
                                      Didier Bur
                                      It should import the points quite quickly, but for triangulation: forget it (the delaunay algorithm is slow and SU is lazy when drawing such a bunch of new entities).
                                      Regards,
                                      DB
                                        @didier bur said:
                                        Regards,
                                        Tried building the geometry with fill_from_mesh ?
                                        • Didier BurD
                                          Didier Bur
                                          Yes
                                          DB
                                            Sir
                                            ok great thanks for your quick response
                                            • 1 / 4
