    [Plugin] Cloud
    72 Posts 25 Posters 105.2k Views 25 Watching
    • broomstickB
      broomstick
      now, if only I could find reliable dem sources for Italy...
      Anyone know where I could look?
      • GaieusG
        Thanks Didier,
        I am about starting a new project where we not only reconstruct Roman architecture in my city but also contemporary ground surface (based on geological and archaeological research).
        This is exactly the tool I need in these cases. 👍 👍 👍
        • Didier BurD
          Didier Bur
          Nice to see it is useful 😛
          DB
            mozzie
            For me, it's an essential tool.
            And it just gets better!
            Merci Didier!
              mozzie
              The Points Cloud Export function will be a wonderful new tool for me, but I am having trouble with the Export dialog - if I highlight a face with one divide line, then choose Points Cloud >> Export, nothing happens. The Ruby Console shows:
              Error: #<TypeError: no implicit conversion from nil to integer>
              (eval):655:in []' (eval):655:in initialize'
              (eval):1269:in new' (eval):1269:in exportPointsCloud'
              (eval):1281
              (eval):1281:in `call'
              screenshot attached
              Also - would it be possible to nominate a new (not World) origin for export, just as for Import? I will understand if you decide that it will make the tool too complicated.
              Screenshot showing Ruby Console
              • MALAISEM
                MALAISE
                Very useful, specially for terrain modelling
                MALAISE
                • Didier BurD
                  Didier Bur
                  @ Mozzie: please open the ruby console and copy-paste this line: Sketchup.active_model.options[0][2]
                  Hit enter and post what happens. You should have an integer returned, from 0 to 4. Any other result shows who's the culprit...
                  They changed the units options hash between 7.0 and 7.1 👿
                  DB
                    What? that has not been documented anywhere - has it?
                    • Didier BurD
                      Didier Bur
                      v6: length unit is: Sketchup.active_model.options[0][2]
                      v7.0 length unit is: Sketchup.active_model.options[0][2]
                      v 7.1. length unit is: Sketchup.active_model.options[3][2]
                      Am I right ?
                      DB
                        oh, you meant the array index - I thought the hash key had changed:
                        ` Sketchup.active_model.options.keys.each {|key| p key; Sketchup.active_model.options[key].each {|k,v| puts "> #{k} - #{v}"} }
                        "PageOptions"
                        ShowTransition - false
                        TransitionTime - 2.0
                        "SlideshowOptions"
                        LoopSlideshow - true
                        SlideTime - 1.0
                        "NamedOptions"
                        "UnitsOptions"
                        LengthPrecision - 0
                        LengthFormat - 0
                        LengthUnit - 2
                        LengthSnapEnabled - false
                        LengthSnapLength - 0.0393700787401575
                        AnglePrecision - 1
                        AngleSnapEnabled - true
                        SnapAngle - 15.0
                        SuppressUnitsDisplay - false
                        ForceInchDisplay - false
                        "PrintOptions"
                        PrintWidth - 7.0
                        PrintHeight - 5.0
                        ComputeSizeFromScale - false
                        SizeInPrint - 1.0
                        SizeInModel - 307.906005859375
                        VectorMode - false
                        FitToPage - true
                        NumberOfPages - 1
                        LineWeight - 0.5
                        PixelsPerInch - 150.0
                        SectionSlice - false
                        ModelExtents - false
                        PrintQuality - 3
                        ScaleAdjustment - 1.0
                        QualityAdjustment - 0.5
                        ["PageOptions", "SlideshowOptions", "NamedOptions", "UnitsOptions", "PrintOptions"]`
                        This is the same in all versions?
                          You shouldn't hard-code the units items like that [or any other option for that matter] - because the order can change with each build - instead use model.options["UnitsOptions"]["LengthUnit"] that will work no matter what 🤓
                          • Didier BurD
                            Didier Bur
                            Of course ! I don't know why I didn't though of that before...
                            Bug fixed, new version available, same place.
                            DB
                              mozzie
                              Thanks for the fix ... it is no longer necessry but result is;
                              nil
                              for 7.1
                                There are four Cloud threads - can we clean these up please?
                                For instance;
                                Removing the download for the old ones,
                                Replacing [Plugin] with [Obsolete]
                                Add a link to the new version
                                Then finally lock the old ones?
                                When I was looking at the plugin index it was confusing to what was the latest version.
                                  Difficult to keep track of what's new, some topics contain plugins but not the [Plugin] prefix, other topics are posted as questions and then a plugin is added but the first post not renamed with the prefix, etc.
                                  Yea - we should do a cleanup of all these - have them reposted fresh and remove any outdated version.
                                    JGA
                                    Thanks very much for providing this plugin, we've recently invested in a Total Station & this translates the point data reliably. Providing a help file is also a boon.
                                    We're also using TIG's contourmaker plugin, which helps when exporting to data to AutoCAD.
                                    Regards,
                                    JGA
                                    • E
                                      Erkki
                                      How to get Cloud_71.rbs and Cloud_6.rb to work?
                                      My intention is to load elevation data of a terrain collected with the help of a GSP-logger to create a terrain model for a village. I noticed that there is a plugin Cloud_71.rbs in the Ruby Library Depot by Didier Bur. I understand that the plugin accepts elevation data, if it is in the CSV-format described in the pdf of the plugin. I downloaded Cloud_71.rbs in the plugin folder of Sketchup 7.1 (Windows XP Pro).
                                      For some reason the Cloud_71.rbs didn't show up in the Plugin menu or any other menu either after restart of Sketchup 7.1. The older "Clouds" with extension .rb show up, but unfortunately I wasn't able to get them work with the downloaded sample files, although I browsed all the possible SketchUcation discussion forums and also some others for help.
                                      Does anyone know if there is an any easy way to get the Cloud_xx.rb plugins to work? And how to get the Cloud_71.rbs plugin show up and make terrain in Sketchup 7.1 or even in the newer Sketchup 8? I'm convinced that there are ways - I just couldn't find the way.
                                      I'd be grateful for your help.
                                      Kind regards Erkki Finni
                                      • Didier BurD
                                        Didier Bur
                                        Avoid having more than one version of a plugin installed at the same time, remove older versions of cloud script, this may cause the problem.
                                        Hope this helps,
                                        DB
                                        • E
                                          Erkki
                                          @didier bur said:
                                          Hope this helps,
                                          Thanks for the hint! I'll try to do this.
                                          Regards Erkki Finni
                                          • E
                                            Erkki
                                            @didier bur said:
                                            Hope this helps,
                                            Hi again,
                                            1. I removed the oldest versions of the Cloud_xx.rb plugins and
                                            2. left only Cloud_71.rbs in the Plugin folder of Skecthup 7.1.
                                            3. I started Skecthup
                                            4. As it was opened, the File menu included Points Cloud option
                                            5. After this everything was childsplay - all the test files were
                                              drawn beatifully on the screen. I didn't test the Export-option yet.
                                            6. I repeated the test with Skecthup 8.0.3117 and the result was also good.
                                            This success made me happy and confident to use the plugin for my orginal purpose; to create terrain by using GPS-logger data as input. So many thanks for your help!
                                            • 1 / 4
