    [Plugin] Cloud
    72 Posts 25 Posters 105.2k Views 25 Watching
    • Didier BurD
      Didier Bur
      Nice to see it is useful 😛
      DB
        mozzie
        For me, it's an essential tool.
        And it just gets better!
        Merci Didier!
          mozzie
          The Points Cloud Export function will be a wonderful new tool for me, but I am having trouble with the Export dialog - if I highlight a face with one divide line, then choose Points Cloud >> Export, nothing happens. The Ruby Console shows:
          Error: #<TypeError: no implicit conversion from nil to integer>
          (eval):655:in []' (eval):655:in initialize'
          (eval):1269:in new' (eval):1269:in exportPointsCloud'
          (eval):1281
          (eval):1281:in `call'
          screenshot attached
          Also - would it be possible to nominate a new (not World) origin for export, just as for Import? I will understand if you decide that it will make the tool too complicated.
          Screenshot showing Ruby Console
          • MALAISEM
            MALAISE
            Very useful, specially for terrain modelling
            MALAISE
            • Didier BurD
              Didier Bur
              @ Mozzie: please open the ruby console and copy-paste this line: Sketchup.active_model.options[0][2]
              Hit enter and post what happens. You should have an integer returned, from 0 to 4. Any other result shows who's the culprit...
              They changed the units options hash between 7.0 and 7.1 👿
              DB
                What? that has not been documented anywhere - has it?
                • Didier BurD
                  Didier Bur
                  v6: length unit is: Sketchup.active_model.options[0][2]
                  v7.0 length unit is: Sketchup.active_model.options[0][2]
                  v 7.1. length unit is: Sketchup.active_model.options[3][2]
                  Am I right ?
                  DB
                    oh, you meant the array index - I thought the hash key had changed:
                    ` Sketchup.active_model.options.keys.each {|key| p key; Sketchup.active_model.options[key].each {|k,v| puts "> #{k} - #{v}"} }
                    "PageOptions"
                    ShowTransition - false
                    TransitionTime - 2.0
                    "SlideshowOptions"
                    LoopSlideshow - true
                    SlideTime - 1.0
                    "NamedOptions"
                    "UnitsOptions"
                    LengthPrecision - 0
                    LengthFormat - 0
                    LengthUnit - 2
                    LengthSnapEnabled - false
                    LengthSnapLength - 0.0393700787401575
                    AnglePrecision - 1
                    AngleSnapEnabled - true
                    SnapAngle - 15.0
                    SuppressUnitsDisplay - false
                    ForceInchDisplay - false
                    "PrintOptions"
                    PrintWidth - 7.0
                    PrintHeight - 5.0
                    ComputeSizeFromScale - false
                    SizeInPrint - 1.0
                    SizeInModel - 307.906005859375
                    VectorMode - false
                    FitToPage - true
                    NumberOfPages - 1
                    LineWeight - 0.5
                    PixelsPerInch - 150.0
                    SectionSlice - false
                    ModelExtents - false
                    PrintQuality - 3
                    ScaleAdjustment - 1.0
                    QualityAdjustment - 0.5
                    ["PageOptions", "SlideshowOptions", "NamedOptions", "UnitsOptions", "PrintOptions"]`
                    This is the same in all versions?
                      You shouldn't hard-code the units items like that [or any other option for that matter] - because the order can change with each build - instead use model.options["UnitsOptions"]["LengthUnit"] that will work no matter what 🤓
                      • Didier BurD
                        Didier Bur
                        Of course ! I don't know why I didn't though of that before...
                        Bug fixed, new version available, same place.
                        DB
                          mozzie
                          Thanks for the fix ... it is no longer necessry but result is;
                          nil
                          for 7.1
                            There are four Cloud threads - can we clean these up please?
                            For instance;
                            Removing the download for the old ones,
                            Replacing [Plugin] with [Obsolete]
                            Add a link to the new version
                            Then finally lock the old ones?
                            When I was looking at the plugin index it was confusing to what was the latest version.
                              Difficult to keep track of what's new, some topics contain plugins but not the [Plugin] prefix, other topics are posted as questions and then a plugin is added but the first post not renamed with the prefix, etc.
                              Yea - we should do a cleanup of all these - have them reposted fresh and remove any outdated version.
                                JGA
                                Thanks very much for providing this plugin, we've recently invested in a Total Station & this translates the point data reliably. Providing a help file is also a boon.
                                We're also using TIG's contourmaker plugin, which helps when exporting to data to AutoCAD.
                                Regards,
                                JGA
                                • E
                                  Erkki
                                  How to get Cloud_71.rbs and Cloud_6.rb to work?
                                  My intention is to load elevation data of a terrain collected with the help of a GSP-logger to create a terrain model for a village. I noticed that there is a plugin Cloud_71.rbs in the Ruby Library Depot by Didier Bur. I understand that the plugin accepts elevation data, if it is in the CSV-format described in the pdf of the plugin. I downloaded Cloud_71.rbs in the plugin folder of Sketchup 7.1 (Windows XP Pro).
                                  For some reason the Cloud_71.rbs didn't show up in the Plugin menu or any other menu either after restart of Sketchup 7.1. The older "Clouds" with extension .rb show up, but unfortunately I wasn't able to get them work with the downloaded sample files, although I browsed all the possible SketchUcation discussion forums and also some others for help.
                                  Does anyone know if there is an any easy way to get the Cloud_xx.rb plugins to work? And how to get the Cloud_71.rbs plugin show up and make terrain in Sketchup 7.1 or even in the newer Sketchup 8? I'm convinced that there are ways - I just couldn't find the way.
                                  I'd be grateful for your help.
                                  Kind regards Erkki Finni
                                  • Didier BurD
                                    Didier Bur
                                    Avoid having more than one version of a plugin installed at the same time, remove older versions of cloud script, this may cause the problem.
                                    Hope this helps,
                                    DB
                                    • E
                                      Erkki
                                      @didier bur said:
                                      Hope this helps,
                                      Thanks for the hint! I'll try to do this.
                                      Regards Erkki Finni
                                      • E
                                        Erkki
                                        @didier bur said:
                                        Hope this helps,
                                        Hi again,
                                        1. I removed the oldest versions of the Cloud_xx.rb plugins and
                                        2. left only Cloud_71.rbs in the Plugin folder of Skecthup 7.1.
                                        3. I started Skecthup
                                        4. As it was opened, the File menu included Points Cloud option
                                        5. After this everything was childsplay - all the test files were
                                          drawn beatifully on the screen. I didn't test the Export-option yet.
                                        6. I repeated the test with Skecthup 8.0.3117 and the result was also good.
                                        This success made me happy and confident to use the plugin for my orginal purpose; to create terrain by using GPS-logger data as input. So many thanks for your help!
                                          Sir
                                          anyone tried this on a file with about half a billion points?
                                          • Didier BurD
                                            Didier Bur
                                            It should import the points quite quickly, but for triangulation: forget it (the delaunay algorithm is slow and SU is lazy when drawing such a bunch of new entities).
                                            Regards,
                                            DB
                                            • 1 / 4
