    [Plugin] Cloud
    72 Posts 25 Posters 103.8k Views 25 Watching
      Ben Ritter
      Thanks again for sharing.
      • broomstickB Offline
        broomstick
        now, if only I could find reliable dem sources for Italy...
        Anyone know where I could look?
          Thanks Didier,
          I am about starting a new project where we not only reconstruct Roman architecture in my city but also contemporary ground surface (based on geological and archaeological research).
          This is exactly the tool I need in these cases. 👍 👍 👍
          • Didier BurD Offline
            Didier Bur
            Nice to see it is useful 😛
            DB
              mozzie
              For me, it's an essential tool.
              And it just gets better!
              Merci Didier!
                mozzie
                The Points Cloud Export function will be a wonderful new tool for me, but I am having trouble with the Export dialog - if I highlight a face with one divide line, then choose Points Cloud >> Export, nothing happens. The Ruby Console shows:
                Error: #<TypeError: no implicit conversion from nil to integer>
                (eval):655:in []' (eval):655:in initialize'
                (eval):1269:in new' (eval):1269:in exportPointsCloud'
                (eval):1281
                (eval):1281:in `call'
                screenshot attached
                Also - would it be possible to nominate a new (not World) origin for export, just as for Import? I will understand if you decide that it will make the tool too complicated.
                Screenshot showing Ruby Console
                • MALAISEM Offline
                  MALAISE
                  Very useful, specially for terrain modelling
                  MALAISE
                    Didier Bur
                    @ Mozzie: please open the ruby console and copy-paste this line: Sketchup.active_model.options[0][2]
                    Hit enter and post what happens. You should have an integer returned, from 0 to 4. Any other result shows who's the culprit...
                    They changed the units options hash between 7.0 and 7.1 👿
                    DB
                      What? that has not been documented anywhere - has it?
                        Didier Bur
                        v6: length unit is: Sketchup.active_model.options[0][2]
                        v7.0 length unit is: Sketchup.active_model.options[0][2]
                        v 7.1. length unit is: Sketchup.active_model.options[3][2]
                        Am I right ?
                        DB
                          oh, you meant the array index - I thought the hash key had changed:
                          ` Sketchup.active_model.options.keys.each {|key| p key; Sketchup.active_model.options[key].each {|k,v| puts "> #{k} - #{v}"} }
                          "PageOptions"
                          ShowTransition - false
                          TransitionTime - 2.0
                          "SlideshowOptions"
                          LoopSlideshow - true
                          SlideTime - 1.0
                          "NamedOptions"
                          "UnitsOptions"
                          LengthPrecision - 0
                          LengthFormat - 0
                          LengthUnit - 2
                          LengthSnapEnabled - false
                          LengthSnapLength - 0.0393700787401575
                          AnglePrecision - 1
                          AngleSnapEnabled - true
                          SnapAngle - 15.0
                          SuppressUnitsDisplay - false
                          ForceInchDisplay - false
                          "PrintOptions"
                          PrintWidth - 7.0
                          PrintHeight - 5.0
                          ComputeSizeFromScale - false
                          SizeInPrint - 1.0
                          SizeInModel - 307.906005859375
                          VectorMode - false
                          FitToPage - true
                          NumberOfPages - 1
                          LineWeight - 0.5
                          PixelsPerInch - 150.0
                          SectionSlice - false
                          ModelExtents - false
                          PrintQuality - 3
                          ScaleAdjustment - 1.0
                          QualityAdjustment - 0.5
                          ["PageOptions", "SlideshowOptions", "NamedOptions", "UnitsOptions", "PrintOptions"]`
                          This is the same in all versions?
                            You shouldn't hard-code the units items like that [or any other option for that matter] - because the order can change with each build - instead use model.options["UnitsOptions"]["LengthUnit"] that will work no matter what 🤓
                              Didier Bur
                              Of course ! I don't know why I didn't though of that before...
                              Bug fixed, new version available, same place.
                              DB
                                mozzie
                                Thanks for the fix ... it is no longer necessry but result is;
                                nil
                                for 7.1
                                  There are four Cloud threads - can we clean these up please?
                                  For instance;
                                  Removing the download for the old ones,
                                  Replacing [Plugin] with [Obsolete]
                                  Add a link to the new version
                                  Then finally lock the old ones?
                                  When I was looking at the plugin index it was confusing to what was the latest version.
                                    Difficult to keep track of what's new, some topics contain plugins but not the [Plugin] prefix, other topics are posted as questions and then a plugin is added but the first post not renamed with the prefix, etc.
                                    Yea - we should do a cleanup of all these - have them reposted fresh and remove any outdated version.
                                      JGA
                                      Thanks very much for providing this plugin, we've recently invested in a Total Station & this translates the point data reliably. Providing a help file is also a boon.
                                      We're also using TIG's contourmaker plugin, which helps when exporting to data to AutoCAD.
                                      Regards,
                                      JGA
                                      • E Offline
                                        Erkki
                                        How to get Cloud_71.rbs and Cloud_6.rb to work?
                                        My intention is to load elevation data of a terrain collected with the help of a GSP-logger to create a terrain model for a village. I noticed that there is a plugin Cloud_71.rbs in the Ruby Library Depot by Didier Bur. I understand that the plugin accepts elevation data, if it is in the CSV-format described in the pdf of the plugin. I downloaded Cloud_71.rbs in the plugin folder of Sketchup 7.1 (Windows XP Pro).
                                        For some reason the Cloud_71.rbs didn't show up in the Plugin menu or any other menu either after restart of Sketchup 7.1. The older "Clouds" with extension .rb show up, but unfortunately I wasn't able to get them work with the downloaded sample files, although I browsed all the possible SketchUcation discussion forums and also some others for help.
                                        Does anyone know if there is an any easy way to get the Cloud_xx.rb plugins to work? And how to get the Cloud_71.rbs plugin show up and make terrain in Sketchup 7.1 or even in the newer Sketchup 8? I'm convinced that there are ways - I just couldn't find the way.
                                        I'd be grateful for your help.
                                        Kind regards Erkki Finni
                                          Didier Bur
                                          Avoid having more than one version of a plugin installed at the same time, remove older versions of cloud script, this may cause the problem.
                                          Hope this helps,
                                          DB
                                          • E Offline
                                            Erkki
                                            @didier bur said:
                                            Hope this helps,
                                            Thanks for the hint! I'll try to do this.
                                            Regards Erkki Finni
                                            • 1 / 4
