    [Plugin] Cloud
    72 Posts 25 Posters 105.2k Views 25 Watching
    • GaieusG
      Thanks Didier,
      I am about starting a new project where we not only reconstruct Roman architecture in my city but also contemporary ground surface (based on geological and archaeological research).
      This is exactly the tool I need in these cases. 👍 👍 👍
      • Didier BurD
        Didier Bur
        Nice to see it is useful 😛
        DB
          mozzie
          For me, it's an essential tool.
          And it just gets better!
          Merci Didier!
            mozzie
            The Points Cloud Export function will be a wonderful new tool for me, but I am having trouble with the Export dialog - if I highlight a face with one divide line, then choose Points Cloud >> Export, nothing happens. The Ruby Console shows:
            Error: #<TypeError: no implicit conversion from nil to integer>
            (eval):655:in []' (eval):655:in initialize'
            (eval):1269:in new' (eval):1269:in exportPointsCloud'
            (eval):1281
            (eval):1281:in `call'
            screenshot attached
            Also - would it be possible to nominate a new (not World) origin for export, just as for Import? I will understand if you decide that it will make the tool too complicated.
            Screenshot showing Ruby Console
            • MALAISEM
              MALAISE
              Very useful, specially for terrain modelling
              MALAISE
              • Didier BurD
                Didier Bur
                @ Mozzie: please open the ruby console and copy-paste this line: Sketchup.active_model.options[0][2]
                Hit enter and post what happens. You should have an integer returned, from 0 to 4. Any other result shows who's the culprit...
                They changed the units options hash between 7.0 and 7.1 👿
                DB
                  What? that has not been documented anywhere - has it?
                  • Didier BurD
                    Didier Bur
                    v6: length unit is: Sketchup.active_model.options[0][2]
                    v7.0 length unit is: Sketchup.active_model.options[0][2]
                    v 7.1. length unit is: Sketchup.active_model.options[3][2]
                    Am I right ?
                    DB
                      oh, you meant the array index - I thought the hash key had changed:
                      ` Sketchup.active_model.options.keys.each {|key| p key; Sketchup.active_model.options[key].each {|k,v| puts "> #{k} - #{v}"} }
                      "PageOptions"
                      ShowTransition - false
                      TransitionTime - 2.0
                      "SlideshowOptions"
                      LoopSlideshow - true
                      SlideTime - 1.0
                      "NamedOptions"
                      "UnitsOptions"
                      LengthPrecision - 0
                      LengthFormat - 0
                      LengthUnit - 2
                      LengthSnapEnabled - false
                      LengthSnapLength - 0.0393700787401575
                      AnglePrecision - 1
                      AngleSnapEnabled - true
                      SnapAngle - 15.0
                      SuppressUnitsDisplay - false
                      ForceInchDisplay - false
                      "PrintOptions"
                      PrintWidth - 7.0
                      PrintHeight - 5.0
                      ComputeSizeFromScale - false
                      SizeInPrint - 1.0
                      SizeInModel - 307.906005859375
                      VectorMode - false
                      FitToPage - true
                      NumberOfPages - 1
                      LineWeight - 0.5
                      PixelsPerInch - 150.0
                      SectionSlice - false
                      ModelExtents - false
                      PrintQuality - 3
                      ScaleAdjustment - 1.0
                      QualityAdjustment - 0.5
                      ["PageOptions", "SlideshowOptions", "NamedOptions", "UnitsOptions", "PrintOptions"]`
                      This is the same in all versions?
                        You shouldn't hard-code the units items like that [or any other option for that matter] - because the order can change with each build - instead use model.options["UnitsOptions"]["LengthUnit"] that will work no matter what 🤓
                        • Didier BurD
                          Didier Bur
                          Of course ! I don't know why I didn't though of that before...
                          Bug fixed, new version available, same place.
                          DB
                            mozzie
                            Thanks for the fix ... it is no longer necessry but result is;
                            nil
                            for 7.1
                              There are four Cloud threads - can we clean these up please?
                              For instance;
                              Removing the download for the old ones,
                              Replacing [Plugin] with [Obsolete]
                              Add a link to the new version
                              Then finally lock the old ones?
                              When I was looking at the plugin index it was confusing to what was the latest version.
                                Difficult to keep track of what's new, some topics contain plugins but not the [Plugin] prefix, other topics are posted as questions and then a plugin is added but the first post not renamed with the prefix, etc.
                                Yea - we should do a cleanup of all these - have them reposted fresh and remove any outdated version.
                                  JGA
                                  Thanks very much for providing this plugin, we've recently invested in a Total Station & this translates the point data reliably. Providing a help file is also a boon.
                                  We're also using TIG's contourmaker plugin, which helps when exporting to data to AutoCAD.
                                  Regards,
                                  JGA
                                  • E
                                    Erkki
                                    How to get Cloud_71.rbs and Cloud_6.rb to work?
                                    My intention is to load elevation data of a terrain collected with the help of a GSP-logger to create a terrain model for a village. I noticed that there is a plugin Cloud_71.rbs in the Ruby Library Depot by Didier Bur. I understand that the plugin accepts elevation data, if it is in the CSV-format described in the pdf of the plugin. I downloaded Cloud_71.rbs in the plugin folder of Sketchup 7.1 (Windows XP Pro).
                                    For some reason the Cloud_71.rbs didn't show up in the Plugin menu or any other menu either after restart of Sketchup 7.1. The older "Clouds" with extension .rb show up, but unfortunately I wasn't able to get them work with the downloaded sample files, although I browsed all the possible SketchUcation discussion forums and also some others for help.
                                    Does anyone know if there is an any easy way to get the Cloud_xx.rb plugins to work? And how to get the Cloud_71.rbs plugin show up and make terrain in Sketchup 7.1 or even in the newer Sketchup 8? I'm convinced that there are ways - I just couldn't find the way.
                                    I'd be grateful for your help.
                                    Kind regards Erkki Finni
                                    • Didier BurD
                                      Didier Bur
                                      Avoid having more than one version of a plugin installed at the same time, remove older versions of cloud script, this may cause the problem.
                                      Hope this helps,
                                      DB
                                      • E
                                        Erkki
                                        @didier bur said:
                                        Hope this helps,
                                        Thanks for the hint! I'll try to do this.
                                        Regards Erkki Finni
                                        • E
                                          Erkki
                                          @didier bur said:
                                          Hope this helps,
                                          Hi again,
                                          1. I removed the oldest versions of the Cloud_xx.rb plugins and
                                          2. left only Cloud_71.rbs in the Plugin folder of Skecthup 7.1.
                                          3. I started Skecthup
                                          4. As it was opened, the File menu included Points Cloud option
                                          5. After this everything was childsplay - all the test files were
                                            drawn beatifully on the screen. I didn't test the Export-option yet.
                                          6. I repeated the test with Skecthup 8.0.3117 and the result was also good.
                                          This success made me happy and confident to use the plugin for my orginal purpose; to create terrain by using GPS-logger data as input. So many thanks for your help!
                                            Sir
                                            anyone tried this on a file with about half a billion points?
                                            • 1 / 4
