    [Plugin] Component Stringer UPDATED May 23, 2013
    173 Posts 73 Posters 1.1m Views 73 Watching
    • simon le bonS Offline
      simon le bon
      I have found no solution to make the flat stakes to follow the path while they are planted vertically (=invariable direction+ following direction) ❓ ❓
      http://i274.photobucket.com/albums/jj245/Spendauballet/SketchUp/BarriereBucolique04th.jpg
      Well.., I've found a hand-assisted solution 😉
      Fredo6 [Plugin] Tools On Surface - v1.5f
      http://i274.photobucket.com/albums/jj245/Spendauballet/SketchUp/clf_CompString_016th.jpg
      Fredo6 [Plugin] BezierSpline v1.21
      http://i274.photobucket.com/albums/jj245/Spendauballet/SketchUp/clf_CompString_017th.jpg
      I assume I want the stakes are to be regularly spaced, non depending of the declivity. So The 3D curve must be regularly segmented (Segmented Polyline) before to be projected on the wall and on the floor.
      (Re: if reversely we want the stakes planted depending of the déclivity, the segmentation must be done after curve projection on the floor and on the wall.)
      Didier Bur [plugin] Projections version 2
      http://i274.photobucket.com/albums/jj245/Spendauballet/SketchUp/clf_CompString_018th.jpg
      http://i274.photobucket.com/albums/jj245/Spendauballet/SketchUp/clf_CompString_019th.jpg
      The long rectangle set as component, distributed along the wall projected curve using Component Stringer is going to be used as a gauge. A line of this rectangle fall in coincidence with the initial 3D curve. This intersection is the point where to move each stake placed on the ground.
      (Re: 1)ground face is deleted to make the process easy.
      2)Move tool is used with Up arrow to constraint the moving on the blue direction)
      http://i274.photobucket.com/albums/jj245/Spendauballet/SketchUp/clf_CompString_020th.jpg
      http://i274.photobucket.com/albums/jj245/Spendauballet/videos/CompStringFence01.gif
      (The same on Youtube )
      [flash=575,360:1p7pi4pm]http://www.youtube.com/v/zDAQYT0jk6k[/flash:1p7pi4pm]
      http://i274.photobucket.com/albums/jj245/Spendauballet/SketchUp/clf_CompString_021th.jpg
      http://i274.photobucket.com/albums/jj245/Spendauballet/SketchUp/clf_CompString_022th.jpg
      http://i274.photobucket.com/albums/jj245/Spendauballet/SketchUp/clf_CompString_023th.jpg
      http://i274.photobucket.com/albums/jj245/Spendauballet/SketchUp/clf_CompString_024th.jpg
      😒 Simon
      • EscapeArtistE Offline
        EscapeArtist
        Anyone tried this with SU8 yet? I seem to be having difficulty with component orientation and scaling.
          Screenshots? Would help with more specific information.
          • Chris FullmerC Offline
            Yeah, screenshot please 😄 I have not gotten around to testing my plugins with version 8. I'm sure there might be some problems. But problems with scaling and orientation were not on my list of things I was expecting to break - so I'm not exactly sure what might be wrong. But screenshots might help, thanks!
              sklu
              Component Stringer Loading Problem
              I loaded the RB into sketchup folder..but when trying to activate, it doesn't work.
              Ruby Console showing:
              Error: #<ArgumentError: Cannot convert argument to Sketchup::Point3d>
              C:/PROGRA~1/Google/GOOGLE~2/Plugins/clf_component_stringer.rb:79:in add_text' C:/PROGRA~1/Google/GOOGLE~2/Plugins/clf_component_stringer.rb:79:in curve_labeler'
              C:/PROGRA~1/Google/GOOGLE~2/Plugins/clf_component_stringer.rb:70:in curve_ordering' C:/PROGRA~1/Google/GOOGLE~2/Plugins/clf_component_stringer.rb:105:in main'
              C:/PROGRA~1/Google/GOOGLE~2/Plugins/clf_component_stringer.rb:190
              Any help, Chris?
                Hmm, its past my bedtime right now, I'll check it out tomorrow. But what version of SU are you trying it on?
                  sklu
                  SU 7 Pro...tried a few different windows..same error occurs..many thanks
                  • olisheaO Offline
                    olishea
                    Great plugin 👍
                    oli
                      EscapeArtist
                      I found the bug, it was on this side of my computer screen.
                      • V Offline
                        voxdei_999
                        thanks Chris very useful to me
                          Great Beto, glad you like it!
                          • F Offline
                            fabiorossi
                            Any help, Chris?
                            This is just the same error message that I see on my ruby console; I've got su7Pro and this message appears also on SU6;I've tried many times to download "Component Stringer"script but ther is not any changement...............what's the problem??
                            my blog
                            http://progettin3d.blogspot.com/
                              Hmm, does it fail everytime you try it? Can you upload a small test file here for me?
                              Are you using the Itallian Language of SketchUp and is your computer set to Itallian?
                              Upload a test model, I'll start by looking at that.
                                bentleykfrog
                                Nice plugin Chris, would love to see an option to use the tangent of the two edges at the node rather than perpendicular to one edge
                                  raffy
                                  thank you so much for your help....
                                  • soloS Offline
                                    I'm getting this:
                                    Error; #<NoMethodError; undefined method `definition' for nil;NilClass>
                                    C;/Program Files (x86)/Google/Google SketchUp 8/Plugins/clf_component_stringer.rb;103;in `main'
                                    C;/Program Files (x86)/Google/Google SketchUp 8/Plugins/clf_component_stringer.rb;190
                                    C;/Program Files (x86)/Google/Google SketchUp 8/Plugins/clf_component_stringer.rb;103;in `call'
                                    Nothing happens, no dialogue box.
                                      @solo said:
                                      I'm getting this:
                                      The relevant code is this [ending line #103
                                              sel = model.selection
                                      		comp = []
                                      		$arc_labels = []
                                      		comp_height = []
                                      		sel.each do |e|
                                      		  comp << e if e.is_a? Sketchup;;ComponentInstance
                                      		  edges << e if e.is_a? Sketchup;;Edge
                                      		comp_height = comp[0].definition.bounds.depth
                                      So the error is saying that the selection [sel] doesn't contain a component-instance ?
                                      Since 'nil' has no 'definition'...
                                      It could be better trapped to stop if the selection contains no instances but...
                                      SO - question: does the selection contain a component-instance when you run the tool ??
                                        jorge2011
                                        hi sr Chris Fullmer.
                                        This plugin is generating the following error
                                        Error: #<NoMethodError: undefined method edges' for nil:NilClass> C:/Archivos de programa/Google/Google SketchUp 8/Plugins/clf_component_stringer.rb:59:in curve_ordering'
                                        C:/Archivos de programa/Google/Google SketchUp 8/Plugins/clf_component_stringer.rb:56:in times' C:/Archivos de programa/Google/Google SketchUp 8/Plugins/clf_component_stringer.rb:56:in curve_ordering'
                                        C:/Archivos de programa/Google/Google SketchUp 8/Plugins/clf_component_stringer.rb:105:in `main'
                                        C:/Archivos de programa/Google/Google SketchUp 8/Plugins/clf_component_stringer.rb:190
                                        I use sketchup8 pro
                                        It is possible to fix?
                                        Thank you very much
                                          Can you supply the model or a part of the model you are working on? Is it repeatedable on all models for you?
                                            jorge2011
                                            that error can not play Mr. Chris, but the plugin works well in general.
                                            thanks
                                            • 6 / 9
