    [Plugin] Component Stringer UPDATED May 23, 2013
    173 Posts 73 Posters 1.1m Views 73 Watching
      maybach67
      great plugin, thanks alots
      • pep75P Offline
        pep75
        unbelievable! Well this is an essential plugin! What can they still do at Google?
        SU has become a full functional modeller at the moment...
        Thanks Chris!
          grim
          chris
          the video shows a great tool and i have put it to the test, i build a chain link and made it a component, however when i apply the plug in it spaces the component far apart and rotates it in odd positions a can not seem to imitate the steps you show in the tutorial video 👿 is there a problem with this script?
            no 😄
            • Chris FullmerC Offline
              Hi Grim, it is important to pay attention to the x-component axis. This plugin uses the component axis to place the component. So you are going to have to make sure that the axis is placed very strategically. You can post you test model if you are still unable to get it to work,
              • simon le bonS Offline
                simon le bon
                I have found no solution to make the flat stakes to follow the path while they are planted vertically (=invariable direction+ following direction) ❓ ❓
                http://i274.photobucket.com/albums/jj245/Spendauballet/SketchUp/BarriereBucolique04th.jpg
                Well.., I've found a hand-assisted solution 😉
                Fredo6 [Plugin] Tools On Surface - v1.5f
                http://i274.photobucket.com/albums/jj245/Spendauballet/SketchUp/clf_CompString_016th.jpg
                Fredo6 [Plugin] BezierSpline v1.21
                http://i274.photobucket.com/albums/jj245/Spendauballet/SketchUp/clf_CompString_017th.jpg
                I assume I want the stakes are to be regularly spaced, non depending of the declivity. So The 3D curve must be regularly segmented (Segmented Polyline) before to be projected on the wall and on the floor.
                (Re: if reversely we want the stakes planted depending of the déclivity, the segmentation must be done after curve projection on the floor and on the wall.)
                Didier Bur [plugin] Projections version 2
                http://i274.photobucket.com/albums/jj245/Spendauballet/SketchUp/clf_CompString_018th.jpg
                http://i274.photobucket.com/albums/jj245/Spendauballet/SketchUp/clf_CompString_019th.jpg
                The long rectangle set as component, distributed along the wall projected curve using Component Stringer is going to be used as a gauge. A line of this rectangle fall in coincidence with the initial 3D curve. This intersection is the point where to move each stake placed on the ground.
                (Re: 1)ground face is deleted to make the process easy.
                2)Move tool is used with Up arrow to constraint the moving on the blue direction)
                http://i274.photobucket.com/albums/jj245/Spendauballet/SketchUp/clf_CompString_020th.jpg
                http://i274.photobucket.com/albums/jj245/Spendauballet/videos/CompStringFence01.gif
                (The same on Youtube )
                [flash=575,360:1p7pi4pm]http://www.youtube.com/v/zDAQYT0jk6k[/flash:1p7pi4pm]
                http://i274.photobucket.com/albums/jj245/Spendauballet/SketchUp/clf_CompString_021th.jpg
                http://i274.photobucket.com/albums/jj245/Spendauballet/SketchUp/clf_CompString_022th.jpg
                http://i274.photobucket.com/albums/jj245/Spendauballet/SketchUp/clf_CompString_023th.jpg
                http://i274.photobucket.com/albums/jj245/Spendauballet/SketchUp/clf_CompString_024th.jpg
                😒 Simon
                • EscapeArtistE Offline
                  EscapeArtist
                  Anyone tried this with SU8 yet? I seem to be having difficulty with component orientation and scaling.
                    Screenshots? Would help with more specific information.
                      Yeah, screenshot please 😄 I have not gotten around to testing my plugins with version 8. I'm sure there might be some problems. But problems with scaling and orientation were not on my list of things I was expecting to break - so I'm not exactly sure what might be wrong. But screenshots might help, thanks!
                        sklu
                        Component Stringer Loading Problem
                        I loaded the RB into sketchup folder..but when trying to activate, it doesn't work.
                        Ruby Console showing:
                        Error: #<ArgumentError: Cannot convert argument to Sketchup::Point3d>
                        C:/PROGRA~1/Google/GOOGLE~2/Plugins/clf_component_stringer.rb:79:in add_text' C:/PROGRA~1/Google/GOOGLE~2/Plugins/clf_component_stringer.rb:79:in curve_labeler'
                        C:/PROGRA~1/Google/GOOGLE~2/Plugins/clf_component_stringer.rb:70:in curve_ordering' C:/PROGRA~1/Google/GOOGLE~2/Plugins/clf_component_stringer.rb:105:in main'
                        C:/PROGRA~1/Google/GOOGLE~2/Plugins/clf_component_stringer.rb:190
                        Any help, Chris?
                          Hmm, its past my bedtime right now, I'll check it out tomorrow. But what version of SU are you trying it on?
                            sklu
                            SU 7 Pro...tried a few different windows..same error occurs..many thanks
                            • olisheaO Offline
                              olishea
                              Great plugin 👍
                              oli
                                EscapeArtist
                                I found the bug, it was on this side of my computer screen.
                                • V Offline
                                  voxdei_999
                                  thanks Chris very useful to me
                                    Great Beto, glad you like it!
                                    • F Offline
                                      fabiorossi
                                      Any help, Chris?
                                      This is just the same error message that I see on my ruby console; I've got su7Pro and this message appears also on SU6;I've tried many times to download "Component Stringer"script but ther is not any changement...............what's the problem??
                                      my blog
                                      http://progettin3d.blogspot.com/
                                        Hmm, does it fail everytime you try it? Can you upload a small test file here for me?
                                        Are you using the Itallian Language of SketchUp and is your computer set to Itallian?
                                        Upload a test model, I'll start by looking at that.
                                          bentleykfrog
                                          Nice plugin Chris, would love to see an option to use the tangent of the two edges at the node rather than perpendicular to one edge
                                            raffy
                                            thank you so much for your help....
                                            • 6 / 9
