    [Plugin] Component Stringer UPDATED May 23, 2013
    173 Posts 73 Posters 1.1m Views 73 Watching
      sklu
      Component Stringer Loading Problem
      I loaded the RB into sketchup folder..but when trying to activate, it doesn't work.
      Ruby Console showing:
      Error: #<ArgumentError: Cannot convert argument to Sketchup::Point3d>
      C:/PROGRA~1/Google/GOOGLE~2/Plugins/clf_component_stringer.rb:79:in add_text' C:/PROGRA~1/Google/GOOGLE~2/Plugins/clf_component_stringer.rb:79:in curve_labeler'
      C:/PROGRA~1/Google/GOOGLE~2/Plugins/clf_component_stringer.rb:70:in curve_ordering' C:/PROGRA~1/Google/GOOGLE~2/Plugins/clf_component_stringer.rb:105:in main'
      C:/PROGRA~1/Google/GOOGLE~2/Plugins/clf_component_stringer.rb:190
      Any help, Chris?
      • Chris FullmerC Offline
        Hmm, its past my bedtime right now, I'll check it out tomorrow. But what version of SU are you trying it on?
          sklu
          SU 7 Pro...tried a few different windows..same error occurs..many thanks
          • olisheaO Offline
            olishea
            Great plugin πŸ‘
            oli
            • EscapeArtistE Offline
              EscapeArtist
              @thomthom said:
              @escapeartist said:
              Anyone tried this with SU8 yet? I seem to be having difficulty with component orientation and scaling.
              Screenshots? Would help with more specific information.
              I found the bug, it was on this side of my computer screen.
              • V Offline
                voxdei_999
                thanks Chris very useful to me
                  Great Beto, glad you like it!
                  • F Offline
                    fabiorossi
                    Any help, Chris?
                    This is just the same error message that I see on my ruby console; I've got su7Pro and this message appears also on SU6;I've tried many times to download "Component Stringer"script but ther is not any changement...............what's the problem??
                    my blog
                    http://progettin3d.blogspot.com/
                      Hmm, does it fail everytime you try it? Can you upload a small test file here for me?
                      Are you using the Itallian Language of SketchUp and is your computer set to Itallian?
                      Upload a test model, I'll start by looking at that.
                        bentleykfrog
                        Nice plugin Chris, would love to see an option to use the tangent of the two edges at the node rather than perpendicular to one edge
                          raffy
                          thank you so much for your help....
                          • soloS Offline
                            I'm getting this:
                            Error; #<NoMethodError; undefined method `definition' for nil;NilClass>
                            C;/Program Files (x86)/Google/Google SketchUp 8/Plugins/clf_component_stringer.rb;103;in `main'
                            C;/Program Files (x86)/Google/Google SketchUp 8/Plugins/clf_component_stringer.rb;190
                            C;/Program Files (x86)/Google/Google SketchUp 8/Plugins/clf_component_stringer.rb;103;in `call'
                            Nothing happens, no dialogue box.
                              @solo said:
                              I'm getting this:
                              The relevant code is this [ending line #103
                                      sel = model.selection
                              		comp = []
                              		$arc_labels = []
                              		comp_height = []
                              		sel.each do |e|
                              		  comp << e if e.is_a? Sketchup;;ComponentInstance
                              		  edges << e if e.is_a? Sketchup;;Edge
                              		comp_height = comp[0].definition.bounds.depth
                              So the error is saying that the selection [sel] doesn't contain a component-instance ?
                              Since 'nil' has no 'definition'...
                              It could be better trapped to stop if the selection contains no instances but...
                              SO - question: does the selection contain a component-instance when you run the tool ??
                                jorge2011
                                hi sr Chris Fullmer.
                                This plugin is generating the following error
                                Error: #<NoMethodError: undefined method edges' for nil:NilClass> C:/Archivos de programa/Google/Google SketchUp 8/Plugins/clf_component_stringer.rb:59:in curve_ordering'
                                C:/Archivos de programa/Google/Google SketchUp 8/Plugins/clf_component_stringer.rb:56:in times' C:/Archivos de programa/Google/Google SketchUp 8/Plugins/clf_component_stringer.rb:56:in curve_ordering'
                                C:/Archivos de programa/Google/Google SketchUp 8/Plugins/clf_component_stringer.rb:105:in `main'
                                C:/Archivos de programa/Google/Google SketchUp 8/Plugins/clf_component_stringer.rb:190
                                I use sketchup8 pro
                                It is possible to fix?
                                Thank you very much
                                  Can you supply the model or a part of the model you are working on? Is it repeatedable on all models for you?
                                    jorge2011
                                    that error can not play Mr. Chris, but the plugin works well in general.
                                    thanks
                                      ok, I hope it keeps working for you,
                                        Lobster
                                        Hi chris,
                                        Great plugin, however i have this on a model.
                                        /Library/Application Support/Google SketchUp 8/SketchUp/Plugins/clf_component_stringer.rb:80:in add_text' /Library/Application Support/Google SketchUp 8/SketchUp/Plugins/clf_component_stringer.rb:80:in curve_labeler'
                                        /Library/Application Support/Google SketchUp 8/SketchUp/Plugins/clf_component_stringer.rb:70:in curve_ordering' /Library/Application Support/Google SketchUp 8/SketchUp/Plugins/clf_component_stringer.rb:105:in main'
                                        /Library/Application Support/Google SketchUp 8/SketchUp/Plugins/clf_component_stringer.rb:190
                                        /Library/Application Support/Google SketchUp 8/SketchUp/Plugins/clf_component_stringer.rb:80:in `call'
                                        Here is a link for it http://www.mediafire.com/?aesv4fd1ccv1cvn
                                        It does not get to the reverse option. The plugin works fine on a simple box and a curve.
                                        SU8, OSX 10.6.7
                                        It seems to write 'start' but not 'end'.
                                        I hope it is useful, if you have time to have a quick look.
                                        Regards
                                        Sam
                                          raineysky
                                          I am trying to make a chain like in the video in the first post. Must be doing something wrong because I'm getting what's in the picture below when I set the component rotation to 90Β°. Any advice? SU8 Free M2
                                          Thank You
                                            It all has to do with where the component axis is set. It looks like its oriented correctly, its just not centered right. Then once the chain is made, you need to edit the component and extend one end of it so that it overlaps into the other components, which I think I did in the video.
                                            But first, spend some time figuring out how to center the component axis better.
                                            • 6 / 9
