    [Plugin] Component Stringer UPDATED May 23, 2013
    173 Posts 73 Posters 1.2m Views 73 Watching
    • T
      tomislavm
      Thank You Chris!
        maybach67
        great plugin, thanks alots
        • pep75P
          pep75
          unbelievable! Well this is an essential plugin! What can they still do at Google?
          SU has become a full functional modeller at the moment...
          Thanks Chris!
          • G
            grim
            chris
            the video shows a great tool and i have put it to the test, i build a chain link and made it a component, however when i apply the plug in it spaces the component far apart and rotates it in odd positions a can not seem to imitate the steps you show in the tutorial video 👿 is there a problem with this script?
              no 😄
              • Chris FullmerC
                Hi Grim, it is important to pay attention to the x-component axis. This plugin uses the component axis to place the component. So you are going to have to make sure that the axis is placed very strategically. You can post you test model if you are still unable to get it to work,
                • simon le bonS
                  simon le bon
                  I have found no solution to make the flat stakes to follow the path while they are planted vertically (=invariable direction+ following direction) ❓ ❓
                  http://i274.photobucket.com/albums/jj245/Spendauballet/SketchUp/BarriereBucolique04th.jpg
                  Well.., I've found a hand-assisted solution 😉
                  Fredo6 [Plugin] Tools On Surface - v1.5f
                  http://i274.photobucket.com/albums/jj245/Spendauballet/SketchUp/clf_CompString_016th.jpg
                  Fredo6 [Plugin] BezierSpline v1.21
                  http://i274.photobucket.com/albums/jj245/Spendauballet/SketchUp/clf_CompString_017th.jpg
                  I assume I want the stakes are to be regularly spaced, non depending of the declivity. So The 3D curve must be regularly segmented (Segmented Polyline) before to be projected on the wall and on the floor.
                  (Re: if reversely we want the stakes planted depending of the déclivity, the segmentation must be done after curve projection on the floor and on the wall.)
                  Didier Bur [plugin] Projections version 2
                  http://i274.photobucket.com/albums/jj245/Spendauballet/SketchUp/clf_CompString_018th.jpg
                  http://i274.photobucket.com/albums/jj245/Spendauballet/SketchUp/clf_CompString_019th.jpg
                  The long rectangle set as component, distributed along the wall projected curve using Component Stringer is going to be used as a gauge. A line of this rectangle fall in coincidence with the initial 3D curve. This intersection is the point where to move each stake placed on the ground.
                  (Re: 1)ground face is deleted to make the process easy.
                  2)Move tool is used with Up arrow to constraint the moving on the blue direction)
                  http://i274.photobucket.com/albums/jj245/Spendauballet/SketchUp/clf_CompString_020th.jpg
                  http://i274.photobucket.com/albums/jj245/Spendauballet/videos/CompStringFence01.gif
                  (The same on Youtube )
                  [flash=575,360:1p7pi4pm]http://www.youtube.com/v/zDAQYT0jk6k[/flash:1p7pi4pm]
                  http://i274.photobucket.com/albums/jj245/Spendauballet/SketchUp/clf_CompString_021th.jpg
                  http://i274.photobucket.com/albums/jj245/Spendauballet/SketchUp/clf_CompString_022th.jpg
                  http://i274.photobucket.com/albums/jj245/Spendauballet/SketchUp/clf_CompString_023th.jpg
                  http://i274.photobucket.com/albums/jj245/Spendauballet/SketchUp/clf_CompString_024th.jpg
                  😒 Simon
                  • EscapeArtistE
                    EscapeArtist
                    Anyone tried this with SU8 yet? I seem to be having difficulty with component orientation and scaling.
                      Screenshots? Would help with more specific information.
                      • Chris FullmerC
                        Yeah, screenshot please 😄 I have not gotten around to testing my plugins with version 8. I'm sure there might be some problems. But problems with scaling and orientation were not on my list of things I was expecting to break - so I'm not exactly sure what might be wrong. But screenshots might help, thanks!
                          sklu
                          Component Stringer Loading Problem
                          I loaded the RB into sketchup folder..but when trying to activate, it doesn't work.
                          Ruby Console showing:
                          Error: #<ArgumentError: Cannot convert argument to Sketchup::Point3d>
                          C:/PROGRA~1/Google/GOOGLE~2/Plugins/clf_component_stringer.rb:79:in add_text' C:/PROGRA~1/Google/GOOGLE~2/Plugins/clf_component_stringer.rb:79:in curve_labeler'
                          C:/PROGRA~1/Google/GOOGLE~2/Plugins/clf_component_stringer.rb:70:in curve_ordering' C:/PROGRA~1/Google/GOOGLE~2/Plugins/clf_component_stringer.rb:105:in main'
                          C:/PROGRA~1/Google/GOOGLE~2/Plugins/clf_component_stringer.rb:190
                          Any help, Chris?
                          • Chris FullmerC
                            Hmm, its past my bedtime right now, I'll check it out tomorrow. But what version of SU are you trying it on?
                              sklu
                              SU 7 Pro...tried a few different windows..same error occurs..many thanks
                              • olisheaO
                                olishea
                                Great plugin 👍
                                oli
                                • EscapeArtistE
                                  EscapeArtist
                                  I found the bug, it was on this side of my computer screen.
                                  • V
                                    voxdei_999
                                    thanks Chris very useful to me
                                    • Chris FullmerC
                                      Great Beto, glad you like it!
                                      • F
                                        fabiorossi
                                        Any help, Chris?
                                        This is just the same error message that I see on my ruby console; I've got su7Pro and this message appears also on SU6;I've tried many times to download "Component Stringer"script but ther is not any changement...............what's the problem??
                                        my blog
                                        http://progettin3d.blogspot.com/
                                        • Chris FullmerC
                                          Hmm, does it fail everytime you try it? Can you upload a small test file here for me?
                                          Are you using the Itallian Language of SketchUp and is your computer set to Itallian?
                                          Upload a test model, I'll start by looking at that.
                                          • B
                                            bentleykfrog
                                            Nice plugin Chris, would love to see an option to use the tangent of the two edges at the node rather than perpendicular to one edge
                                            • 6 / 9
