    [Plugin] Component Stringer UPDATED May 23, 2013
    173 Posts 73 Posters 1.2m Views 73 Watching
    • Chris FullmerC Offline
      Yeah, screenshot please πŸ˜„ I have not gotten around to testing my plugins with version 8. I'm sure there might be some problems. But problems with scaling and orientation were not on my list of things I was expecting to break - so I'm not exactly sure what might be wrong. But screenshots might help, thanks!
        sklu
        Component Stringer Loading Problem
        I loaded the RB into sketchup folder..but when trying to activate, it doesn't work.
        Ruby Console showing:
        Error: #<ArgumentError: Cannot convert argument to Sketchup::Point3d>
        C:/PROGRA~1/Google/GOOGLE~2/Plugins/clf_component_stringer.rb:79:in add_text' C:/PROGRA~1/Google/GOOGLE~2/Plugins/clf_component_stringer.rb:79:in curve_labeler'
        C:/PROGRA~1/Google/GOOGLE~2/Plugins/clf_component_stringer.rb:70:in curve_ordering' C:/PROGRA~1/Google/GOOGLE~2/Plugins/clf_component_stringer.rb:105:in main'
        C:/PROGRA~1/Google/GOOGLE~2/Plugins/clf_component_stringer.rb:190
        Any help, Chris?
          Hmm, its past my bedtime right now, I'll check it out tomorrow. But what version of SU are you trying it on?
            sklu
            SU 7 Pro...tried a few different windows..same error occurs..many thanks
            • olisheaO Offline
              olishea
              Great plugin πŸ‘
              oli
              • EscapeArtistE Offline
                EscapeArtist
                @thomthom said:
                @escapeartist said:
                Anyone tried this with SU8 yet? I seem to be having difficulty with component orientation and scaling.
                Screenshots? Would help with more specific information.
                I found the bug, it was on this side of my computer screen.
                • V Offline
                  voxdei_999
                  thanks Chris very useful to me
                    Great Beto, glad you like it!
                    • F Offline
                      fabiorossi
                      Any help, Chris?
                      This is just the same error message that I see on my ruby console; I've got su7Pro and this message appears also on SU6;I've tried many times to download "Component Stringer"script but ther is not any changement...............what's the problem??
                      my blog
                      http://progettin3d.blogspot.com/
                        Hmm, does it fail everytime you try it? Can you upload a small test file here for me?
                        Are you using the Itallian Language of SketchUp and is your computer set to Itallian?
                        Upload a test model, I'll start by looking at that.
                          bentleykfrog
                          Nice plugin Chris, would love to see an option to use the tangent of the two edges at the node rather than perpendicular to one edge
                            raffy
                            thank you so much for your help....
                            • soloS Offline
                              I'm getting this:
                              Error; #<NoMethodError; undefined method `definition' for nil;NilClass>
                              C;/Program Files (x86)/Google/Google SketchUp 8/Plugins/clf_component_stringer.rb;103;in `main'
                              C;/Program Files (x86)/Google/Google SketchUp 8/Plugins/clf_component_stringer.rb;190
                              C;/Program Files (x86)/Google/Google SketchUp 8/Plugins/clf_component_stringer.rb;103;in `call'
                              Nothing happens, no dialogue box.
                                @solo said:
                                I'm getting this:
                                The relevant code is this [ending line #103
                                        sel = model.selection
                                		comp = []
                                		$arc_labels = []
                                		comp_height = []
                                		sel.each do |e|
                                		  comp << e if e.is_a? Sketchup;;ComponentInstance
                                		  edges << e if e.is_a? Sketchup;;Edge
                                		comp_height = comp[0].definition.bounds.depth
                                So the error is saying that the selection [sel] doesn't contain a component-instance ?
                                Since 'nil' has no 'definition'...
                                It could be better trapped to stop if the selection contains no instances but...
                                SO - question: does the selection contain a component-instance when you run the tool ??
                                  jorge2011
                                  hi sr Chris Fullmer.
                                  This plugin is generating the following error
                                  Error: #<NoMethodError: undefined method edges' for nil:NilClass> C:/Archivos de programa/Google/Google SketchUp 8/Plugins/clf_component_stringer.rb:59:in curve_ordering'
                                  C:/Archivos de programa/Google/Google SketchUp 8/Plugins/clf_component_stringer.rb:56:in times' C:/Archivos de programa/Google/Google SketchUp 8/Plugins/clf_component_stringer.rb:56:in curve_ordering'
                                  C:/Archivos de programa/Google/Google SketchUp 8/Plugins/clf_component_stringer.rb:105:in `main'
                                  C:/Archivos de programa/Google/Google SketchUp 8/Plugins/clf_component_stringer.rb:190
                                  I use sketchup8 pro
                                  It is possible to fix?
                                  Thank you very much
                                    Can you supply the model or a part of the model you are working on? Is it repeatedable on all models for you?
                                      jorge2011
                                      that error can not play Mr. Chris, but the plugin works well in general.
                                      thanks
                                        ok, I hope it keeps working for you,
                                          Lobster
                                          Hi chris,
                                          Great plugin, however i have this on a model.
                                          /Library/Application Support/Google SketchUp 8/SketchUp/Plugins/clf_component_stringer.rb:80:in add_text' /Library/Application Support/Google SketchUp 8/SketchUp/Plugins/clf_component_stringer.rb:80:in curve_labeler'
                                          /Library/Application Support/Google SketchUp 8/SketchUp/Plugins/clf_component_stringer.rb:70:in curve_ordering' /Library/Application Support/Google SketchUp 8/SketchUp/Plugins/clf_component_stringer.rb:105:in main'
                                          /Library/Application Support/Google SketchUp 8/SketchUp/Plugins/clf_component_stringer.rb:190
                                          /Library/Application Support/Google SketchUp 8/SketchUp/Plugins/clf_component_stringer.rb:80:in `call'
                                          Here is a link for it http://www.mediafire.com/?aesv4fd1ccv1cvn
                                          It does not get to the reverse option. The plugin works fine on a simple box and a curve.
                                          SU8, OSX 10.6.7
                                          It seems to write 'start' but not 'end'.
                                          I hope it is useful, if you have time to have a quick look.
                                          Regards
                                          Sam
                                            raineysky
                                            I am trying to make a chain like in the video in the first post. Must be doing something wrong because I'm getting what's in the picture below when I set the component rotation to 90Β°. Any advice? SU8 Free M2
                                            Thank You
                                            • 6 / 9
