    [Plugin] Component Stringer UPDATED May 23, 2013
    173 Posts 73 Posters 1.1m Views 73 Watching
      KXI System
      Chris, I love your tools but just one thing...
      This plugin I can't get to work for some reason, I even reinstalled it. Nothing happens when I even activate it, here is what I get in the Ruby console:
      Error: #<NoMethodError: undefined methoddefinition' for nil:NilClass>
      C:/Program Files/Google/Google SketchUp 7/Plugins/clf_component_stringer.rb:103:in main' C:/Program Files/Google/Google SketchUp 7/Plugins/clf_component_stringer.rb:190 C:/Program Files/Google/Google SketchUp 7/Plugins/clf_component_stringer.rb:190:in call'
      See Chris? a little help here?`
      Getting the perfect sig is hard...
      Google it!
      • Chris FullmerC Offline
        Thank you for reporting the error with the error codes from the console, helps spped things up a bit!
        It looks like you do not have a component selected when you start the script. So make sure that you select a component first, then start the script.
        If that does not fix it, please upload a test model that you are having problems with and I'll test it.
          KXI System
          Chris,
          After a few moments of struggle I found out that the script works after a few failures...
          But what I have found is that sometimes the selected component changes during action, see attachments:
          Bug1.skp
          Ruby Console:
          No reversing needed Error: #<NoMethodError: undefined methodposition' for nil:NilClass>
          C:/Program Files/Google/Google SketchUp 7/Plugins/clf_component_stringer.rb:137:in main' C:/Program Files/Google/Google SketchUp 7/Plugins/clf_component_stringer.rb:134:in each_with_index'
          C:/Program Files/Google/Google SketchUp 7/Plugins/clf_component_stringer.rb:134:in each' C:/Program Files/Google/Google SketchUp 7/Plugins/clf_component_stringer.rb:134:in each_with_index'
          C:/Program Files/Google/Google SketchUp 7/Plugins/clf_component_stringer.rb:134:in main' C:/Program Files/Google/Google SketchUp 7/Plugins/clf_component_stringer.rb:190 C:/Program Files/Google/Google SketchUp 7/Plugins/clf_component_stringer.rb:190:in call'.`
          Note: 1 try only
          Bug2.skp
          Ruby Console:
          Error: #<NoMethodError: undefined methodedges' for nil:NilClass>
          C:/Program Files/Google/Google SketchUp 7/Plugins/clf_component_stringer.rb:59:in curve_ordering' C:/Program Files/Google/Google SketchUp 7/Plugins/clf_component_stringer.rb:56:in times'
          C:/Program Files/Google/Google SketchUp 7/Plugins/clf_component_stringer.rb:56:in curve_ordering' C:/Program Files/Google/Google SketchUp 7/Plugins/clf_component_stringer.rb:105:in main'
          C:/Program Files/Google/Google SketchUp 7/Plugins/clf_component_stringer.rb:190:in call' Error: #<NoMethodError: undefined method edges' for nil:NilClass>
          C:/Program Files/Google/Google SketchUp 7/Plugins/clf_component_stringer.rb:190:in call' Error: #<ArgumentError: Cannot convert argument to Sketchup::Point3d> C:/Program Files/Google/Google SketchUp 7/Plugins/clf_component_stringer.rb:79:in add_text'
          C:/Program Files/Google/Google SketchUp 7/Plugins/clf_component_stringer.rb:79:in curve_labeler' C:/Program Files/Google/Google SketchUp 7/Plugins/clf_component_stringer.rb:70:in curve_ordering'
          C:/Program Files/Google/Google SketchUp 7/Plugins/clf_component_stringer.rb:105:in main' C:/Program Files/Google/Google SketchUp 7/Plugins/clf_component_stringer.rb:190 C:/Program Files/Google/Google SketchUp 7/Plugins/clf_component_stringer.rb:190:in call'
          Error: #<NoMethodError: undefined method definition' for nil:NilClass> C:/Program Files/Google/Google SketchUp 7/Plugins/clf_component_stringer.rb:103:in main'
          Note 10+ tries, no result
          Bug3.skp
          Ruby Console:
          C:/Program Files/Google/Google SketchUp 7/Plugins/clf_component_stringer.rb:134:in main' C:/Program Files/Google/Google SketchUp 7/Plugins/clf_component_stringer.rb:190 C:/Program Files/Google/Google SketchUp 7/Plugins/clf_component_stringer.rb:190:in call'`
          Note 1 try, "big" problem
          Google it!
          • simon le bonS Offline
            simon le bon
            Hello Chris, Hello everybody,
            I'm back for a little addition in using Component Stringer.
            I have had the idea to use a progressive segmented curve in conjunction with Component Stringer for various interesting effects.
            It exists a Fredo's tool :Fredo_BZ__Animation which can do the goal. But it is build for animation matters and I had found it not enough flexible for my purpose.
            So I have made a small tut to make our Own BZ_animation Curve
            I have made some exemples, not very subtle I guess but I think the idea is shown 😉
            http://i274.photobucket.com/albums/jj245/Spendauballet/SketchUp/temple1300_02_th.jpg
            http://i274.photobucket.com/albums/jj245/Spendauballet/SketchUp/temple1300_03_th.jpg
            *s
            • brookefoxB Offline
              brookefox
              Well, I'm happy to post this homely little picture: my first entry into the well-worn spiral stair saga. Contents: the usual suspects: one set of edges, one component (soon to be tuned and embellished with stringers, railings etc.). Why bother this thread? I just thought maybe a point or two needed clarification: In this case the length of each edge determines the displacement of the component, and the component cannot touch the edges or the routine will not work (for me).
              Thanks, Chris!!
              (For me, it would be nice if the settings were sticky across uses.)
              ~ Brooke
                jackalvn
                Hi Chris, Hi All.
                I used the plugin to make an array of component along a path, but it only create one component at the start of the path and nothing else.
                I don't know what i do wrong. Any help?
                One more thing: The plugin don't give me a choice of inputting distance between components (like Copy to spacing in Copy along path plugin). Or I miss something?
                Thanks for your attention!
                  Hi Hu. There is no option for spacing. It always inserts a component at each line segment. There is no way to skip line segments, or evenly space components over uneven lengthed lines.
                  It should not stop after a single component though. Could you upload the test model where this happened? Thanks,
                    tomislavm
                    Thank You Chris!
                      maybach67
                      great plugin, thanks alots
                      • pep75P Offline
                        pep75
                        unbelievable! Well this is an essential plugin! What can they still do at Google?
                        SU has become a full functional modeller at the moment...
                        Thanks Chris!
                          grim
                          chris
                          the video shows a great tool and i have put it to the test, i build a chain link and made it a component, however when i apply the plug in it spaces the component far apart and rotates it in odd positions a can not seem to imitate the steps you show in the tutorial video 👿 is there a problem with this script?
                            no 😄
                              Hi Grim, it is important to pay attention to the x-component axis. This plugin uses the component axis to place the component. So you are going to have to make sure that the axis is placed very strategically. You can post you test model if you are still unable to get it to work,
                                simon le bon
                                I have found no solution to make the flat stakes to follow the path while they are planted vertically (=invariable direction+ following direction) ❓ ❓
                                http://i274.photobucket.com/albums/jj245/Spendauballet/SketchUp/BarriereBucolique04th.jpg
                                Well.., I've found a hand-assisted solution 😉
                                Fredo6 [Plugin] Tools On Surface - v1.5f
                                http://i274.photobucket.com/albums/jj245/Spendauballet/SketchUp/clf_CompString_016th.jpg
                                Fredo6 [Plugin] BezierSpline v1.21
                                http://i274.photobucket.com/albums/jj245/Spendauballet/SketchUp/clf_CompString_017th.jpg
                                I assume I want the stakes are to be regularly spaced, non depending of the declivity. So The 3D curve must be regularly segmented (Segmented Polyline) before to be projected on the wall and on the floor.
                                (Re: if reversely we want the stakes planted depending of the déclivity, the segmentation must be done after curve projection on the floor and on the wall.)
                                Didier Bur [plugin] Projections version 2
                                http://i274.photobucket.com/albums/jj245/Spendauballet/SketchUp/clf_CompString_018th.jpg
                                http://i274.photobucket.com/albums/jj245/Spendauballet/SketchUp/clf_CompString_019th.jpg
                                The long rectangle set as component, distributed along the wall projected curve using Component Stringer is going to be used as a gauge. A line of this rectangle fall in coincidence with the initial 3D curve. This intersection is the point where to move each stake placed on the ground.
                                (Re: 1)ground face is deleted to make the process easy.
                                2)Move tool is used with Up arrow to constraint the moving on the blue direction)
                                http://i274.photobucket.com/albums/jj245/Spendauballet/SketchUp/clf_CompString_020th.jpg
                                http://i274.photobucket.com/albums/jj245/Spendauballet/videos/CompStringFence01.gif
                                (The same on Youtube )
                                [flash=575,360:1p7pi4pm]http://www.youtube.com/v/zDAQYT0jk6k[/flash:1p7pi4pm]
                                http://i274.photobucket.com/albums/jj245/Spendauballet/SketchUp/clf_CompString_021th.jpg
                                http://i274.photobucket.com/albums/jj245/Spendauballet/SketchUp/clf_CompString_022th.jpg
                                http://i274.photobucket.com/albums/jj245/Spendauballet/SketchUp/clf_CompString_023th.jpg
                                http://i274.photobucket.com/albums/jj245/Spendauballet/SketchUp/clf_CompString_024th.jpg
                                😒 Simon
                                • EscapeArtistE Offline
                                  EscapeArtist
                                  Anyone tried this with SU8 yet? I seem to be having difficulty with component orientation and scaling.
                                    Screenshots? Would help with more specific information.
                                      Yeah, screenshot please 😄 I have not gotten around to testing my plugins with version 8. I'm sure there might be some problems. But problems with scaling and orientation were not on my list of things I was expecting to break - so I'm not exactly sure what might be wrong. But screenshots might help, thanks!
                                        sklu
                                        Component Stringer Loading Problem
                                        I loaded the RB into sketchup folder..but when trying to activate, it doesn't work.
                                        Ruby Console showing:
                                        C:/PROGRA~1/Google/GOOGLE~2/Plugins/clf_component_stringer.rb:79:in add_text' C:/PROGRA~1/Google/GOOGLE~2/Plugins/clf_component_stringer.rb:79:in curve_labeler'
                                        C:/PROGRA~1/Google/GOOGLE~2/Plugins/clf_component_stringer.rb:70:in curve_ordering' C:/PROGRA~1/Google/GOOGLE~2/Plugins/clf_component_stringer.rb:105:in main'
                                        C:/PROGRA~1/Google/GOOGLE~2/Plugins/clf_component_stringer.rb:190
                                        Any help, Chris?
                                          Hmm, its past my bedtime right now, I'll check it out tomorrow. But what version of SU are you trying it on?
                                            sklu
                                            SU 7 Pro...tried a few different windows..same error occurs..many thanks
                                            • 5 / 9
