    Joint Push Pull Classic (Old version) - v2.2a - 26 Apr 17
    368 Posts 150 Posters 2.2m Views 150 Watching
      saedobaid
      thx a lot...u help me πŸ˜„)
      • P
        pmolsen
        Whenever I use the plugin and specify Erase Original Faces plus No Borders, it deletes the original faces but leaves all the surrounding lines from the faces. I am on the latest version (12 June 2010).
        Is that a bug or is there some reason why people would want numerous orphaned lines left behind?
        • fredo6F
          It's probably a bug. Will have a look
            Sir
            yup thats happening for me too, skp7 pro, win 7 64bit
              When I tried to install JPP it told me I already had a LibTraductor.rb installed - and the one I had was 18.8kB - while the one in JPP was 13.4kB. Which one should be kept?
              • mariochaM
                mariocha
                This is the one I have on my Mac.
                %(#008000)[Mario C.
                • fredo6F
                  In BezierSpline 1.4, I updated LibTraductor.rb, which is also used by JPP.
                  The right version is therefore the one dated 15 Aug 10. Although for JPP it does not really matter, it does for BezierSpline.
                  I'll move soon both plugins to LibFredo6 envrionment so that this problem should not happen.
                  • fredo6F
                    NEW RELEASE
                    version 1.5 - 02 Sep 10: maintenance release for SU8
                    • Suppress some warning (though harmless) messages in the Ruby console
                    • JPP now installs itself as an extension of Sketchup (can be disabled / enabled via the Windows > Preferences > Extension dialog
                    • Spanish translation - Thanks to Defisto
                    See main post for download.
                    Note: Because JoinPushPull shares LibTraductor.rb with BezierSpline 1.4, it is also advised to upgrade to BezierSpline 1.4 - 02 Sep 10 (so you have the same version of LibTraductor.rb, dated 31 Aug 10). See Main post of BezierSpline 1.4 for download.
                    • jeff hammondJ
                      oh, hey.
                      one thing i keep meaning to ask you about JPP is if there's a way to make 'thickening' the default finishing method?
                      • CadFatherC
                        CadFather
                        Thank you Fredo
                        is this right? (line 122): JPP_DIR = "JPP_Dir"
                        shouldn't it read 'JPP_Dir_15'
                        • fredo6F
                          oh, hey.
                          JPP does not really have persistent options like some other scripts.
                          However, you can edit the file jointpushpull_main.rb and, on line 386, replace the statement @option_finishing = 'D' by @option_finishing = 'R'
                          • fredo6F
                            @cadfather said:
                            Thank you Fredo
                            Actually this should be on line 226 (in jointpushpull_main.rb)
                            The statement is indeed useless now. I use another method to determine the right folder.
                            Did you encounter problems?
                            • jeff hammondJ
                              perfect!
                              thank you
                                DIEGO-RODRIGUEZ
                                Thanks for the update.
                                a question.
                                pushpull may generate a single click of the mouse?
                                Redo last is possible to use Push Pull, double click mouse? pushpull similar to sketchup
                                pushpull you can add new? similar a SmartPushPull v0.26
                                http://forums.sketchucation.com/viewtopic.php?f=180&t=23341
                                • T
                                  theark
                                  Thanks for Good job and great plug-in.
                                  • fredo6F
                                    a question.
                                    Diego,
                                    I am not clear on your question. What do you request exactly?
                                      I think that he is requesting that you can doubleclick a surface to repeat the last Push-Pull operation. Like the native Push-Pull where you double-click and it extrudes the faces you clicked the same distance as the previous PP.
                                      • CadFatherC
                                        CadFather
                                        No i didn't, in fact the script seems smoother than before.. πŸ˜„
                                          DIEGO-RODRIGUEZ
                                          yes πŸ˜„
                                          or can be "shift + click mouse"
                                          and other questios is:
                                          and to generate pushpull. now you have to do:
                                          selcted face + three click with mouse
                                          can be changed to :
                                          selected face + two click with mouse
                                          similar to native sketchup.
                                          • EarthMoverE
                                            EarthMover
                                            oh, hey.
                                            πŸ‘ Thanks...big help as I only ever use thickening also.
                                            Content Creator at Skapeup
                                            • 11
                                            • 18
                                            • 19
                                            • 9 / 19
