    Joint Push Pull Classic (Old version) - v2.2a - 26 Apr 17
    368 Posts 150 Posters 2.1m Views 150 Watching
      TESLER
      hi,
      thanks for the response. i have tried to upload a model to the internet, but it is now not starting generating the geometry. instead, I have a picture of the problem. this is a screenshot of what was happening. i selected the area to extrude, (the whole model) and then used the JPP tool to extrude about an inch inward. then, it only showed some of the faces in purple outline. when it was done generating the geometry, only the faces that had the purple lines would be extruded. hope this helps you find the problem http://sketchup.google.com/3dwarehouse/details?mid=1a5515310e3adac6b030d9c7c2d7c9e9
      thanks, tesler
      • fredo6F Offline
        @tesler said:
        hi,
        thanks, tesler
        It is difficult to see what's right or wrong on the picture.
        Can you attach the skp file to this thread.
        Also, you can do the JPP progressively by portions. did you try it?
          TESLER
          hi,
          I got the plugin to work again, but it is still not working right. I did try doing the model in chunks, and it seems to have worked. it will just take linger, but that is alright. just for reference, there is an example of the problem attached.
          thanks, TESLER
          tailfin panel lines.skp
          • fredo6F Offline
            @tesler said:
            hi,
            thanks, TESLER
            The problem was in the texturing part of the script. For whatever reasons, it was blocking the computation.
            I modified the JPP script to overcome the issue (skip texturing in case of problem) and tried on your model. Below is the result, noting that it took 15 minutes to process all 2,300 faces and 7,000 edges (you get a blank screen, but the script is still computing). Also, I noticed that you have a few faces which are missing in your original model.
            I am updating the jointpushpull script in the main post.
            tailfin JPP.zip
            • N Offline
              NOLASaintTM
              Suggestion Add a function where you can create a new face when you joint push/pull.....like the CTRL push/pull... What do you guys think?
              "There are only 2 seasons in [color=#008000:29bx2alm]Louisiana[/color:29bx2alm]: [color=#BF0000:29bx2alm]Hurricane Season[/color:29bx2alm] and [color=#BF0000:29bx2alm]Summer[/color:29bx2alm]" My Models: [url:29bx2alm]http://sketchup.google.com/3dwarehouse/search?viewer=06262141413891559654&scoring=m[/url:29bx2alm] [color=#0000FF:29bx2alm]G[/color:29bx2alm][color=#FF0000:29bx2alm]O[/color:29bx2alm][color=#FFBF00:29bx2alm]O[/color:29bx2alm][color=#0000FF:29bx2alm]G[/color:29bx2alm][color=#00BF00:29bx2alm]L[/color:29bx2alm][color=#FF0000:29bx2alm]E[/color:29bx2alm]!!!
              • boofredlayB Offline
                boofredlay
                Using the thickening option does the same thing. When you activate JPP press the tab key for options.
                • N Offline
                  NOLASaintTM
                  πŸ˜• Thanks. Lol.
                    saedobaid
                    thx a lot...u help me πŸ˜„)
                      pmolsen
                      Whenever I use the plugin and specify Erase Original Faces plus No Borders, it deletes the original faces but leaves all the surrounding lines from the faces. I am on the latest version (12 June 2010).
                      Is that a bug or is there some reason why people would want numerous orphaned lines left behind?
                      • fredo6F Offline
                        It's probably a bug. Will have a look
                          Sir
                          yup thats happening for me too, skp7 pro, win 7 64bit
                            When I tried to install JPP it told me I already had a LibTraductor.rb installed - and the one I had was 18.8kB - while the one in JPP was 13.4kB. Which one should be kept?
                            • mariochaM Offline
                              mariocha
                              This is the one I have on my Mac.
                              %(#008000)[Mario C.
                              • fredo6F Offline
                                In BezierSpline 1.4, I updated LibTraductor.rb, which is also used by JPP.
                                The right version is therefore the one dated 15 Aug 10. Although for JPP it does not really matter, it does for BezierSpline.
                                I'll move soon both plugins to LibFredo6 envrionment so that this problem should not happen.
                                • fredo6F Offline
                                  NEW RELEASE
                                  version 1.5 - 02 Sep 10: maintenance release for SU8
                                  • Suppress some warning (though harmless) messages in the Ruby console
                                  • JPP now installs itself as an extension of Sketchup (can be disabled / enabled via the Windows > Preferences > Extension dialog
                                  • Spanish translation - Thanks to Defisto
                                  See main post for download.
                                  Note: Because JoinPushPull shares LibTraductor.rb with BezierSpline 1.4, it is also advised to upgrade to BezierSpline 1.4 - 02 Sep 10 (so you have the same version of LibTraductor.rb, dated 31 Aug 10). See Main post of BezierSpline 1.4 for download.
                                  • jeff hammondJ Offline
                                    oh, hey.
                                    one thing i keep meaning to ask you about JPP is if there's a way to make 'thickening' the default finishing method?
                                    • CadFatherC Offline
                                      CadFather
                                      Thank you Fredo
                                      is this right? (line 122): JPP_DIR = "JPP_Dir"
                                      shouldn't it read 'JPP_Dir_15'
                                      • fredo6F Offline
                                        oh, hey.
                                        JPP does not really have persistent options like some other scripts.
                                        However, you can edit the file jointpushpull_main.rb and, on line 386, replace the statement @option_finishing = 'D' by @option_finishing = 'R'
                                        • fredo6F Offline
                                          @cadfather said:
                                          Thank you Fredo
                                          Actually this should be on line 226 (in jointpushpull_main.rb)
                                          The statement is indeed useless now. I use another method to determine the right folder.
                                          Did you encounter problems?
                                            perfect!
                                            thank you
                                            • 18
                                            • 19
                                            • 8 / 19
