    1.3k Posts 300 Posters 3.1m Views 298 Watching
    • charly2008C
      charly2008
      thanks Fredo,
      you are great.
      Charly
      • X
        xrok1
          Daniel S
          Great update Fredo! Very powerful!!
          If you select all and then apply skin there are still issues with this type of geometry:
          skin not work right.skp
          Daniel S
          • fredo6F
            Daniel S
            Daniel,
            Thanks for this contribution. There are issues, for sure. I will have a close look.
            In the meantime, it is recommended to use the method of explicitly putting small segments to indicate where to cut cell contours.
              DIEGO-RODRIGUEZ
              hi fredo.
              ruby console, a new error:
              D:/Archivos de programa/Google/Google SketchUp 7/Plugins/LIBFREDO6_Dir_35/Lib6EdgePicker.rb:2166: warning: Object#id will be deprecated; use Object#object_id
              Could you fix it.
              I´m use:
              windows xpSp3 Spanish
              sketchup last version in Spanish
              thank you very much
              • fredo6F
                @diego-rodriguez said:
                hi fredo.
                Could you fix it.
                It is just a warning, but I'll fix it for the next release
                • C
                  cam youds
                  I must be slow in the head but I keep getting this msg
                  Cannot load plugin Curviloft because the script cannot create DEFPARAM_Dir folder in:
                  /Library/Application Support/Google SketchUp 7/SketchUp/Plugins
                  Please create it manually, respecting the case
                  What am I doing wrong?????????????????????????????????????????????????
                  • fredo6F
                    It may be that your system folder is protected by some security rules preventing to create folders there by program.
                    So just create the folder DEFPARAM_Dir manually in the directory: /Library/Application Support/Google SketchUp 7/SketchUp/Plugins and this should work.
                    • C
                      cam youds
                      It works....Life changing!...no more rhino or soild works!!!!!!
                        DIEGO-RODRIGUEZ
                        frequently, I have a little problem.
                        does not generate the geometry.
                        http://img94.imageshack.us/img94/2872/86299088.gif
                        if I open the ruby console and run the plugins. Sketchup is labeled.
                        and generate this error:
                        http://img146.imageshack.us/img146/6030/sinttulo1yj.jpg
                        skin test.skp
                        • fredo6F
                          does not generate the geometry. if I open the ruby console and run the plugins. Sketchup is labeled.
                          Diego,
                          The two shapes in your attached file work fine by pre-selecting all contours.
                          But I did not find the small shapes where you seem to have troubles (the one with color edges on your picture).
                          For the warning in the Ruby console, do not worry. This is harmless and I have already fixed it for the next release.
                          fredo
                            DIEGO-RODRIGUEZ
                            hi fredo.
                            thanks for your response.
                            already solved the problem.
                            Reinstall sketchup, in another partition of my hard disk and found that the problem is a file called MSVCRT-ruby18.dll
                            upload the file.
                            file size 853kb not works
                            file size 792kb works
                            file.rar
                            • pep75P
                              pep75
                              Thanks Fredo! Brilliant update!! Thanks so much!!
                              grtzzz
                              Pep
                              • olisheaO
                                olishea
                                this really is a different league of plugin!!
                                something i've been wanting for a LONG time. how come you don't charge? its amazing
                                oli
                                • mariochaM
                                  mariocha
                                  Testing the beta, the skin command cannot complete this file, attached.
                                  EEbyrails does it well tought.
                                  No-skin.skp
                                  %(#008000)[Mario C.
                                    Both work for me... but there are more facets in CurviLoft's result...Capture.PNG
                                    • mariochaM
                                      mariocha
                                      Thanks TIG,
                                      So I tried it on the PC side of my MAC, and it worked just fine.
                                      frustrated me 😢
                                      Strange, cause other curves were ok.
                                      %(#008000)[Mario C.
                                      • fredo6F
                                        Mariocha,
                                        I think I know what it is and why it is specific to Mac. I'll publish a fix soon with a new release.
                                        By the way, you can adjust the density of meshing by using the Interpoland OverSamplingboxes. If you deactivate both, then you get a mesh strictly built on the original contour vertices.
                                        • mariochaM
                                          mariocha
                                          A new relase ? Great !! 👍 👍 👍
                                          And Oversampling & Interpol will be so usefull for designing !
                                          C'est vraiment super !
                                          as I'm working on a tensile structure these days.
                                          %(#008000)[Mario C.
                                          • cmeedC
                                            cmeed
                                            help.
                                            I see skinning videos posted within this thread but i can't get this shape to work. it seems so simple.....
                                            I click contours, click space, i then repeat until all three lines are coloured and click the tick button or open space. i get a PLEASE WAIT then nothing happens.
                                            Am I doing something wrong, is it Because i'm on a mac?
                                            the last picture is tig's rails but i have to make a 4th rail for it to work.
                                            • 11
                                            • 12
                                            • 13
                                            • 65
                                            • 66
                                            • 11 / 66
