    1.3k Posts 299 Posters 2.6m Views 297 Watching
      I would think Fredo's tool superior to my EEbyLoft... BUT mine works with some componentizing and exploding etc !
      Fredo, please borrow whatever ideas work in my tool for yours !
      Capture.PNGcurviloft5.skp
      • massimoM Offline
        massimo Moderator
        Charly, try like this:
        -Select, lets say, four profiles. Explode them and press the loft button;
        -Select the two profiles on the ends of two stumps and press loft. Do that for all the stumps;
        -Delete the unwanted original profiles.
        curviloft5-2_street.skp
        • charly2008C Offline
          charly2008
          In this design I get some errors. The idea was to create a road profile. I have selected the faces one by one. Maybe Fredo can find the error. Even in a straight line this error will appear.
          Charly
          curviloft5.skp
          • mitcorbM Offline
            mitcorb
            In Fredo6's discussion in the first post, I saw something that suggested to leave open a tiny segment in the profile to be lofted. Perhaps to prevent the twisting?
              charly2008
              Dear TIG and Massimo,
              thank you for your advices. The background for my experiments with a winding road is the representation of the curve slope.
              With EEbyLoft I have also tried. TIG, your EEbyL is also a great tool. I would not belittle your merits. But in this case it is difficult to find the correct level for the protractor because the Edges. With Curviloft i can use faces and I can change the faces more simple(made by Perpendiculare Faces) gradually at an specified angle and can construct the slope. And this worked in my first attempt (see pictures below).
              You may have seen my posts with winding Roads in the forum. The disadvantage of these Roads was, that the road profile was shown only horizontal in the curves.
              Charly
              • fredo6F Offline
                NEW BETA RELEASE
                Curviloft 1.0b – LibFredo6 3.5b – 11 Jul 10: Second beta version, dedicated to Loft by Spline and Skinning (Loft Along Path is still not fully functional). Main changes are:
                • Skinning should better accept preselection of contours and make its way to create the mesh
                • Added some spline methods (Linear, Ortho-elliptic and ortho-spline)
                • For Skinning and Loft Along Path, you can over-sample the rails
                • For Skinning, you can swap the direction between contours and rails
                • Preview Mesh is normally black in SU7
                • Floating palette remembers its position across SU sessions
                • Spanish translation by Defisto
                  On top of potential bugs and geometry issues (including bugsplats), there are some limitations and unfinished work
                • VCB is not active
                • No interactive edition in the floating palette
                • B-Spline and F-Spline do not close nicely in loop mode
                • No later reedition of shape generated (this will come)
                • all texts and labels are not reviewed yet
                see main post for download:http://forums.sketchucation.com/viewtopic.php?f=323&t=28586#p248195
                • fredo6F Offline
                  Charly,
                  Thanks very much for your deep testing of Curviloft. It helps me find and hopefully fix the many bugs and imprecisions remaining in the script. This is why I judged that I had to go through a long beta phase with the users.
                  For the long and winding roads, I have found the issues and they should be adressed in the next release 1.0b.
                    dylan
                    Thanks Fredo 👍
                    http://dmdarchitecture.co.uk/
                      charly2008
                      thanks Fredo,
                      you are great.
                      Charly
                      • X Offline
                        xrok1
                          Daniel S
                          Great update Fredo! Very powerful!!
                          If you select all and then apply skin there are still issues with this type of geometry:
                          skin not work right.skp
                          Daniel S
                          • fredo6F Offline
                            Daniel S
                            Daniel,
                            Thanks for this contribution. There are issues, for sure. I will have a close look.
                            In the meantime, it is recommended to use the method of explicitly putting small segments to indicate where to cut cell contours.
                              DIEGO-RODRIGUEZ
                              hi fredo.
                              ruby console, a new error:
                              D:/Archivos de programa/Google/Google SketchUp 7/Plugins/LIBFREDO6_Dir_35/Lib6EdgePicker.rb:2166: warning: Object#id will be deprecated; use Object#object_id
                              Could you fix it.
                              I´m use:
                              windows xpSp3 Spanish
                              sketchup last version in Spanish
                              thank you very much
                              • fredo6F Offline
                                @diego-rodriguez said:
                                hi fredo.
                                Could you fix it.
                                It is just a warning, but I'll fix it for the next release
                                  cam youds
                                  I must be slow in the head but I keep getting this msg
                                  Cannot load plugin Curviloft because the script cannot create DEFPARAM_Dir folder in:
                                  /Library/Application Support/Google SketchUp 7/SketchUp/Plugins
                                  Please create it manually, respecting the case
                                  What am I doing wrong?????????????????????????????????????????????????
                                  • fredo6F Offline
                                    It may be that your system folder is protected by some security rules preventing to create folders there by program.
                                    So just create the folder DEFPARAM_Dir manually in the directory: /Library/Application Support/Google SketchUp 7/SketchUp/Plugins and this should work.
                                      cam youds
                                      It works....Life changing!...no more rhino or soild works!!!!!!
                                        DIEGO-RODRIGUEZ
                                        frequently, I have a little problem.
                                        does not generate the geometry.
                                        http://img94.imageshack.us/img94/2872/86299088.gif
                                        if I open the ruby console and run the plugins. Sketchup is labeled.
                                        and generate this error:
                                        http://img146.imageshack.us/img146/6030/sinttulo1yj.jpg
                                        skin test.skp
                                        • fredo6F Offline
                                          does not generate the geometry. if I open the ruby console and run the plugins. Sketchup is labeled.
                                          Diego,
                                          The two shapes in your attached file work fine by pre-selecting all contours.
                                          But I did not find the small shapes where you seem to have troubles (the one with color edges on your picture).
                                          For the warning in the Ruby console, do not worry. This is harmless and I have already fixed it for the next release.
                                          fredo
                                            DIEGO-RODRIGUEZ
                                            hi fredo.
                                            thanks for your response.
                                            already solved the problem.
                                            Reinstall sketchup, in another partition of my hard disk and found that the problem is a file called MSVCRT-ruby18.dll
                                            upload the file.
                                            file size 853kb not works
                                            file size 792kb works
                                            file.rar
                                            • 11
                                            • 12
                                            • 13
                                            • 65
                                            • 66
                                            • 11 / 66
